Title says it all really - my new DWC 18-4500 is jamming, i.e. not returning to position so jamming in the compressed position, mainly when doing ceilings as dust gets into the mech - bad design!
I've had Makita cordless autofeed for over 10 years, needed to clean them out once a year or so due to a build up of dust (
I don't do a lot of drywall). Otherwise, after I did a little mod to them, they worked flawlessly.
I've already had to clean this out and lubricate it 3 times in 2 months. It's not the screw strips (currently have a stock of Senco), it jams even when there are no screw strips in it.
I got the Festool for the 'Auto' mode, which is very good. Also spins 500rpm faster than the Makita's.
Other problems - the AF55 (autofeed attachment), is just held in place by nylon sprubng loaded balls - this is rubbish. A couple of times the screw has not fully gone in for whatever reason, the AF55 snags on the screw as it is removed and detaches itself from the DWC, only stopped from crashing to the floor by the long screwdriver bit.
Also it feels heavy. I'm not sure whether to get the 2.6Ah battery to see if it is more useable like that, (add the 5.2Ah's to a basic kit for another tool), or cut my losses and try something else.
Anyone else with the same problems?
