Author Topic: NEW TSO TPG-30 Parallel Guide  (Read 55742 times)
Offline Roachmill
« Reply #1 on: January 15, 2019, 07:39 AM »
Thanks for that. I've been eager to see what they were going to come out with.
I can't see it being any use for ripping narrow stock unless they have something else up their sleeves. Besides, for narrow stock, you really want two reference points... and thus two GRS-16s and two TPG-30s (which makes the Woodpeckers version look "cheap"!).
Offline TSO Products
    • TSO Products
« Reply #2 on: January 15, 2019, 08:27 AM »
the link to the preview image shows one part of a larger "SYSTEM" designed to improve on existing solutions. Subscribers to our TSO INSIDER  (or sign up at https://tsoproducts.com ) will receive more detail as we near launch day. We will recap the points raised in various forum posts and address them in a comprehensive approach.
In the meantime we view all the comments and questions as helpful input to be able to effectively communicate with our base of customers and prospective customers as well.
thank you
Hans and Eric
TSOproducts.com
Offline lerabotperche
    • What I do and how I do it :)
« Reply #3 on: January 15, 2019, 09:13 AM »
Do you mean it works better as a system ?  [blink]
More seriously, will it be set in systainers or with something to put it outside of a systainer ? Will you do a promo pack with already « existing solutions » ?
Exciting news we have here :) Already on my way to ask my customer to send money asap  [big grin]  [wink]
Offline duburban
« Reply #4 on: January 15, 2019, 09:56 AM »
I just ordered one of your square cutting attachments and had thought of making the same jig for it.
helper: i used a festool "circular saw" to do something simple and it made it really hard
me: exactly, it makes simple cuts complicated and complicated cuts simple
« Reply #5 on: January 15, 2019, 10:41 AM »
Looks interesting. As an owner of the original GRS I’m looking forward to the solution for mounting the new product to the old.
Offline Jmacpherson
« Reply #6 on: January 15, 2019, 10:52 AM »
And there I thought I was going to behave myself when it came to tool shopping in 2019.....oh well my arm has been twisted
    • TSO Products
« Reply #7 on: January 15, 2019, 11:33 AM »
Michael - we are determined to develop a way for early adopters like you to be able to take advantage of later offerings like the TPG-30 in a most affordable way. No planned obsolescence at TSO [smile]
stay tuned
Hans
TSOproducts.com
« Reply #8 on: January 15, 2019, 11:42 AM »
I have the same issue Michael. My GRS-16 PE has 2 tapped holes while my GRS-16 has none.
I believe there was some conversation, maybe 9-12 months ago about producing a jig/kit for adding the tapped holes to earlier tools. It was a fixture that would be circulated to those that signed up and after you modified your tool, you'd send the kit off to the next participant on the list. At least that was the discussion at the time.
« Last Edit: January 15, 2019, 11:44 AM by Cheese »
Offline tazprime38
« Reply #9 on: January 15, 2019, 01:12 PM »
Hans
I may be mistaken but the flipstop looks like thst there may be some play in it when a board is butted to it?
Offline tomp
« Reply #10 on: January 15, 2019, 01:24 PM »
Hans,
It looks as if the extension track locates off the left side of the rib that locates the rail. If this is correct, is there some slight adjustment to the flip stop to compensate for minor differences in the blade location on the saw?  Also, I have one of what I think is one of the earlier GR-16 squares - only has two holes - and wonder if you could let me know the location of the two additional holes needed to accommodate the TPG-30 as it looks as if one hole may match but the missing hole may be pretty close to the other.
    • TSO Products
« Reply #11 on: January 15, 2019, 05:40 PM »
Hans
@tazprime38  - you must have "strong' eyes to be able to move that stop (in a picture) because I can't move the real thing by any means.
I know, - you're just testing us  [smile]
Hans
TSOproducts.com
Offline tjbnwi
  • Cedar Tucky Indiana
« Reply #12 on: January 15, 2019, 07:50 PM »
Hans
There is no play in the stop.
Offline tjbnwi
« Reply #13 on: January 15, 2019, 07:53 PM »
Hans,
The stop is adjustable to compensate for the variations. The TPG needs to be calibrated to your tools.
Offline tomp
« Reply #14 on: January 16, 2019, 10:29 AM »
Hans,
Tom,
Thanks for the information. Presumably this would be a one-time setting? My present set-up (non-Festool) has no positive stops, plus I disassemble after use because it's so cumbersome, so has to be calibrated each time.
The "fence is detachable, no scale because of the loose pivot where it attaches to the rail so basically has to be manually set to the required cut length - the required length is marked on the material, the cursor is used to set the rail to the line and the stop adjusted.
Offline tomp
« Reply #15 on: January 16, 2019, 10:31 AM »
Sorry, this photo of my present set-up didn't post for some reason.
