Author Topic: Conturo problem  (Read 1170 times)
Offline csamain
Conturo problem
« on: March 24, 2019, 05:04 AM »
Hello !  :)
I start using my festool conturo but I have a big problem: I use my conturo in stationary mode with the  mft/3 ap table and most of the time, when I start gluing, the band is not not driven by the mechanism, the roller turns but the edgeband does not move. So, I have glue everywhere, I can not even interrupt the process ...
I probably have to go wrong but I do not know when or why ... I open the notch to insert my abs band 2mm, I tighten up and then I open 2 clicks. Right?
He writes on the screen that the band is validated and I start it but it does not move, the roller slides on the band! not even 1mm... I tried to insert the band a little more or several cm, it has no effect, .
It has already worked but I do not know how, I proceed in the same way it seems to me... Sometimes the band goes by itself and everything is fine, sometimes it gets stuck and it's stuff :-(
Do you have an idea for not having this problem? Sorry for my english, it's not my mother tongue :)
Offline escan
Re: Conturo problem
« Reply #1 on: March 25, 2019, 09:10 AM »
I've also had banding not insert or eject smoothly. Not sure if its weather or moisture related, or maybe a friction issue but giving it a hand helps to facilitate the in-feed and out-feed. Raising up a 3-4 clicks also helps, just make sure you have enough banding height.
