Author Topic: NEW TSO TPG-30 Parallel Guide  (Read 56396 times)
Offline DynaGlide
« Reply #60 on: January 23, 2019, 02:44 PM »
@TSO Products So I'm looking at this system and wondering. .probably too late for a design change or if it's even do-able, but how great would it be if it doubled as a fence for the MFT with flip stops when used on the GRS PE mounted to the hinge? As it is now, the parallel edge guide would be in the way of the material being cut going up against the GRS-16 PE. I'm sure I'm not alone in wanting this. It would solve a lot of problems.
Edit: Looking at it more it seems with a simple different flip stop accessory you could use it for this purpose. The material would butt up against the T-track of the parallel guide instead of against the GRS-16 PE. The only downside would be the material would not be supported underneath the guide rail as is the case with the Festool fence. However there are people using Incra or 8020 fences on their MFT's that also have this limitation.
« Last Edit: January 23, 2019, 02:51 PM by DynaGlide »
Instagram @matts.garage
Offline Roachmill
« Reply #61 on: January 23, 2019, 02:44 PM »
That's great to hear. I've emailed about the insider email so hopefully there's something about it in there. Sounds like a costly option though... a tempting one nonetheless!
Offline tazprime38
« Reply #62 on: January 23, 2019, 05:52 PM »
  @tomp @ChuckM @tjbnwi @RobBob  @glass1 @lerabotperche  @Michael Kellough @Paul G
TPG-50 coming! – we hear you [big grin]
We will make a 50 inch cutting T-Track width version available as a stand-alone SKU for those who need it. Thanks for the examples you had in mind: "Refrigerator cabinet".
We’re producing the extrusions in heat-treated 20 ft + length before all the secondary operations. So the lengths we offer are limited only by practical commerce considerations such as shipping cost – just like the extra long guide rails which need to $hip by LTL truck line. For everyday needs it pays  to keep things under 48 inch max. shipping length to avoid UPS/FedEx length surcharges kicking in at that point. Beyond that: whatever you’re willing to pay for.
Don’t laugh: one of our BETA Testers, Duane H., early on needed a super length track for cross-cutting-to-matched-length paneling boards for a high-end auto dealership interior. The GRS-16 helped him get perfect square and equal length cross cuts. So yes, there are extremes which can, on some projects, justify extreme tools. We will keep a few full length 20 ft extrusions back for just such one-off requirements – seriously, only at TSO  [smile]
Hans
PS: look for another Post addressing Narrow Stock questions
Hans,
When I had the festool Parallel guides including extensions, I was able to cut just over 900mm capacity by flipping the extensions over and connecting them to the ends of the parallel guides. I would use this set up to cut 900mm lengths of boards ie for shelving etc. I would have used them to cut the side panels for long boxes if I had the extra capacity.
Would it not be possible to join shorter lengths of the extrusions together to give us the extra capacity?
Tariq
Offline tomp
« Reply #63 on: January 23, 2019, 09:18 PM »
Pretty sure I have a 51" cut capable as a prototype.
Tom,
Do you find that the set-up for the 51" cut is a little cumbersome, moving the track with the guide attached between cyts? I made one for the Track I was using before I "found" Festool, and it is awkward picking it up off and handling it between cuts, particularly in a small shop like mine. The intent of the longer arm was to allow cutting base cabinet ends - so 34-1/2" capacity would be what I need and I may cut it down to limit that. That particular extrusion can be extended using a connector between the sections so that may be an option if I need more capacity.
The track shown in the photo is from EurekaZone, and I use their UEG for ripping sheets to width - have ripped as narrow as 1-1/2" and commonly up to 23-1/2" for base cabinet ends. I took the Basic Festool course from Greg Paolini; the Festool parallel guide was one of the tools that we were taught to use, but I was honestly not impressed and thought that the UEG was much simpler and easier to use.
It may be that the 30" cut length is enough for a good percentage of the jobs I do, but 36" shelf lengths are pretty common so that would be a problem. I've looked at the home-made parallel guides made by Dan Pattison, and had the idea that one of these guides, combined with the GRS might be an idea for getting consistent, repeatable cut length - clamp the guide to the sheet, butt the LH edge of the track to the guide and the square against the edge of the sheet. You would have to remove and reposition the guide for each cut, but wouldn't have to handle the track with the guide attached each time.
Offline tjbnwi
  • Cedar Tucky Indiana
« Reply #64 on: January 23, 2019, 09:56 PM »
@tomp, it comes off and on the rail so easily I just pop it off and pop it back on. Faster than struggling with it.
