Author Topic: can't disengage brake on CT MIDI I  (Read 560 times)
Offline Goose15
« on: April 08, 2021, 02:51 PM »
Hi, I just received the CT MIDI I and I was watching a video on youtube in order to get familiar with how to use it.
I put the brake on but now it won't disengage. From the video, it seems so effortless. I'm attaching a picture - does it look like there's something wrong with the green part? (bottom corners don't look flush).
Thank you for your time.
Online FestitaMakool
Re: can't disengage brake on CT MIDI I
« Reply #1 on: April 08, 2021, 03:27 PM »
Seems like your release button is misplaced, yes.
Try push it back and upwards.
Should look like this:
Offline Goose15
« Reply #2 on: April 08, 2021, 04:46 PM »
Thank you for your response.
Unfortunately, it doesn't push back at all. I'll keep trying though.
Offline Lincoln
« Reply #3 on: April 08, 2021, 07:38 PM »
Try moving the 'foot' at the same time as pushing the green release button.
Offline Goose15
« Reply #4 on: April 08, 2021, 07:57 PM »
It worked! Problem solved!
Thank you both for your time!
Offline Mr.Scrappy
« Reply #5 on: April 10, 2021, 04:29 PM »
I had the same issue with mine, took a swift pop with the fist and it retracted, and I popped the green lever not the leg
« Reply #6 on: April 10, 2021, 07:12 PM »
If it happens again, or becoming harder to engage or disengage because of dirt and dust, the assembly comes off with two screws at the bottom to clean and maintain.
Offline Mr.Scrappy
« Reply #7 on: April 10, 2021, 07:20 PM »
If you look at both pictures in this thread you can see the top of the green button/lever is actually out in front of the casing and that’s where the binding is happening, that’s also what I found with mine
