Author Topic: new TDS-10 Dog Stop from TSO  (Read 5900 times)
Offline TSO Products
    • TSO Products
« on: May 04, 2019, 03:49 PM »
@Sparktrician spotted our TDS-10 Dog Stop product page has gone live on our website this afternoon.
Aimed at speeding up the production of precisely equal size cuts. This concept is worth taking a closer look at an approach that differs from "the way we've always done it".
Our BETA Testers (Pro woodworkers) love it on the job site.
A detailed description is available at TSOproducts.com type TDS-10 in the SEARCH box on our home page. I tried posting a link just a while ago and it would not upload my post.
Hans
TSOproducts.com
Offline RKA
Re: new TDS-10 Dog Stop from TSO
« Reply #1 on: May 04, 2019, 11:03 PM »
Well that’s interesting!  I was just dominoing (now it’s a verb) a series of small mitered parts last week with the XL, and you’re right, I spent more time trying to wedge the parts onto the MFT with scraps and dogs.
And your speed knobs don’t get enough credit around here.  One flick and the spin down or spin off.  I’ve been spoiled by them.  My Festool knobs are buried in a systainer somewhere, while the speed knobs are on the MFT.
One quick question, If you order a qty of 1 of the TDS, you’re getting a pair?
-Raj
    • TSO Products
« Reply #2 on: May 04, 2019, 11:20 PM »
@RKA - our TDS-10 product page has been updated to reflect the various combinations of items you can choose to purchase.
                     https://tsoproducts.com/accessories/tds-10-adjustable-material-stop-for-20mm-worktops/
The basic TDS-10 SKU 61-414-A consists of two(2) CNC machined blue anodized and engraved components. Click on "Build your Order" and the description, picture and pricing will toggle according to your selection.
thank you for you for sharing your experience with our SpeedKnobs. As humble an item as they are, it exemplifies our passion for not allowing "good enough" in our vocabulary or products. Your comments would be very helpful on the SpeedKnobs product Review [wink]
                 https://tsoproducts.com/workholding-accessories/speedknobs/
Hans
TSOproducts.com
Offline RKA
« Reply #3 on: May 04, 2019, 11:28 PM »
Great, thanks for clarifying!
-Raj
Offline ScotF
« Reply #4 on: May 05, 2019, 10:58 AM »
This looks pretty cool.
Do you make or no where to find 20mm collars that could be used with larger dogs under the rail to adjust to thickness of material? There are some videos of someone on YouTube using this with a competing rail system, but the concept is the same. Attach rail dogs o bottom of rail and slide the collar to accommodate stock thickness similar to how the MFT works but I could see this working well with these stops for repeatable width cuts. It would allow narrow stock ripping if you do not have similar thickness to fully support the guide rail.
« Last Edit: May 05, 2019, 11:00 AM by ScotF »
Offline Sparktrician
« Reply #5 on: May 05, 2019, 05:26 PM »
I've just finished cutting the pieces for a photo printer riser and used the TDS-10 that @TSO Products graciously sent me for testing.  I concur with RKA that the Speed Knobs are far superior to the Festool knobs in this application.  Every repeat piece I cut came out dead on the money.  The thing that struck me while using it is that while it's great for repeat pieces cut at 90° angles, it might be better suited for cutting oddly-shaped pieces if one end were not square, but radiused.  That suggestion aside, it seems to me that this is a tool more reliable for quantity repeat cuts than using just the flag stops.  I'd even go so far as to suggest that they'd be better used in sets of four in combination with the MFT/3's fence.
- Willy -
Offline ScotF
« Reply #6 on: May 05, 2019, 07:27 PM »
That looks great. Did you do any testing for longer rips?
Offline kbwoodworker
« Reply #7 on: May 05, 2019, 11:11 PM »
A while back I looked at various 20mm bore shaft collars with set screws to use with bench dogs.  They were about 35-40mm outside diameter.  Started at under $10 to very expensive.  It's possible that something like this could be adapted to a longer bench dog.  I never tried it, so can't say.
I'm trying to envision what you mean by this allowing narrow stock ripping with the TDS-10.  It would be great if these accommodated narrow stock ripping.
Just remembered that Precision Dogs have some rail dogs with collars, though they are called spacers.
« Last Edit: May 05, 2019, 11:19 PM by kbwoodworker »
« Reply #8 on: May 06, 2019, 08:09 AM »
I did some longer rips yesterday, but used the parallel guides for that task.   [smile]
- Willy -
Offline jeffm13
« Reply #9 on: May 07, 2019, 02:10 AM »
I just ordered a pair.  I've spent months trying to find the holy grail: a fence that works with a custom MFT and can be used for repeatable cross-cuts, LR32 setups, etc. That search caused me to go through probably a dozen different variations with different extrusions for fences, different fence dogs, and different flag and flip stops.  Most extrusions are just too bulky to use as a fence. And flag/flip stops seem to be designed to require a specific extrusion to work well.  So I went ahead and purchased a Festool MFT fence and a couple of Festool flag stops. They work pretty well, but really I'm looking for something else.
