My fence arrived last Wednesday, wrapped in a festive moose design.
I was very excited and decided I would install it that day, because I had to install baseboard on Thursday, and I could test it out right away.
It felt quite substantial, especially after feeling the original part, so I went to grab the kitchenscale and check the weigths. (518g for the festool vs 1251g for the colliflower fence)
I noticed the stop bolts for preventing the sliding fences to detach work differently, on the standard fence you need to screw the little bolts all the way down, so the tab on the fences clear them, on the colliflower fence, you need to unscrew them a bit, so the tab clears them underneath the head.
I was a bit in a rush, and the circumstances at the time of the transplant weren’t ideal. (my temporary “shop” is a huge mess, and I didn’t have the most stable flat surface I should have)
The sliding fences wouldn’t slide easily onto the new fence, but after I loosened the bolt for the fenceclamp and making sure there wasn’t any debris in the channels with a few cottonswabs, and the application of some lube I got them on, and dial the bolts back so the fenceclamp would apply enough pressure to keep the fence from sliding.
I made a few cuts and the miters didn’t turn out great, which was caused by the sliding fences tilting to the back.
My kapex is an early version (2007) and one of the issues the saws had back then was that the sliding fences could get stuck, which happened to my saw when it was still in warranty, and I sent it in for a repair.
I did check ekat if the partnumbers for the slidingfences had changed over the change in partnumbers for the saw, but that doesn’t seem the case.
I think it will work if I order them new. (maybe they have done some machining on the fence and/or the sliding fences as part of the repair).
Since I needed my saw the next morning I reinstalled the original fence; and decided that I will order a new set of sliding fences, and try it again after my saw has been sent back for the safety issue repair.
By then I also have a bit more space, and I 'll have a bunch of extra cubes at the ready to play with. (if the cube isn't square, and you turn it around for making a bevel cut for example, it won't be flush with the fence, or you would have to dial in the setscrews everytime you flip it)
I was a bit dissapointed I couldn't use it straight away, but I am looking forward to have it up and running next month.