Offline tjbnwi
« Reply #65 on: January 23, 2019, 10:08 PM »
The TPG 48 in the wild......
These are prototypes, thus the difference in color and various hardware.
I use the Gecko on all pre-finished material.
Offline Pnw painter
« Reply #66 on: January 24, 2019, 12:52 AM »
Using the gecko on pre-finished materials is a great idea Tom. Recently, I was using pre-finish ply for some drawers and was having issues with the track slipping while I was cutting.
Offline tjbnwi
« Reply #67 on: January 24, 2019, 08:12 AM »
@Pnw painter,
One thing I have done to make the process easier is I've removed the bolts and nuts that retain the Gecko to the rail. This allows me to just drop the Gecko in place and lift it off easily.
Offline tomp
« Reply #68 on: January 24, 2019, 09:22 AM »
Thanks for the info, guess I'm going to give it a try.
Offline Mike Goetzke
« Reply #69 on: January 24, 2019, 09:45 AM »
I'm a recent owner of the GRS-16 PE. I also purchased a used (but looked unused) Woodpeck PGS. Then couple weeks later the TPG is announced  :-\.
I tossed a few ideas at another FOG member Peter_C. I had noticed along with the two threaded holes on the leading/trailing edge of the GRS there were also two 1/4" through holes. Since WP PGS uses a three track extrusion (two on top one on the bottom) it is very simple to attach it to the GRS with a couple of "T" nuts and thumb screws. When required you can additionally use the standard WP arm assembly at the far end for long cuts. Even a very inexpensive Incra dual track works, but, the WP PGS has laser etched rule and can be easily calibrated on the GRS.
The TSO TPS seems to have the advantage of more secure attachment and is one piece but for even a serious hobbyist that already has the WP PGS this may prove to be a great solution.
When I built many cabinets for our kitchen remodel several years ago I purchased a WP story stick system. So I have one piece extrusions of 24" and 48" available to play with.
Mike
« Reply #70 on: January 24, 2019, 09:54 AM »
Hey Tom, just to be clear, so you clamp the TSO end to the ply and then place the Gecko on the far end?
I notice there are 2 Geckos in the photo.
Offline tjbnwi
« Reply #71 on: January 24, 2019, 06:26 PM »
With the GRS and the TPG on the entry end I find th rail does not drift. I use the Gecko on the "free" end because it will drift.
I have 6 Gecko’s, booth 4 of them from a member here who was liquidating.
Offline TSO Products
    • TSO Products
« Reply #72 on: January 24, 2019, 10:19 PM »
@DynaGlide -  Months ago we used a prototype (anodized blue) TPG-30 and attached it to a GRS-16 PE which was already connected to the MFT/3 Hinge Plate and had the 1080 Guide Rail locked onto it.
A real simple way for repeated crosscuts on the MFT/3 and no longer worrying about keeping anything squared up.
        simple, quick and repeatably accurate: TSO
Thanks for raising the question.
Hans
PS: unable to get the jpg attached with three tries
TSOproducts.com
Offline dlu
« Reply #73 on: January 25, 2019, 03:10 AM »
Anyone got their TSO Insider with info? Patiently waiting :)
Not yet (west coast of the US, so I was expecting to be late to the party, but not this late :-)
    • TSO Products
« Reply #74 on: January 25, 2019, 10:05 AM »
@DynaGlide - found out the picture file I was trying to download was too large for the FOG to accept:
here is my earlier response this time with picture:
Hans
TSOproducts.com
Offline DynaGlide
« Reply #75 on: January 25, 2019, 11:51 AM »
So is the scale automatically calibrated to the edge of the guide rails clear strip? This is a great solution.
Offline ChuckM
« Reply #76 on: January 25, 2019, 11:54 AM »
This so-called insider thing is not working. I am not an insider subscriber, but if the intention of the insider mailing is to excite and please subscribers or potential customers, it fails. Instead, it seems to be frustrating or irritating some of those who are insiders.
The system needs to be looked at and fixed. West coast, east coast, if it mattered, should mean delays of hours, not days (I can't imagine the insider mailing list has 100,000 addresses on it). It is an unnecessary distraction when TSO is trying to release a new product.
« Reply #77 on: January 25, 2019, 12:05 PM »
Looks like you need to calibrate this system like others. You can see a bolt in the flip stop - this must need adjustment.
Offline Roachmill
« Reply #78 on: January 25, 2019, 12:49 PM »
FWIW, I've emailed the info@ address with the subject line above and heard nothing other than an automated acknowledgment of the email. Nothing in spam folder either :(
I'm pretty sure I've signed up tonks ago and never had anything so just assumed they were like hen's teeth. But this time I'm all ears.
