Author Topic: Extra dust with TS55  (Read 779 times)
Offline SGreenberg
« on: June 08, 2022, 10:16 PM »
I've noticed that my saw is putting out more dust than it used to. I've checked the usual suspects (vacuum bag, clogged hose, tape over window on saw). Everything I can think of checks out. I'm cutting FinColorPly with the 48-tooth blade. Anything I'm missing?
Thanks.
Online SRSemenza
Re: Extra dust with TS55
« Reply #1 on: June 09, 2022, 12:44 AM »
  Try looking into the blade cover through the dust port. Sometimes a shaving will lodge inside. If you don't see anything through the port, then take the side cover off. A jam of shavings can hide pretty well inside.
Offline SGreenberg
« Reply #2 on: June 09, 2022, 10:13 AM »
Thanks for the suggestion. Everything inside looks very clean.
Offline Peter Halle
  • XENA - #4 Coming 8/20/22
« Reply #3 on: June 09, 2022, 07:36 PM »
How old are your filters?  They do slowly clog over time although they might look clean.  At least mine have.  It has always been amazing to see the difference in my case with a filter change.
Just a thought.
Offline Chris Wong
  • Festool Dealer
  • I make things that challenge me.
    • Flair Woodworks
« Reply #4 on: June 09, 2022, 09:54 PM »
Does the blade protrude more through the material less than usual? Are you using a different blade or cutting a different material than you usually work with? Do you have a second dust extractor with which you can compare the suction? Did you recently clean your safety glasses?
Chris Wong, http://FlairWoodworks.com and https://www.ultimatetools.ca/
First Festool was a free pencil.
Shipping live-edge cribbage boards around the world since 2010.
Offline woodbutcherbower
« Reply #5 on: June 10, 2022, 04:17 AM »
@SGreenberg did you pull the blade? As in take it out altogether? I once suffered a similar issue, and everything looked clean and OK from the outside. I checked everything listed by other contributors above. Taking out the blade revealed a large splinter of oak jammed right up inside the roof of the blade housing, with a substantial clog of material built up behind it. The splinter was doing a fine ‘Hoover Dam’ job of preventing dust and debris reaching the extractor port. Just a thought.
« Last Edit: June 10, 2022, 04:22 AM by woodbutcherbower »
Offline SGreenberg
« Reply #6 on: June 10, 2022, 10:36 AM »
Thanks, all good suggestions, and I'd either tried them or did them again now. I even had eye surgery. It's not a major problem, but still seems to be more than it should be. I can live with it for now.
