+1 for roseland
The rails are designed to be this way - when there is no weight the anti-slip pads are able to "hold" the rail a bit in the air.
The idea is that for the anti slip pads to be - well, anti-slip - they must get some pressure to the surface so have to protrude a bit. Once a saw is put in place with a bit of pressure, the the pad does not hold the weight as it is on the rail protrusions on the bottom (next to the anti-slip pad) and the splinter guard edge as the two contact points which create the proper angle with the saw blade.
That is the only way one can have anti-slip (needs pressure on the rubber) AND accurate/repeatable angle (courtesy of the non-squeezable hard surfaces of the Alu protrusion and splinter guard).
I have played with Makita and other no-name rails for our community workshop, and this design detail is what makes the Festool rails superior in sticking to the material - so clamps are not needed 99% of the time.
/Besides the fact they do not come bent from factory (looking at you Makita!)./
I wonder if there was a bad batch?
It can be, but one needs to be careful with distinguishing how the rail "lays" and what is the actual shape of the extrusion.
All 3 of my rails are a "bit" of in air, when just placed on material (think 0.2mm / 0.001"), when clamped (normal pressure), they get even more "in the air", up to 1mm or so. When actually used by a saw/router etc. the splinter guard gets to still be the pressure point and I get perfect cuts even from lamino.
To make a true assessment one would need a detailed measurement of the unloaded extrusion, without any effect of clamps, pads or splinter guard.
Either way, quality service is part of the Festool price - so you did the best thing you could by getting them replaced when not satisfied.
