Author Topic: High pitch noise charger, TCL 3  (Read 5000 times)
Offline janr1982
« on: February 20, 2016, 02:02 PM »
Hi guys,
I have two TCL 3 chargers. One came with my T18 the other with my PDC. The first one is made in China, the second is made in Germany. When I put a battery in one of the two, it makes a very high pitched noise during the entire length of the charging time. Guess one. Does anybody else have this problem?
Offline ginge
Re: High pitch noise charger, TCL 3
« Reply #1 on: February 20, 2016, 02:05 PM »
Mine also makes the noise. Not sure if its a German or Chinese model. Will check on Monday.
Offline DB10
« Reply #2 on: February 20, 2016, 06:32 PM »
Funny that you should mention this as I usually only charge my batteries outside using the TCL3 battery charger and I hadn't noticed this high pitched noise before. When I need to charge batteries in the workshop then I have an older TRC 3 charger permanently plugged in.
 But the other day In the workshop I needed two batteries charged up quickly for the TSC 55 so I had one battery on charge in the older TRC3 and one battery on charge in the TCL3 and noticed that one charger was emitting a high pitched noise, when I checked it was the TCL 3 charger which was making this noise, I'll check to see where it was made.
Offline demographic
« Reply #3 on: February 21, 2016, 11:13 AM »
Had fan cooled chargers do the high pitched whine thing before.
Put it down to a dodgy fan bearing.
Offline Brice Burrell
« Reply #4 on: February 24, 2016, 02:06 PM »
I'd love a followup on this guys.
Offline geoffshep
« Reply #5 on: May 05, 2017, 06:45 AM »
My TCL-6 charger makes a high-pitched whine when a battery is inserted, but it stops after about 10 seconds.
Offline yetihunter
« Reply #6 on: May 06, 2017, 01:20 AM »
My German chargers sing.
Offline yetihunter
« Reply #7 on: May 06, 2017, 01:24 AM »
The frequency should change with a lithium ion charging cycle (which is more like cycles since the last bit is an infinite "trickle charge").
Offline John Huh
    • Tidbits
« Reply #8 on: March 25, 2021, 10:50 AM »
I just got a TCL 6 charger with the RTSC 400 Li sander set. The noise is there during charging as well as when there's no battery inserted. Is this defective?
Called Festool Support. They are asking to send it in.
Shipped today. Let's see how long it takes to get it back.
« Last Edit: April 08, 2021, 02:53 PM by John Huh »
Offline Birdhunter
« Reply #9 on: March 26, 2021, 04:54 AM »
I’m mostly deaf without my aids. Can’t help here.
Birdhunter
Offline mrB
« Reply #10 on: March 26, 2021, 05:50 AM »
Wow, a bizarre amount of inconsistency here. My TLC3 makes no noise but my newer TLC6 makes the high pitched whine for the full duration of charging only (not while empty/unused)
Offline John Huh
    • Tidbits
« Reply #11 on: April 08, 2021, 02:47 PM »
I just got a TCL 6 charger with the RTSC 400 Li sander set. The noise is there during charing as well as when there's no battery inserted. Is this defective?
Got the unit back. Festool sent me a brand new one. It still has the same issue, but much quieter. I guess that's by design?
