Author Topic: UJK Parf Guide System - Videos  (Read 204864 times)
Offline DB10
Re: UJK Parf Guide System - Videos
« Reply #30 on: March 16, 2016, 07:17 AM »
Hi Peter,
              Thanks for the video demo. I'll be visiting the UK next month and thought this would be a great item to bring back to Australia with me. I spoke with a nice lady at Axminster today and she said these items are proving to be very popular so I'm on backorder. Lets hope the factory in Axminster will be burning some midnight oil and ramping up production. I'm looking forward to receiving this. thanks again.
Offline Richard/RMW
« Reply #31 on: March 16, 2016, 08:15 AM »
I volunteered to be the test case in NA, the system accepted the order but note that they have to "quote" shipping.
I recall having this happen on a previous Axminster order, so I expect to receive an email with the shipping quote, from which I have a link to complete the order. Pretty nice system, customer friendly.
RMW
PS - Peter, excellent design. It is no small matter to overcome all the design challenges and end up with a viable product that can be mass produced and marketed for a reasonable price. Kudos to you!
Offline Peter Parfitt
  • Magazine/Blog Author
« Reply #32 on: March 16, 2016, 08:42 AM »
RMW
Hi Richard,
That is a brilliant idea to describe the North American ordering process - it will help a lot of people. I am sure that once things settle down there will be a friendly NA stockist or stockists that will make life much easier.
It has been a really interesting and educational process taking the PGS from a germ of an idea with wooden mock-ups to the final product. I have to say that the clever people at Axminster did make sure that finished design was viable in terms of both  manufacturing process and final cost. My final AutoCAD drawing would have taken twice the machining, twice the raw material and hence twice the cost but you could at least have used it as a weapon of mass destruction !
I realise I might be expected to say this but the PGS does truly deliver near CNC accuracy. I have some timings as well - to drill the 3 mm holes at the start of the process takes an average of 20 seconds each and then the boring of the 20 mm holes takes 15 seconds (yes less time) each. I can now do it faster than that but I have been doing it a lot recently. A chap just doing the odd slab from time to time should be able to achieve those figures.
On the subject of timing - someone said to me that he could use the PGS to do a complete new bench top in less time that it would take him to drive to the local CNC workshop.
Cheers.
Offline tms0425
« Reply #33 on: March 16, 2016, 09:36 AM »
I emailed Axminster last night and had an email already this morning asking for shipping info to the US. I provided the info, exchanged a couple more emails, completed the order, and paid via Paypal as requested. I found they were very efficient :)
I already have a variety of bench dogs - Precision, Qwas, RipDogs, but no Parfs yet. I decided to order a small set of Parf Dogs from Lee Valley, just in case, so that I was using the entire system as designed.
I'm just at the point of outfitting a new shop and building all the work benches, so this timing is perfect.
« Reply #34 on: March 16, 2016, 12:04 PM »
Well done Axminster for being on the ball, especially with the export orders.
Good luck with the new workshop.
Offline Chris Perren
« Reply #35 on: March 16, 2016, 02:05 PM »
Really cool design -  Will the 20 mm bit be offered as a replaceable item by Axminster.  From the video, this bit appears to be custom sized to fit the jig.  I'm assuming after a hundred holes it may need to be replaced.  Thanks
« Last Edit: March 16, 2016, 02:29 PM by ByoBuzz »
« Reply #36 on: March 16, 2016, 02:57 PM »
Really cool design -  Will the 20 mm bit be offered as a replaceable item by Axminster.  From the video, this bit appears to be custom sized to fix the jig.  I'm assuming after a hundred holes it may need to be replaced.  Thanks
All of the components will eventually be available as individual replacement parts. The only ordinary item is the 3 mm drill bit and you can replace that easily enough without any fuss.
I have used my system (lets call it PGS One) to provide photographs for Axminster (about 140 holes cut in ordinary MDF). I have then made my 3 videos - about another 100 holes. I have not made a video of this (but you may see clips of it in my first 3 videos) where I make a 77 hole custom bench top (11x7). On Tuesday I had a visit from an amateur wood worker and we did about 55 holes whilst he was here. On top of all of that I have had some practice goes to check timings for the production of holes. I estimate that I am now over the 400 mark with PGS One.
