Author Topic: ETS 150 EC, brushless orbital  (Read 1232 times)
Offline Stktrader
« on: January 22, 2021, 09:09 PM »
Bought one from a dealer in Utah. Wouldn’t stay on longer than 15 seconds. Sent back for a refund. Bought another from a dealer in Ohio. Started shutting off after 100 lineal feet of sanding wood floor wall edges. Sent back for a refund. What’s up? My $60 Dewalt doesn’t have these problems. I doubt I will buy a third unless this problem is addressed.
Offline neilc
Re: ETS 150 EC, brushless orbital
« Reply #1 on: January 22, 2021, 11:44 PM »
I’ve had one since they were introduced and it works great.  Have you spoken to Festool Service in Indiana?
My unit is really my favorite FT sander.  So smooth and easy to use.
Good luck on resolving the problem.
Offline nvalinski
« Reply #2 on: January 23, 2021, 11:09 AM »
The ETS EC's have a little tiny clear spot on the dust port that detect if a hose is attached. If you do not have the hose pushed on and locked on all the way, it may have the tendency to slip back, allowing the photosensor in that clear window to see light and assume your hose has slipped off. This is to prevent you from being able to sand without proper dust extraction, but can be frustrating if you aren't aware of the feature. You can disable the feature if you want through a sequence that can be found in the manual.
Offline Alex
« Reply #3 on: January 23, 2021, 11:23 AM »
I have an incling a hose wasn't used and a manual wasn't read.
Offline Stktrader
« Reply #4 on: January 25, 2021, 03:46 PM »
You guys are right. I didn’t read the manual. I have an Ets 150 eq and just assumed it worked like the ec. Thanks for the feed back. I may buy another in the future but frankly my Dewalt 5” orbital does all that I need for floor sanding so I may stick with that tool.
Offline mrB
« Reply #5 on: January 25, 2021, 04:21 PM »
Could it really be the hose detection? The sander wouldn’t stop because of that, it would never have started. .
Offline Stktrader
« Reply #6 on: January 25, 2021, 04:31 PM »
I put the hose up to that first ring on the sander. Not all the way up to where it connects to the sander housing. It felt very solid the way I connected it.
Offline nvalinski
« Reply #7 on: January 25, 2021, 05:12 PM »
I had issues with mine early on, not necessarily doing the full twist lock with the connection at first (the bayonette connection is a bit of a hassle at first) and having the hose vibrate off just enough to expose the sensor. Once you are aware of needing to put it on all the way every time, the problem disappeared.
Offline Stktrader
« Reply #8 on: January 27, 2021, 09:34 AM »
I read the manual and the dust hose signal is deactivated unless one turns it on. I did not turn it on so these two orbitals I bought and returned were defective or they are just under engineered for my use. I need to run it on high speed for up to 2-3 hours on large floor refinishing jobs with 80g sandpaper. This tool cannot handle that load apparently. My 2nd ec stopped after less than 100 feet. I won’t by buying another. My $60 Dewalt can run all day.
Offline Alex
« Reply #9 on: January 27, 2021, 10:11 AM »
It was made with working on cars in mind. I think you indeed over used it and probably the heat protection kicked in.
Sounds to me you'd be better off with a Rotex 150, that sander does a lot better with floors.
Offline Stktrader
« Reply #10 on: January 27, 2021, 10:36 AM »
I bought all three rotex’s last month for a staircase refinish. I will find other uses I assume. I also have an ets 150/5 eq plus orbital that will run for long periods. Not brushless. It’s problem is it has a lower rpm vs the Dewalt or the Rigid so it is slow in that regard. The Festool has low vibration probably due to the lower rpm. The Festool spends its time sitting on a table in my garage. I have it up for sale.
Offline Alex
« Reply #11 on: January 27, 2021, 10:44 AM »
You should try the Rotex on your floors then. First in the geared aggressive mode for the rough work, and then switch over to the fine random orbit mode to finish up. Or whatever suits you.
The Rotex can take a beating. First week I had mine I dropped it 3 meters down the stairs, not a scratch on it. Now, 12 years later it is still going strong and never required maintenance. I don't abuse my tools, but I don't spare them either. Lately it's been showered in tons of drywall dust, but it just doesn't care.
Offline Wood_Slice
« Reply #12 on: February 22, 2021, 05:33 PM »
As per Festool this is a known issue on the ETS EC sanders and they are trying to figure out the cause I guess. I currently have my ETS EC 125/3 sander with their warranty department as well.
DF 500 + Assortments | ETS EC 125/3 EQ | CT MIDI + CT-Fi| MFT3 + Elements| Installer's Set |
