When talking narrow rips, do I assume that means rips narrower than the width of the rail? Tom's video showed a rip on a narrow piece to put a good starting edge on it, but never showed cutting to a specific width. Looking at this video from Peter Millard, he's showing a home-made guide, quickly made to cut a specific width on the "waste" side of the rail; has anyone looked at something similar but adjustable for different widths? I would think that a t-track with scale and a movable stop could be used, with a sliding stop for calibration similar to that on the TPG
As much as possible, I try to do all the ripping first, and then all I have to do is cross-cut to length as needed. I have made rips as narrow as 1-1/2" with the EZ UEG and as wide as 24" (about the capacity). This works for me given my workspace limitations - and the fact that I don't have a long rail (and would have trouble finding a place to store it if I did.
After ripping, the strips are cut to length as needed - this would be my basic used for the TPG when it's available, to give me repeatable lengths. I normally do the cross-cutting on the collapsible grid (and have also used that as an assembly table too).
If I need to adjust the width on a part later, I'd use the Rip Dogs parallel guide. I think someone posted the idea of using a single arm of the parallel guide, in conjunction with the GRS-16, something that I had been considering as it would already be calibrated to my rail, but it looks as if the TPG might be a little more user-friendly.
