Author Topic: Does anyone have a vac with a hose garage intact?  (Read 23479 times)
Offline cfullen
« on: October 12, 2016, 10:22 PM »
Hey guys,
More of a call for help here.  I have a CT 36 and have recently purchased a CT mini.  I am on my third garage for the 36 and my new CT mini garage has now cracked in two places.  I have friends with the attic broken into much smaller pieces.
On my CT 36 I have had success "stitching" the broken pieces together with zip ties.  I had done this in the past with ripped fenders in my 4 wheeler.  It works quite well.  I smeared a good amount of epoxy on top of the joint after stitched with the zip ties and it has worked quite well. The first two garages I lost relatively quickly.  It is a short learning curve realizing how fragile these are.  The third one looks a bit like Frankenstein, stitches all over its face.
The CT mini is my road warrior.  It now goes everywhere with me.  That's not to say that I do not baby it because of my previous experience with the CT36.  It got a small fracture on the front left corner and did not make the trip home.  I gently lifted up the front to engage the brake foot and "snap".  I was now the proud owner of a two piece hose garage.  I am going to make an attempt to repair by stitching it up, but I don't think I will have much success because it is a compound fracture.
I will likely be forking out the money for a replacement sooner or later.  Do I have any options?  Should I install a fiberglass backing before I release it into the wild?  (serious question)
The short end of the story is that I cannot be without both of these wonderful dust collectors.  But for the long term, I would like to see a longer life out of the hose garages.  Everything else I own by Festool is rock solid.
Cheers,
CF
Offline Bohdan
Re: Does anyone have a vac with a hose garage intact?
« Reply #1 on: October 12, 2016, 10:54 PM »
You could try filling the back of your existing hose garage with polyurathane foam to reinforce it.
Offline Jim Green
« Reply #2 on: October 13, 2016, 12:53 AM »
I had to laugh when I read the title of your post. I have a ct 26 and a midi both with broken garages that I have replaced a few times. They tip over in your truck or you look at them and there you go crack! I also have a ct 22 and 33 which seem to be almost bullet proof. They all are good vacs but my older ones are shall we say a little more robust.
Offline Cunningrj
« Reply #3 on: October 13, 2016, 01:08 AM »
I just replaced my hose garage and switch today because of damage while in the van. When I was at the connect event, I mentioned it to the repair guys and they said they are aware of it and apparently Festool is looking for a fix. 252251-0
TS 55 EQ-plus•OF 1400 EQ-plus• MFT/3•RO 150 FEQ•ETS EC 125/3 EQ•CT 26 E•
Offline TSO Products
    • TSO Products
« Reply #4 on: October 13, 2016, 08:51 AM »
would not ABS cement (solvent) do a better job for repair with a thin sheet of ABS material as a reinforcement heat formed to conform? - or am I missing the point entirely?
Hans
TSOproducts.com
Offline aloysius
« Reply #5 on: October 13, 2016, 09:15 AM »
Have one for my CT22 sitting on top of the shelves.  Used it once only.  Utter waste of time & money.  Whilst it seemed like a good idea at the time, it actually makes the otherwise compact vac uselessly ungainly & (with a box or 2 loaded with sander/s & abrasives) unstably top heavy.
Unfortunately, it seems that later vacs need the stupid "top box" for the Festo toolcase locking lugs etc.
Maybe you could ditch it altogether & screw &/or glue a Systainer "Metadepot" from the Metabo/Starmix vac range to solve the problem once & for all...
FOG-wit since '95:  Some say since birth...
Offline mleny77
« Reply #6 on: October 13, 2016, 09:34 AM »
I have the CT26 still intact but I don't move it around a lot. How does the cracking happen? Is it from moving around from job site to job site or when you store and remove the hose? When I first got it unit I thought that it seemed a little tight to remove the hose from the garage.
