Author Topic: BS 75 (Belt Sander) extraction poor  (Read 929 times)
Offline hklim5
« on: December 17, 2020, 03:50 AM »
Hi all, new to this forum and hoping to work out if what I’m experiencing is normal.
I have the BS 75 belt sander hooked up to my CT 36 E AC at full power vacuum and I’m noticing that there is a lot of sawdust that doesn’t get vacuumed up.
I’m getting by with swapping the vacuum between the sander and the vacuum attachment every minute or so but it is a lot of work to do this. I’m hoping this is not the norm and that perhaps I’m missing something?
Appreciate if anyone can share their experience - hoping to hear that the norm is that saw dust is all vacuumed up (I have 90sq meters of floorboards to sand through and work up through grits so finger crossed)
Thanks in advanced
Offline Roachmill
Re: BS 75 (Belt Sander) extraction poor
« Reply #1 on: December 17, 2020, 05:05 AM »
I've used mine connected to a few different extractors (SYS, MIDI, 26 and the cyclone) and not noticed any difference between them; they got most (75%ish?) of the dust. Theres normally a little dust left on the surface (hardly any really but I'll go over it with a vac between grits) and on the table around the edges. I've always used mine in the sanding frame which may (or may not) help.
Offline Bert Vanderveen
« Reply #2 on: December 17, 2020, 08:28 AM »
Dust extraction is a lot better with an FSR-BS 75 Sanding Frame attached, is my experience. Also, when using the BS 75 in its bare form, I tend to use it outside… : )
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · DTS 400 · ETS EC 125 w 150 pad · Surfix Set · CTL SYS · CT-VA-20 · … | Mirka 1230L P&C | Hammer: A3 31 Silent Power · N4400 · HS950 | TaigaTools: VacPods Pro Set
On order: … [ ! ]
Offline Alex
« Reply #3 on: December 17, 2020, 09:04 AM »
Unfortunately it is the norm with a belt sander that dust extraction is pretty bad. It is due to the shape of the belt sander, a large rotating belt that can't have any holes in it. The dust port has to be located at another point then where the dust is generated.
Offline ultane
« Reply #4 on: December 17, 2020, 09:35 AM »
Welcome to the forum.
I might be wrong… Just ask my X...
Offline PaulMarcel
    • Voilà, my blog
« Reply #5 on: December 17, 2020, 02:59 PM »
I've only minimally used mine, but always with the sanding frame. The DC was pretty good, but I was leveling marquetry, which isn't a lot of dust
« Reply #6 on: December 17, 2020, 04:43 PM »
Since you’re sanding a floor maybe you started with a very course grit. If so you might have clogged up the narrow passageway dust takes to get to the vac hose. Use a bent wire to see if anything can be dislodged.
That belt sander was designed about 40 years ago. At the time it was one of the few tools that even pretended to allow for dust collection. It could be better.
Another possibility is that the chute behind the belt has been degraded. It should extend close the work surface but if several belts have broken when it use it will get worn back. You can also extend it with some thin stiff stock and glue.
Offline aloysius
« Reply #7 on: December 17, 2020, 04:53 PM »
You can't expect extraction to be as effective as with, say a mesh pad on a Rando.  There's only one extraction slit at the rear of the belt housing, meaning that any swarf that escapes sideways from the belt will be missed.
Also, when used on floors etc. which are often dirty or dusty, other unrelated detritis gets sucked up into the airways.  I've experienced partial blockage of the internal airways from dust, fluff & especially fibrous rubbish.  As your sander ages it pays to occasionally (yearly?) part disassemble the tool & clear out the internals.  At the same time you can check on the condition of the grease on the bevel geartrain & the drive belt too.
FOG-wit since '95:  Some say since birth...
Offline hklim5
« Reply #8 on: December 19, 2020, 06:36 AM »
Thanks for the input everyone. Sounds like a fairly common problem. I’ll have to see if I can inspect and clear any blockages I find.
Offline Milvus
« Reply #9 on: December 19, 2020, 07:10 AM »
I agree with above comments. I have both bs75 and bs105 and dust collection is far worse than that of a Rotex.
Not bad idea to open it to look for obstructions, but be aware: main parts of the body are sealed by means of silicone caulking, no with a gasket. If you open it you will have to remove all caulking, renew it and wait for it to dry.
Regards.
Offline Alex
« Reply #10 on: December 19, 2020, 07:37 AM »
Caulking in a powertool? Remarkeable.
Offline hoedma
« Reply #11 on: February 12, 2021, 07:28 AM »
Dust collection on my BS75 was not very good, so today I checked the dust channel. Not very good was a bit of an understatement, it was completely clogged. So, I would advise you to just open it up and check the dust channel.
327547-0
(TS55, Midi, RTS400, LR32, OF1010, CS50, RO150)
