Author Topic: Ct midi 1. Auto start don't shut off after cutting  (Read 467 times)
Offline 207 carpenter
« on: October 13, 2021, 10:03 AM »
Over a year old but only used on a few remodels pulled
It out set up and now you cut and it starts but doesn't shut off
Offline squall_line
Re: Ct midi 1. Auto start don't shut off after cutting
« Reply #1 on: October 13, 2021, 10:14 AM »
When you say "Midi 1", do you mean the original MIDI with the control knobs, or the MIDI-I with the Bluetooth and touch panel?
The MIDI should keep running up to 3-5 seconds after a cut to clear the hose, but if this started happening recently I'm guessing you already knew that and it runs longer.
Which saw are you using?
What happens if you pull the saw's plug from the MIDI after the cut?  Will it stop?
Do you have another tool you can use to see if it's a tool issue or a MIDI issue?
« Reply #2 on: October 13, 2021, 10:38 AM »
It is ct midi with bt  every thing works but it dosen't shut off after cut unless i turn it off manual
Offline guybo
« Reply #3 on: October 13, 2021, 10:45 AM »
hi, try resetting. hold connectivty and manual @ same time 10 sec. or so till soild purple light appears, and welcome
Offline imdking
  • Tropical woodworking hobbyist
« Reply #4 on: October 14, 2021, 10:45 AM »
Did the reset work?
TS55 REBQ, 2 x FS 1400/2, FS 800/2, Festool carrying bag for rails, FS-AW Cable Deflector, Kapex KS 120 REB, CTM Midi, Domino DF 500, FS-HZ 160 ratchet lever clamps x2.
