Author Topic: Festool FS-WA/90 vs. TSO GRS-16 (Festool not square)  (Read 602 times)
Offline mikeyr
« on: July 29, 2022, 02:28 PM »
 I thought I was being smart and saving money by buying a Festool FS-WA/90 equivalent to the TSO GRS-16, it even has a TSO clasp on it.   Well, I got it after waiting almost 3 weeks and happily (stupidly?) started cutting away without checking for square and everything was off, just a tiny bit on short cuts and more on longer cuts.  The thing was not 90degree square when I had a rail on it.  Off by a tiny amount but when I was cross-cutting a 4x8 sheet, it was almost a 1/8" off (about 3/32") on the other end.   Luckily Amazon let me return it :) and lesson learned, buy from TSO.
 Thing is, I could not figure out where it was off, putting a square on it sure looked good, but attaching a rail that same square would wobble a bit or have a tiny gap at the end which of course got bigger as the distance went on.  I experimented and could not figure out why/where it was not square, it sure looked good when checking it but attach the rail and no go.   Before any one asks, I used several (4 squares) different squares and rails, from short rail to long and even holey rail (3 rails).  Same results across the board.
 Anyone ever have the GRS-16 be off ? Based on reviews I just assumed they were good at 90degrees.
  I am going to order one from TSO in the next few days, Amazon should refund my money in the next day or 2 although they say 7 days.   All I am looking for is a way to break down sheet goods at a reliable 90, my TS55 leaves a good enough edge on sheet goods that if I can get a 90 I don't need to pass it on the table saw.  Very disappointed in the Festool version of this but is TSO any better ? the reviews say it is.
ex-cabinet maker, now I just play with wood
Offline mino
Re: Festool FS-WA/90 vs. TSO GRS-16 (Festool not square)
« Reply #1 on: July 29, 2022, 04:57 PM »
Check this thread:
https://www.festoolownersgroup.com/festool-tools-accessories/tso-rail-square-not-square/
The issues you see are 99.99% NOT due to the square being off.
If you are a hobby user and can return it, my advice is you return it and just get the adjustable Festool FS-WA and calibrate it for each use. That way you can get absolutely precise cuts even when you do not hit "just the right" rail as the calibration will take care of any micro errors whereever they be.
If you are a pro, I would start by getting a precise reference engineer's square (aka DIN class 1 or, better, class 0) so you actually have a known-good reference and do not have to "shoot blind" like now.
Offline NiteWalkerGR
« Reply #2 on: July 30, 2022, 01:13 PM »
I have the same rail square (the festool branded TSO design) and it's dead on.
Offline afish
« Reply #3 on: August 08, 2022, 08:12 AM »
I'm also not a fan but TSO does make some really good stuff.  I have said it before but I have been down this road many times.  For the most accurate cuts a large MFT style bench with a very stout fence with no play and a good quality rail hinge like dashboard (NOT THE FESTOOL ONE) is the best for square cuts every time.  This is overkill depending on what you might be cutting but if cutting up a cabinet job and a sheet of material is easily $100+ its money well spent in the long run. Im also not a fan of dogs for large cutting jobs.  I see dogs more of a in the field system for making one off cuts that offer quick easy to set up cuts for things that might not need the "highest" of accuracy like cutting fillers. Everyone has there own way but I always struggled getting "super accurate" and repeatable cuts until I switched to a fence and hinge combo.  I would rip by material on a 3hp cabinet saw and handle all cross cutting on the 4x8 MFT bench.