Offline RobBob
« Reply #16 on: January 16, 2019, 11:20 AM »
Me too.
Offline tjbnwi
« Reply #17 on: January 16, 2019, 03:18 PM »
Hans,
Tom,
It is a one time calibration to your current tools unless you change the pin out for the narrow stock rod. At that time you would have to calibrate the narrow stock rods, then recalibrate when you install the pin.
If you plan on doing the above often I recommend 2 stops, calibrate each and be done with it.
We do rip 8’ sheets with a single arm, largest variation we’ve seen is 128th of an inch.
Full disclosure, I have been testing this system for over a year. Hans supplied me with all the pieces necessary to test the system then updated piece as changes were made.
Offline tazprime38
« Reply #18 on: January 16, 2019, 04:33 PM »
Hans,
Tom,
Tom, what are your impressions on this new parallel guide? How does it compare with the festool PG set or others that you may have tried?
Tariq
Offline tjbnwi
« Reply #19 on: January 16, 2019, 06:30 PM »
I own the Woodpecker and Seneca parallel guides.
The issue I had with the Woodpecker system was arm creep, you had to be aware that the segments would separate after repeated bumping of the material to set them in place. I also found the stop itself would creep.
The Seneca set I could never get calibrated 100%, most likely me.
I have used the Festool pg’s.  Never bought a set because they really never impressed me.
One of the really nice thing about TSO’s system is if you have a long arm on the rail or multiple stops you can unsnap the clamp on the GRS and slide the entire assembly off the rail.  Remove the cut piece, reposition for your next cut, slide the GRS on the rail, lock it in place, potion the assembly make the cut. This reads like a pain, but compared to moving a rail with a long arm on it this is a dream.
There won’t be any segment creep because there are no segments. The stop locks in place well. Scale and pointer are very easy to view.
This system is more accurate than my sliding table saw.
Offline tazprime38
« Reply #20 on: January 16, 2019, 06:54 PM »
Tom,
That is good to know. What about the Rod for narrow board cutting, is this well thought out and does it work well? What are the maximum and minimum cuts possible with these?
Tariq
Offline tjbnwi
« Reply #21 on: January 16, 2019, 07:06 PM »
Tom,
Tariq
For narrow rips I highly recommend 2 of everything. One set for the left side. There is not enough purchase on the GRS to make certain you are dead square.
Minimum cut is 0. The rod extends all the way to the saw blade. Max 51ish.
Offline simonh
  • Hobbyist / Maker of the VCS-R
« Reply #22 on: January 17, 2019, 04:48 AM »
I'm looking forward to seeing the final product in production.  Looks interesting.
That's pretty impressive.  Looks like you've got a pretty good guide rail coupled with the TSO square.
I read somewhere on FOG that Festool say that linearity tolerances for the 3m rails are 1.5mm... So 0.5mm per 1m is presumably their manufacturing tolerances. So, unfortunately not everyone is going to get perfect results depending on their individual rails. Likewise in setting up the MFT we have squares that are accurate to 0.0254mm (0.001" over there length) but if the rail is so slack on tolerances then a 4-cut square might not turn out perfect.
-Simon
Offline dr.r.lam
« Reply #23 on: January 19, 2019, 04:32 PM »
Thank you Tom for the information!
Am I correct in assuming that the TPG-30 will be able to replicate the function of the Festool parallel guide extensions?
I imagine a scenario where you have a full sheet (wider than the length of the TPG) and only need a thin strip.
In that case would you have to do 2 cuts - the first to rip a piece from the full sheet, narrow enough to use the TPG, and then use the TPG to make your thin, final strip?
Thank you in advance!
Richard.
Offline tjbnwi
« Reply #24 on: January 19, 2019, 04:35 PM »
Richard.
Let me think on this, I have not tried this yet.
Offline jobsworth
  • Festool Baby.....
« Reply #25 on: January 19, 2019, 05:44 PM »
Any word on the cost?
« Reply #26 on: January 19, 2019, 07:26 PM »
Everything was fine and kind until this very moment.  [big grin]
    • TSO Products
« Reply #27 on: January 19, 2019, 08:58 PM »
all you subscribers to the TSO INSIDER will get a very detailed description with pictures of the TSO Parallel Guide System . The mail is programmed to go from east to west starting at the International date line - look for it around dinner time in the US on Sunday.
Thanks for all the questions and comments. Helps a lot in knowing what we need to address - really!
Pricing will go up on our website right after the TSO INSIDER announcement of availability has gone out.
Hans and Eric
TSOproducts.com
Offline tjbnwi
« Reply #28 on: January 19, 2019, 09:26 PM »
Leave it to Ron.....
Offline jobsworth
  • Festool Baby.....
« Reply #29 on: January 19, 2019, 10:23 PM »
hehehehehehehe you know me  [big grin]
