Author Topic: RTS Engineering 8-Foot Articulated Boom Arm  (Read 16750 times)
Offline RJNeal
Re: RTS Engineering 8-Foot Articulated Boom Arm
« Reply #60 on: July 10, 2019, 07:50 AM »
Congratulations Rick on your new product. Looks great.
I would order one up in a heart beat if I still had a shop.
I moved a year and half ago. My shop consists of a 20’ container for storage.
Rick.
Offline jdm5
« Reply #61 on: July 10, 2019, 07:55 AM »
Likely in for one and possibly even two depending on mounting options!
Drank the green Kool-Aid...gave up counting long ago.
Offline Rick Christopherson
    • http://www.rts-engineering.com/
« Reply #62 on: July 10, 2019, 08:06 AM »
I've done the calculations, and the mounting requirements are way lower that I originally expected. That's because I based my original assumptions on the huge white elephant that Festool offers that weighs over 200 pounds. Theirs could never be mounted to a wooden wall...mine can. It only weighs 30 pounds (calculated). I think a couple of brackets and sistering some studs, is probably about all anyone my need. (of course, you must consult a structural engineer to ensure your installation is safe.)
The forces on the wall are pretty typical, but I need to double check them before publishing any numbers.
Online RKA
« Reply #63 on: July 10, 2019, 12:54 PM »
Wow, that's really awesome (and light)!!  Love the name!
-Raj
Offline zapdafish
« Reply #64 on: July 10, 2019, 01:31 PM »
Will you have a version that doesn't articulate?
Offline jellyroll
« Reply #65 on: July 10, 2019, 02:57 PM »
Rick,
I’m interested for the shop I’m redesigning for our local theater where I join a group of volunteers building the sets. As a retired mechanical engineer... kudos for following good engineering design principles and for design elegance. Long term, it might be interesting to have an option of a vertical member on the wall to spread the load and if it had a “track”, to allow for height adjustment.
« Reply #66 on: July 10, 2019, 04:59 PM »
I don't anticipate doing that, because without the articulation, you are no better off than buying a Festool vac-mounted boom arm with its limited reach of just a couple of feet. The articulation gives you the ability to cover EVERYTHING from zero to 8-feet. If it was fixed-length, you'd be stuck with a single radius. Prometheus will permit you to have infinite positioning from zero to 8-foot radius.
« Reply #67 on: July 12, 2019, 12:58 AM »
The website is finally active for taking your orders for the Prometheus articulated vacuum boom arm.
The articulated boom arm uses a 2-tube design, giving you dust extraction through the upper tube, and any number of other energy types through the lower tube, such as electrical power, compressed air, VacSys vacuum air, etc.
The boom arm is available in lengths of 6, 8, and 10 feet.
Oh, I forgot to mention.....
Free Shipping for introductory purchases. Limited Time offer.
« Last Edit: July 12, 2019, 01:13 AM by Rick Christopherson »
Offline Richard/RMW
« Reply #68 on: July 12, 2019, 08:29 AM »
@Rick Christopherson looks awesome!
In my use case the 10'er could be used to deliver "beer energy" from a tap out to the smoker... now if I can only figure out a project to justify that tool purchase to the boss. [scratch chin]
Best of luck with this, looks like you have a real winner here.
RMW
Offline zapdafish
« Reply #69 on: July 12, 2019, 11:01 AM »
Ah, ok, figured there was something I didn't understand.
« Reply #70 on: July 12, 2019, 11:56 AM »
I’d like to see a picture of the contiguous path of the vacuum hose from vac to tool.
« Reply #71 on: July 12, 2019, 12:11 PM »
Not sure what you're expecting to see with a "contiguous" picture, but the flexible hose in the main knuckle is high-grade rubber, wire reinforced hose. This is far more flexible (and expensive) than a plastic hose.
I don't cut corners on materials!
Oh, both upper and lower tubes are connected by this hose, even though the upper tube is the only one needing a vacuum seal. Your wires and hoses are not exposed when they pass through the main knuckle joint. (is that what you were wondering?)
« Last Edit: July 12, 2019, 12:14 PM by Rick Christopherson »
Offline broseiden
« Reply #72 on: July 12, 2019, 12:14 PM »
Looks like a wonderful solution. I've toyed with a couple different shop-built boom arm designs, but they've all been lacking... I'd like to order an 8 or 10 footer in the not-too-distant future. Any idea what shipping to Canada would cost? (I can contact you privately if preferred, just thinking others may be interested as well)
« Reply #73 on: July 12, 2019, 12:20 PM »
Full Blown Motorsports is graciously allowing me to shirttail on their UPS shipping rates. (They do a very high volume of shipping, so their rates are very low.) I'll know better once we start shipping. That's the reason why I am giving free shipping on initial orders.