The 20 mm cutter is a fine piece of precision engineering and not a cheap import. It is so important to the overall success of the PGS that a lot of thought (not mine - but clever chaps at Axminster) has gone into it. I understand that the grinding angles, lapping and so on (or whatever terms should be used - not my area of expertise) are all designed to make the cutter very efficient at removing waste. It certainly does not get hot and just keeps going.
One thing to watch for when you get your PGS. Like many Forstner style cutters, one often gets a disc of material stuck on the end after doing a cut - I have shown this in one of the videos (probably Part 2 of the detailed work). It is there because of the scoring cutting flanging widgity things that help create the near zero breakout. Just make sure that you pull this off before the start of the next cut otherwise it behaves like a washer and nothing happens when you try to do a cut.
I will be releasing a video soon showing the most recent cuts and they are all perfect. There is no breakout on the underside and the sides are very clean. I have a number of videos up my sleeve and they will all use PGS One. I will say if I need to replace the cutter and I will keep everyone informed of any wear and tear.
« Reply #37 on: March 16, 2016, 03:14 PM »
Thanks Peter - Are there any plans to bring PGS One to a US store.   Or is it an exclusive item for Axminster Only?  I'm happy to order it through Axminster although if I can save few dollars in shipping costs then I would prefer to wait until a US store stocks it.  Thanks for the reply.
« Reply #38 on: March 16, 2016, 03:17 PM »
I am sure that there will be a North American distributor soon. This is not something I am involved with. In the meantime I am advising people to order direct. I have no timings of any changes I am afraid.
Offline Shane Holland
  • Festool Dealer
« Reply #39 on: March 16, 2016, 04:06 PM »
Guys, we are working to be able to offer this product in the U.S. market. I will keep you posted as more information becomes available. Thanks.
Shane
877-866-5688
Offline DiscoStu
« Reply #40 on: March 16, 2016, 04:58 PM »
I was just going to post the video on here but I find you lot already know.
Looks good Peter. I've posted it on the UK workshop forum.
Brilliant - well done. I am not a member of that forum and cannot take on another commitment like that so if there are any questions please get them referred to me either through YouTube or here.
Many thanks for your initiative.
Peter,
The only questions I'm seeing are "when will it be in stock" I don't know if anyone has been given an idea?
« Reply #41 on: March 16, 2016, 05:09 PM »
If only I knew the complexity of warehousing computer systems - Amazon drives me mad at times....
The PGS components are in the warehouse and being packed. I suspect that something silly like the instruction manual is waiting to be put in the carton and so "computer says no".
The PGS is available for order - just click the "Backorder" box and you can go through to the checkout. The items are in stock and a large number of orders have been taken this way.
Offline jafenske
« Reply #42 on: March 16, 2016, 08:58 PM »
I just ordered my kit. Shipping to the USA. Axminster was really easy to order from. Used Paypal. I'm excited to use it.
Offline thylaxene
« Reply #43 on: March 16, 2016, 09:01 PM »
This might as well be my first post here. Hi all!
Thanks Peter for this great new product. Perfect timing was about to drill holes in my new bench. So using Axminster's export email I sent them my address here in AU and within a few hours got replay with direct paypal link. This is how online ordering for international buyers should be done! Very easy and very reasonable shipping rates. Unlike some of the postage rates in the US... *cough* Woodpeckers.
Again thank you Peter for the effort that has gone into this. And thank you for your youtube channel! Without which I wouldn't have had the nerve to spend big on Festool! ;)
Cheers, Jon.
« Reply #44 on: March 17, 2016, 02:00 AM »
Cheers, Jon.
Hi Jon
Welcome to the FOG and what an excellent first post - thank you.
I have done most of my work towards the Parf Guide System and now it is in Axminster's hands to make it, market it and sell it. I think all of that seems to be going jolly well and the initial uptake has (happily) taken us all by surprise.
I am glad the overseas ordering is working so smoothly.
Cheers.
Offline Untidy Shop
« Reply #45 on: March 17, 2016, 02:05 AM »
Cheers, Jon.
 [welcome]
Welcome to the FOG Jon. I assume from your Avatar that you live in Tasmania?
@thylaxene
Offline Kev
« Reply #46 on: March 17, 2016, 07:08 AM »
Dare I say "parfect" ? [embarassed]
Nice one Peter.
Offline thylaxene
« Reply #47 on: March 17, 2016, 07:35 AM »
[welcome]
@thylaxene
Thanks! Yep ex-Tassie boy now living in Melbourne.
