Author Topic: Festool TS 55 EBQ  (Read 509 times)
Offline Lbob131
Festool TS 55 EBQ
« on: April 05, 2021, 02:50 PM »
My  TS 55  ebq  stopped midway  through a  cut  today.
Have  removed   the   switch  cover   and   electricity   is arriving   at  the  switch  and  passing  through  the  other  side  when  the  trrigger   is  operated.
The  brushes   look  to have  about  8  or  10mm   left.
Any  other  ideas? [smile] Or  checks  I could  do myself?
Before  I  send  it  away.
Offline Frank-Jan
Re: Festool TS 55 EBQ
« Reply #1 on: April 05, 2021, 04:26 PM »
If the cable isn't broken, maybe the thermal protection kicked in.
If that happens on mine, if I try the trigger afterwards it runs but with little power en slower, if I then let it run with no load, it cools down fairly quickly and I can continue sawing.
If you just leave it, or try to saw straight away, the thermal protection will stop it completely, and usually won't start untill the next day.
Offline Lbob131
« Reply #2 on: April 06, 2021, 01:34 PM »
Power  is  leaving  the  switch   outlet  side  when  the trigger  is  pressed  so  its  not a  cable  issue.
And I've  already  tried   a  separate   plug  it  cord.  And  used   the   ts  55  cord  in another  machine  and  no problems.
Also  not  an  over  heating  issue  as  the  saw  was  just  started  up  cutting a  few  feet  of  light  10mm  osb.
My  ts  55  has  locked  out on thermal  over  load to  a lower  RPM   a  few  times  and  I just  stop  the  machine   for  15  minutes  or  so  and  its  back  online  again.
Where upon  I usually change  the  blade.
This  is  the  first  failure   in  the  20  years  I've  had  this  saw.
Offline Doug S
« Reply #3 on: April 06, 2021, 01:58 PM »
It could be the brushes as some Festools have a kind of auto shut off when the brushes reach a certain amount of wear.
Peter Millard had the same problem
Offline Lbob131
« Reply #4 on: April 06, 2021, 06:14 PM »
Thankyou.   Thats  very  useful.
Offline Lbob131
« Reply #5 on: April 09, 2021, 05:56 PM »
Have  the  brushes  fitted  now  and   running  again. [big grin]