Offline sigmatango
  • Challenge Accepted
« Reply #7 on: October 13, 2016, 09:39 AM »
I just replaced my hose garage and switch today because of damage while in the van. When I was at the connect event, I mentioned it to the repair guys and they said they are aware of it and apparently Festool is looking for a fix. (Attachment Link)
Nice to see someone else whose Festool stuff looks like its been actually used... ;)
TS55REQ - OF1400 - RO150 - CXS - T18+3 - CT26E - BR10 - KAL - MFT3 - SYS2(x1) - SYS-StorageBox - SYS-Toolbox2 -Dewalt DWS709 - Ryobi  P854 - Milwaukee 5616-20 - Kreg PRS2100 - Fuji Semi-Pro 2
Offline SRSemenza
« Reply #8 on: October 13, 2016, 12:49 PM »
Does seem that there are a lot of cracked CT garage housings. But so far my two CT Minis that go to job sites are holding up.  Knock on wood......... or plastic.  [smile]
Offline leakyroof
« Reply #9 on: October 13, 2016, 01:03 PM »
3 vacs, no broken parts or Garage issues. It will interesting to see what develops from this going forward next year.
Offline DrD
  • I might not be fast BUT I sure am slow
« Reply #10 on: October 13, 2016, 02:08 PM »
My CT 26 is 3 yrs old, was moved in 2 house moves in that period of time & everything is intact.  No issues.
KS12 EB Kapex with Delta Folding Table & FastCap Best Fence; TS75 EQ with Parallel Guide Rail Set (FS-PA 495717 & FS-PA-VL 495718) and FS 800/2, 1080/2, 1400/2 LR32, 1400/2, 1900/2 Guide Rails, and Betterly SLC23 Straight Line Connector; DF500 Q with Assortment Systainer; OF1010 EQ with Fine Adjuster for Guide Stop, WA-OF Angle Arm, UP-OF Edging Plate and SF-OF Chip Deflector (486242); OF1400 EQ with OF1400 Dust Hood x 2, OF 1400  Edge Guide x 2, OF 1400  Guide Stop; LR32 Set; PSB399 EQ; EHL65 E; RAS115.04 E; RS2 E; ETS150/3 EQ; RO150 FEQ; Hand Sanding Block Set; CT26 with assortment of AS and Non-AS Hoses; MFT/3 Table x2; SysLite; Assortment of Quick & Screw Clamps, Consumables, Dogs.
Offline PreferrablyWood
« Reply #11 on: October 13, 2016, 02:49 PM »
4 or is it 5 year old CT Midi no cracks, it doesn't get bounced around in the back of a pickup truck or thrown down stairs though..
TS 55 R EBQ, Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, OF 2200, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,
Festool 18V HKC 55, TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus   TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3
Offline Paul G
« Reply #12 on: October 13, 2016, 02:51 PM »
Both my 36 and mini garages are intact. But I don't drive around with them much.
+1
Offline sigmatango
« Reply #13 on: October 13, 2016, 04:47 PM »
I have noticed that I need to buy a sysRoll. I have a tendency to stack all my Festool stuff on my CT26. That could cause future problems...  [scared] [eek]
Offline antss
« Reply #14 on: October 13, 2016, 07:42 PM »
My CT26's is intact. But, that's because it's brand new this summer. The garage , not the vac.
My opinion is that the plastic on this generation of vac is not as robust as the 22/33 series- especially the garages.
However , I was looking at the new sortainers & sys combis this week and plastic on the drawers feels a bit more supple than to old sortainer drawers.
My observations only - as I have not conducted any scientific analysis on any of the materials.
« Last Edit: October 15, 2016, 04:43 AM by antss »
Offline McNally Family
  • Festool Atomic Phaser Particle Blaster (APPB Set)
« Reply #15 on: October 13, 2016, 07:51 PM »
Does seem that there are a lot of cracked CT garage housings. But so far my two CT Minis that go to job sites are holding up.  Knock on wood......... or plastic[smile]
Just don't knock too hard........
GREEN: In order of purchase = | CT26  |  RS 2 E | Hose w/ Sleeve 3.5m | 115mm X 226mm Hand Sanding Block | 80mm X 133mm Hand Sanding Block | HSK D21.5 5m hose | CT Boom Arm Bundle Set | 1080 Plate for custom MFT | OF 1400 EQ Router (metric) w/accessories | SYS-Rock BR10 | Cordless Sander RTSC 400 Set |  Cordless Delta Sander DTSC 400 Basic | Linear Sander LS 130 | PDC 18/4 set | CXS  2.6Ah Set | Installer Cleaning Set (2018 version) |  New style Festool hose D 27/32 x 3,5m AS/CT | Replacement Hose Garage | Remote control CT-F I/M-Set | MFH1000 work stool | Next purchase: TBD
RED: // Mafell P1cc  //  MT55cc  // Next purchase: TBD
Offline Jason Kehl
« Reply #16 on: October 13, 2016, 08:45 PM »
I have 2 Midi and 2 CT-26 on site and 1 CT-36 in the shop. I replaced one of the CT-26 house garages, but otherwise no problems. They get used daily, but not abused. The plastic is not very flexible so we make a point of not banging them into things on site and take a moment to secure them for transport in the tool trailer so they don't shift in transit.
j
Offline Kevin C.