Offline Kev
« Reply #48 on: March 17, 2016, 07:42 AM »
Cheers, Jon.
 [welcome] Jon
You've gotta love some of those shipping rates .. massively inconsistent. I remember enquiring about a guitar a few years back and the quoted shipping from the US was more expensive than a return flight to pick it up [eek] needless to say, I went elsewhere!
Please let us know how you go with the "parfomatic", I may get one too!
Offline Richard/RMW
« Reply #49 on: March 17, 2016, 08:55 AM »
Just received Axminster's email as I was reviewing this thread, and placed the order. £109.30 including shipping to the US.
Brilliant!
RMW
« Reply #50 on: March 17, 2016, 10:56 AM »
Brilliant!
RMW
Gosh, that is a excellent.
Every time I get anything from the US I have to pay the duty but then, on top of that, our Royal Mail, who handle the tax collection for our revenue service, charge a further £8 per package.
Good luck.
I wonder who in North America will be the first to post a video of their first custom bench top ????
« Reply #51 on: March 17, 2016, 01:50 PM »
Hi Everyone
I have just uploaded a video where I film a novice woodworker using the PGS. His name is John Caswell and he is a thoroughly nice guy whom I met at Peter Sefton's open day last year. He was not paid to come to my workshop and did not receive any incentive at all. He was not aware that I was going to give him a set of Veritas Parf Dogs and associated Small Bench Dogs at the end of the filming.
Although the editing makes it skip along at a reasonable pace I have not hidden any disasters or complications. I did not do any of the work other than advising him where to start the first hole and explain how the PGS should be used.
You could not see daylight when he put the 12" engineer's square on the finished work.
It is silly of me not to ask him, but I will shortly, whether he is a FOGger. He has some Festool kit.
Anyway, here is the link:
Offline joiner1970
« Reply #52 on: March 17, 2016, 02:15 PM »
John did a very good job Peter. You didn't need a pro ;)
« Reply #53 on: March 17, 2016, 02:40 PM »
I am still looking for a professional woodworker to create his or her own track saw cutting station.
I may have to invite someone in from abroad !
Offline jcaswell
« Reply #54 on: March 17, 2016, 03:58 PM »
As the novice referred to by Peter, i am a member of FOG, and the process was as straightforward as it looks. I have a system on order as well, to make a larger portable top for cutting sheet goods.
It is great to be able to make tailor-made surfaces with holes only where you need them
I may have to get the Festool drill with the detachable chuck  ;-)
Offline skinee
« Reply #55 on: March 17, 2016, 04:59 PM »
Peter I have a question/concern,it appears from the videos that the 3mm drill guide only rides on top of the holey rule rather than positively inserting into the holes and acting like a hardened guide bush,is that the case?,if so I would be concerned that with repeated use the 3mm drill bit will wear and enlarge the holes on the rule thereby throwing off the accuracy of the whole system,perhaps a larger hole in the rule in which a hardened guide bush could locate would avoid this problem
« Reply #56 on: March 17, 2016, 05:06 PM »
The steel rule is hardened steel and needs a hugely expensive drill to cut it on the CNC. The very slight abrasive action of a relatively soft 3 mm drill is unlikely to cause any problems. Next time you go to your workshop try cutting a hole in one of your steel rules.    Peter
Offline Richard/RMW
« Reply #57 on: March 17, 2016, 05:10 PM »
@skinee - had that same thought when I saw what looked like a tiny bit of wear in the Pt. 1 video:
Might have to drill a bazillion holes before it ever affected anything.
If the hole in the Parf sticks was (for example) 8mm, and both the drill guide and pins were stepped with an 8mm protrusion around a 3mm hole, it would probably overcome any issues over the long term.  If there are any issues.  [scratch chin]
Perhaps V2.0?
RMW
Offline bobfog
« Reply #58 on: March 17, 2016, 05:12 PM »
I suppose if one was really concerned about the drill being in contact with the rule, they could use a hinge drill used for centring pilot holes in doors/frames.
« Reply #59 on: March 17, 2016, 05:20 PM »
Hi Richard,
You have an interesting idea but it may not be necessary. The final prototype Parf Sticks show the same marks and have been used for so many holes that I could not even guess. I think it might be a pattern due to heat caused by MDF clogging of the 3mm drill. You may have noticed in the videos the higher pitch squeak when I do the 3 mm drilling - that is due to some minor MDF clogging of the small drill. The drill does get warm as one would expect.
