Author Topic: Domino 700 Adjustment  (Read 2462 times)
Offline Birdhunter
« on: March 04, 2019, 11:29 AM »
I just shipped off my Domino 700 to Festool Repair.
It was making slanted mortises. I've had the machine since 2014 and I think it has always had this problem, but not as bad.
Yes, I am a very experienced Domino user with literally hundreds of 500 and 700 Dominos used. I plunge smoothly and the bits are new and I have the same problem with different bit sizes. The problem occurs using the fence as a base and it occurs using the base as a reference.The fence measures to be perfectly parallel to the base. My assumption is that the bit's side-to-side axis has shifted out of plumb with the tool's base.
The projects I've done with the 700 were such that the slanted mortises could be overcome with a little more clamp pressure.
I know this is not a unique problem with the 700.
Question... Has Festool Repair been able to correct the problem?
Birdhunter
Offline ear3
Re: Domino 700 Adjustment
« Reply #1 on: March 16, 2019, 08:58 AM »
@Birdhunter I was experiencing the exact same problem with my 700 -- I measured the slant to be between .2 and .3mm.  As my machine had some downtime, I recently sent it in for service.  Just got it back last week, but haven't had a chance yet to test out whether they've fixed it.  Will do some plunging and get back to you.
Offline ear3
« Reply #2 on: May 07, 2019, 07:27 AM »
@Birdhunter Forgot to provide an update earlier, but my XL now produces straight mortises since it came back from service.  Service note said they adjusted it back to factory spec, so I guess they diagnosed it having developed a skew over time.
Offline Birdhunter
« Reply #3 on: May 07, 2019, 07:35 AM »
Thanks for the update. Glad both our machines are now usable.
Birdhunter
