Author Topic: Why aren't the batteries for my Festool CXS available???  (Read 2127 times)
Offline Part135
« on: October 13, 2019, 02:14 PM »
Hello All,
Forgive me if I'm missing something, but after many years of service, I need to replace the batteries of my Festool CXS driver/drill - T-nr: 496118.  The batteries are 10.8V and 1.3 Ah LiIon, T-Nr:496754.
After an extensive search, the only batteries that come close are available on ebay from the UK with $120 shipping!  How can this be?  How can festool sell a tool and then simply stop making batteries for it?
Now, before you say, "There are batteries available all over the place!" please look at the picture I've attached. I can't find a single Festool battery that has this physical configuration!
305455-0  305457-1305459-2
What am I missing?
Thanks in advance for any help you can offer.
Best,
C
Online Cheese
Re: Why aren't the batteries for my Festool CXS available???
« Reply #1 on: October 13, 2019, 02:26 PM »
Those batteries have been obsoleted. The replacement battery 500243 is 2.6 Ah while the original battery was only 1.5 Ah. There’s a huge runtime difference between the two. Also the new version is only around $45. Pick up the 500243...you’ll ❤️  it.
Offline Bert Vanderveen
« Reply #2 on: October 13, 2019, 02:46 PM »
You could also opt for having the accu-pack rebuilt (or do it yourself). The components (eg the batteries) are widely available. And fairly cheap.
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · DTS 400 · ETS EC 125 w 150 pad · Surfix Set · CTL SYS · CT-VA-20 · … | Mirka 1230L P&C | Hammer: A3 31 Silent Power · N4400 · HS950 | TaigaTools: VacPods Pro Set
On order: … [ ! ]
Offline threesixright
« Reply #3 on: October 13, 2019, 03:25 PM »
I think FT upgraded the batteries, and now for the CXS we are 2.6 Ah (3rd gen?).
I do think the CXS self is still same (form factor wise for accepting batteries), and I'm pretty sure the new machines can run on the older style batteries as-well, and vice versa. Same for the charger. I don't have the older CXS, just guessing here  tbh [blink]
When I take my battery off  (new CXS) I still see the space for the old "magazine style" battery.
I think you should be good.
Offline Part135
« Reply #4 on: October 13, 2019, 04:24 PM »
Thanks for all the great information!  500243's are on the way!
Thanks again to all!
Best,
C
Online Cheese
« Reply #5 on: October 13, 2019, 04:50 PM »
Here's a comparison in size. The base was widened to hold more cells. This makes the CXS more stable when you set it down.  All the batteries and chargers are interchangeable along with the drills. There's really no down side.
Offline mrB
« Reply #6 on: October 13, 2019, 04:57 PM »
All true  [thumbs up]
Offline Bob D.
« Reply #7 on: October 14, 2019, 05:56 AM »
Too bad you couldn't make use of that obsoleted space in the tool for bit storage. It would probably be risky to have metal bits floating around inside the tool though.
« Reply #8 on: October 16, 2019, 06:54 AM »
I think they could, but change is the battery would become to heavy? im guessing they tried to keep the weight down. Altogether the new batteries contains 2-3 more Ah then 1st gen. I think?
Offline xedos
« Reply #9 on: October 16, 2019, 08:48 AM »
The new batteries have more energy because they use better cells capable of storing more energy.   The weights are going to be the same for all intents and purposes.
What's changed is the balance point and feel with all the cells being in the base instead of some of their weight being higher up in the handle.  Has to be cheaper to manuf. a pack without the stalk.
Panasonic used to have bit storage inside their drills for bits back when they were king of the battery drill world. There were clips in the battery compartment.  Haven't seen one in the wild for decades so don't know if they're still doing it though.
  I have seen that they are starting to put some of their tools in black and white Systainers for you collectors out there.
