Author Topic: DF 700 Systainer problem  (Read 1895 times)
Offline morogue
« on: June 24, 2014, 08:13 PM »
I got the xl a little while back, before the discount  >:( and just today got the systainer full of 8 and 10mm dominos (and the cutters).
I went to put the 8 and 10mm cutters in the df 700's systainer, in their respective slots, and they don't fit. They both want to fall right out as soon as the lid is closed.
I noticed that the 12mm that comes with the xl has a nice cap, and that is what holds it snugly in its slot.
What am I missing or doing wrong?
Offline Crox G
Re: DF 700 Systainer problem
« Reply #1 on: June 24, 2014, 09:00 PM »
Is the cutting end down and the threaded butt up?
CT Midi, ETS 150/3, OF 1400, TS 55, CXS, RO 90, MF-TB, Syslite, necktie, T18 + 3, Carvex PSC 420 EB, Ti15, Domino XL 700, Vecturo
Offline morogue
« Reply #2 on: June 24, 2014, 09:51 PM »
I'm guessing that is the orientation that works?
I was going cutter up, because that is how the 12mm was oriented when bought, and was a bit of a bugger to get loose to start.
I guess I'll try cutter down now and see how it goes.
Offline bkharman
« Reply #3 on: June 24, 2014, 09:58 PM »
I never use those slots. I just leave the cutters in the spiral cases and put them in the bottom of the 700 case. I also have my domi-shims, adapters and other 700 accessories in there. Really a lot of room in that sys.
People, I just want to say, you know, can we all get along? Can we get along?
Offline morogue
« Reply #4 on: June 24, 2014, 10:02 PM »
Yep. All I had to do is just look at the damned diagram of the cutters facing down, right where you insert the cutters.
File that under "DUH, DOY".
Next question, does that foam hold up?