Offline broseiden
« Reply #74 on: July 12, 2019, 12:22 PM »
Nice! Thanks Rick.
« Reply #75 on: July 12, 2019, 12:30 PM »
(Attachment Link)
(Attachment Link)
That helps! Also, I failed to notice the elbow hidden in the mount pivot.
I prefer the dust/debris stream to pass from a hose/pipe into a larger hose pipe as it flows to the vacuum. In this case the hose from the tool would fit into Prometheus’s snout and the hose from the vac would fit over the elbow in the wall pivot. So unless the hose ends differ the elbow diameters should differ (in my ideal world).
Offline James Biddle
« Reply #76 on: July 12, 2019, 12:47 PM »
Rick, can you show a pic with the vacuum hoses attached and a few other services in the other tube?  It's probably the angle of the pic you have, but it looks like an air hose would be kinked by the vacuum hose elbow.
« Reply #77 on: July 12, 2019, 01:02 PM »
This might answer both of your questions. Here is the actual elbow that is used for both supply and tool drop-down connections. The bead gets cut off on the side that gets welded into the aluminum tube. However, that bead is what permits a Festool suction hose to be clamped on the other end, very securely.
It is just dumb-luck, but this is an elbow that my welder keeps in high volume, and it fits perfectly for what I needed. Literally, the whole design was based around this elbow.
No, your hoses will not be kinked under the elbow. That is something that I was VERY aware of from the beginning, because Festool's ASA5000 boom arm had less space under the elbow than I do. That is exactly why I based the whole design around this particular elbow.
Online JimH2
« Reply #78 on: July 12, 2019, 01:09 PM »
Well done effort on this whole project and a big thanks to Full Blown for assisting.
« Reply #79 on: July 12, 2019, 01:40 PM »
Full Blown just left, after dropping off the load of aluminum stock. We decided to drop it at my shop, because Kapex will cut it faster than their metal-cutting band saw. 24-foot long sticks. I'll be a little busy this weekend. We'll start the mad welding on Monday.
« Reply #80 on: July 12, 2019, 01:53 PM »
Hey, by the way, I'll be cutting these to length this weekend based on what has already been ordered this morning (first come first weld). So anyone that is planning to place an order before Monday, If you could drop me a note (or post here) which size you plan to get, that would help me plan which cuts to make first.
Of course I will be cutting extras, but I am still getting a feel for which sizes are more popular.
« Reply #81 on: July 16, 2019, 06:44 PM »
I spent the day at the welding shop (Full Blown Motorsports) showing them how to jig-up the parts for welding, and where/how I wanted everything welded. It was a gazillion degrees in their shop today, so I'm a bit knackered out. I'll try to post more later on.
In the mean time, I decided to snap some pictures of the incredible welding these guys can pull off, before I cover all that beauty with paint. (I already painted the main boom. This is the jib boom for the first 10-foot boom arm.) Ayup, the welds were smooth enough that I was totally comfortable laying it down on my truck's tonneau cover to take pictures.
« Reply #82 on: July 18, 2019, 01:26 AM »
Well, I got the first 10-foot boom arm assembled. Everything has come out as expected. There's just a few other parts I need before I can begin shipping them out.
Offline Richard/RMW
« Reply #83 on: July 19, 2019, 09:07 AM »
Very nice!
No matter how hard I try I cannot manufacture come up with a reason to justify the, ahem, "need" for one in my shop. Dammit.
RMW
(Attachment Link)
« Reply #84 on: July 19, 2019, 11:32 AM »
Very nice!
RMW
Richard, it's not the need, but the joy!
Offline rst
« Reply #85 on: July 19, 2019, 12:05 PM »
Since when has need been associated with Festool.
Offline Richard/RMW
« Reply #86 on: July 19, 2019, 01:31 PM »
"Need" is related to the story justifying the expense to SHMBO.
Bunch'a rookies....  [poke]
RMW
Offline sprior
« Reply #87 on: July 19, 2019, 02:31 PM »
Very nice!
RMW
Expenses related to cleanliness/dust control have an express approval process with SWMBO at my house, and are you sure there isn't a safety aspect to this as well?
Offline Bob D.
« Reply #88 on: July 19, 2019, 10:31 PM »
The safety angle could be it removes trip hazards from the floor like hoses and cords.
And that's the truth.
Online DynaGlide
« Reply #89 on: July 20, 2019, 06:02 AM »
Slippery slope playing the safety angle. If you're too clumsy to step over some cords what else are you too clumsy to be around? Might find you're talking yourself out of being in your shop altogether. Gotta be careful with the approach argument.
Instagram @matts.garage