Offline grobkuschelig
« Reply #79 on: January 25, 2019, 02:13 PM »
Same here...
Offline DynaGlide
« Reply #80 on: January 25, 2019, 02:42 PM »
That's clever. Easy way to adjust for slight variance between different guide rails. This thing is looking pretty tempting to get rid of the MFT fence once and for all.
Offline tjbnwi
« Reply #81 on: January 25, 2019, 03:18 PM »
You have to calibrate the TPG. There is not enough variation between my rails to bother calibrating for each rail.
You calibrate to the saw kerf, doing this allows a higher degree of accuracy. How many here have perfect splinter strips on their rails?
Offline lerabotperche
    • What I do and how I do it :)
« Reply #82 on: January 25, 2019, 03:47 PM »
someone got the last TSO insider ?  [huh] I've made the request to get it but no news  [sad]
« Reply #83 on: January 25, 2019, 04:20 PM »
What do you adjust? Just the stop block?
Offline neilc
« Reply #84 on: January 25, 2019, 06:25 PM »
TSO email is attached for those that did not receive it...
It's about 3mb  in size so give it a minute to open/download.
« Last Edit: January 25, 2019, 06:34 PM by neilc »
Offline tjbnwi
« Reply #85 on: January 25, 2019, 06:29 PM »
@Michael Kellough,
Look at the picture TSO posted with the GRS PE on the MFT (reply #74). You’ll see a silver pin contacting the work piece. That is the calibration pin.
« Reply #86 on: January 26, 2019, 03:40 AM »
[thanks]
    • TSO Products
« Reply #87 on: January 26, 2019, 12:31 PM »
link to  TSO INSIDER Archive including TPG Parallel Guide:
       https://us14.campaign-archive.com/home/?u=a153fd474bc42913d95001814&id=1b1e11f7db
All the information we have published so far can be seen via this link.
Resolving the MailChimp emailing issues will take time.
We will post a REPLY on this FOG thread when we have more specific information and how to access it if it goes beyond what is appropriate for posting here.
thanks for your interest and patience!
Hans and especially Eric
(-who has been working behind the scenes dealing with these communication matters)
TSOproducts.com
Offline simonh
  • Hobbyist / Maker of the VCS-R
« Reply #88 on: January 26, 2019, 05:31 PM »
It would be quite nice if instead of multiple track lengths if the tracks were broken down to sections and then bolted together like the Woodpecker parallel guide. Very easy to get the right length for any job and much easier for shipping internationally.
-Simon
    • TSO Products
« Reply #89 on: January 26, 2019, 10:53 PM »
@simonh – your comment is the perfect opportunity to talk about design goals and priorities. We start design with the realization that there will be trade-offs. In the case of the TPG System we ranked its ease of function and performance while in use* as the topmost criteria, outranking such other considerations as cost of shipping (within reason) and storage – for example.
*(while in use means the time from reaching for the tool when you realize it is needed until you return it to its normal resting place).
Based on user feedback we sought the most direct way to get from picking up the Parallel Guide tool to cutting. We targeted the elimination of
•   non-essential small parts
•   the infamous “some assembly required” and “disassembly required” with tools
•   risk of assembled elements becoming loose or out of adjustment or calibration
•   wasted time
The result is a product that, above all, is ready for Action and deactivation in seconds rather than minutes – and reactivation with razor sharp repeatable accuracy without loss of calibration – again in seconds not minutes.
For professional trades people time is money. For hobby woodworkers time is THE finite quantity – you can’t get any more and unlike money, you can’t earn anymore or borrow any more time. In fact none of us know how much we have left. So you can see how highly we rank expected performance .
Some will have different priorities and choose other solutions accordingly.
The TPG-20 LEFT- and RIGHT Hand elements will fit in a SYSTAINER with their GRS-16’s.
The TPG-30 can remain fully assembled with its FlipStop(s) and stored just like a larger T-Square or similar tool. This longer tool and its TPG-50 stable mate can also be slipped into the Storage- and Transport Bag we will introduce.
We expect over time quite a few woodworkers will have more than one TPG track and FlipStop Assembly set up for specific types of jobs. Just like GRS-16 PE’s are finding dedicated jobs in woodshops while its twin is used for various other jobs in order to save time and save set-ups.
Thank you for providing the opportunity to explain our design aims.
Keep the comments and questions coming.
Hans
TSOproducts.com