« Reply #17 on: October 13, 2016, 11:04 PM »
Nope! My ct36 is just over a year old and today broke in a third place.
Offline Gregor
« Reply #18 on: October 14, 2016, 04:05 AM »
CT36AC, ~2.8 years old, garage broke around the fixed systainer connectors when moving it over uneven ground (with XL700+OF1010 ontop). According to label produced 2012.
Problem with plastics is that the plasticizer giving it flexibility tend to fail after a while, making it brittle.
Offline JD2720
« Reply #19 on: October 14, 2016, 07:26 AM »
I have owned 8 CTs of all sizes for many years. One stays in the truck full time the others travel as needed. I have yet to even crack a hose garage. I learned early on that the hose garages is not a carrying handles.
Offline Coen
« Reply #20 on: October 15, 2016, 05:55 PM »
A CT-22(-SG), bought in a combo deal with my TS-55, I think in 2006. The hose garage is the -SG part, and was just new at that time. And a CT-26
None of them with cracks. But they largely remain in the garage.
Offline antss
« Reply #21 on: October 17, 2016, 07:40 PM »
Looks like most of the issues are on vacs that travel frequently ?   JD's notwithstanding.
Offline Coen
« Reply #22 on: October 18, 2016, 07:17 AM »
That makes sense, since the hose garage is the thing that sticks out most and bumps into things when transporting it. However, parked under a CS-50... it never contacts with anything.
Offline SS Teach
« Reply #23 on: November 16, 2016, 07:33 PM »
The hose garage on my CT36 has a couple of cracks. I think many many days over 100 degrees F for several years has something to do with it. Plastic things don't last a long time where I live.
RTS 400, LS 130, Sandpaper Systainer, Profile Systainer. ETS 125, Sandpaper Systainer, Ro 90, Sandpaper Systainer,  Ro 150, Sandpaper Systainer, OF 1400, TS 55 REQ, CT36, CXS Li 1.5 Set, Centrotec Wood-Drill-Set/8pcs, CT Wings, Surfix Set. Domino 500, Domino Systainer, Parallel Guide
Offline BJM9818
« Reply #24 on: November 21, 2016, 12:05 AM »
I have a CT36 with just 4 corner post on top. Both my midi garages are fine and one dates back to 2007.
Offline HarveyWildes
« Reply #25 on: November 21, 2016, 09:03 AM »
Mine is fine, but sees mostly shop use.  I have to say that it is a great idea for my house remodel projects - I put my systainer tool caddy on the garage and wheel all the hand and cordless tools around with the vacuum.  I would be disappointed if it broke so that it was no longer usable for that.
Offline duburban
« Reply #26 on: November 22, 2016, 02:19 AM »
I have two vacs and two cracks.
helper: i used a festool "circular saw" to do something simple and it made it really hard
me: exactly, it makes simple cuts complicated and complicated cuts simple
Offline Roseland
« Reply #27 on: November 22, 2016, 03:52 AM »
My 8 year old CT26 is intact, but it spends almost all its life in the workshop, and I don't stack systainers on it.
Andrew
TS55, MFT/3, OF1400, OF1010, CT26, RS100, ETS125, CXS, MFS400, DF-500, Zobos.
Offline chippy
  • Festool Dealer
« Reply #28 on: March 18, 2017, 03:15 AM »
Mine fell over in van last week and now it has cracks and it will fall apart quickly now.
It will be the third top. I see many that are broken it is a real and cheap weakness.
Offline Ross 71
« Reply #29 on: March 18, 2017, 08:35 PM »
My midi has put up with near 2 years of being lumped around and is still intact.
I'm worried now....
If you need a tool and don't buy it, You will ultimately find that you have paid for it but don't have it- Henry Ford
