Author Topic: Bpc 15v won’t charge properly  (Read 1497 times)
Offline Chris161190
« on: March 14, 2019, 04:51 PM »
Hi all,
Quick question, I have a 15v bpc battery pack which when plugged in to charge shows full after about 30 seconds. It isn’t full as when plugged into the tool,the indicator light only shows 1 out of 3 bars...
Any suggestions what to try or is it likely a dead duck? I do have two of these battery packs and swapped the chips from one battery to the other to check, but has done nothing. Volt meter across the terminals prove anything?
Chris
Offline Untidy Shop
Re: Bpc 15v won’t charge properly
« Reply #1 on: March 14, 2019, 05:02 PM »
Try wriggling the battery when first inserted in charger. On mine the terminals do not always align even though the battery looks to be fully inserted.