A fence is overkill. I don't truly need it because I have plenty of dogs. I want something that allows me to set a repeatable stop and that doesn't cause me problems with height as I'm cutting or routing. The TDS-10 dog stop looks like exactly what I've been looking for.  Yet another TSO product I won't be able to do without.
Festool: TS75, DF500, DF700, OF1400, LR32, ETS EC 150/5, DTS400, RS2E, T18, TXS, CT36, PS420, FS1400 (2), FS1400/2-LR 32, FS 2424/2-LR 32, Tradesman/Installer Cleaning Set; TSO: MTR-18, GRS-16 PE, TDS-10, TPG-20/30; UJK: Parf Dogs, Super Dogs, Parf Guide System MkII, Seneca: Parallel Guides, Domiplate, Domishim; Makita: 3000mm Guide Rail; Jessem: Mast-R-Lift w/metric conversion kit, Pow-R-Tec Router, Mast-R-Fence, Mit-R-Slide, ClearCut Stock Guides; Grizzly: G0441 Cyclone, G0691 Table Saw; Laguna: 18BX Bandsaw; Robland: X31 Combination Machine; Incra: MagnaLock Cleansweep; Woodpecker: 1281-300mm, 600mm T-Square, 1200mm Ruler, 1200mm Story Stick Pro; Bosch: GCM12SD Glide Miter Saw
Offline Birdhunter
« Reply #10 on: May 07, 2019, 05:49 AM »
I ordered the $124 set and I am eagerly awaiting its arrival. My primary intended use is when mortising with a Domino. I always have the workpiece hang off the edge of my MFT and the far side blocked by something. Getting that “something” at just the right position can be frustrating. I think the TDS10 will solve that problem.
Birdhunter
Offline Mark Katz
« Reply #11 on: May 08, 2019, 02:42 AM »
I was desperate for a video to see these in action so I typed "tso dog stop" into YouTube. I'm sure that for at least a week or two my feed will be full of videos of how to get my dog (I have none) to stop doing this or that.
    • TSO Products
« Reply #12 on: May 08, 2019, 07:56 AM »
@Mark Katz -  sorry about that. YouTube videos will be coming - but not right away. Search Engines will learn to recognize TDS-10 after a while.
Hans
TSOproducts.com
Offline Claimdude
« Reply #13 on: May 09, 2019, 08:13 AM »
Hans,
I want to order a set up of the TDS-10 including small dogs, knobs, etc. I prefer the "close fit" dogs. How do I flag my order so you will know to include close fit dogs?
Jack Lemley
Hans
Offline Birdhunter
TDS-10 Adjustable Material Stops for 20mm Worktops
« Reply #14 on: May 09, 2019, 08:16 AM »
I received my TDS-10 adjustable stops today. I've only just opened the package and I've not used the stops.
The packaging was perfect and all the parts arrived intact. All the parts look to be of high quality.
I will contact TSO to clarify if what I received was what I ordered as there were actually 4 stops included. I thought the order was for a pair, not two pairs.
If I owe for the additional pair, I plan to keep all 4 of the stops.
I think the stops will be great for setting up for doing mortises wit my Dominos.
Birdhunter
    • TSO Products
Re: TDS-10 Adjustable Material Stops for 20mm Worktops
« Reply #15 on: May 09, 2019, 09:02 AM »
@Birdhunter - thank you for reporting this shipping error.
To help us find and fix the cause, please email us  with your order number along with your FOG name to:
info@tsoproducts.com
Hans
TSOproducts.com
    • TSO Products
« Reply #16 on: May 09, 2019, 10:05 AM »
@Claimdude  - in our view, the combination of having two Dogs locked in position, both horizontally and vertically, makes the clearances of the assembly already pretty tight. I can envision a situation where it is somewhat difficult to remove the Dog Stop assembly from a pair of 20mm holes because of the difficulty of extracting them perfectly perpendicular to the work surface.
If, after receiving our recommended set, you feel you would  still like to try the CF-Dogs, let us know and we'll send you a CF- pair.
Hans
TSOproducts.com
Offline Claimdude
« Reply #17 on: May 10, 2019, 08:45 AM »
Thanks Hans! Will give it a go then.
Jack
Hans
    • TSO Products
« Reply #18 on: May 10, 2019, 09:58 PM »
YES, @Birdhunter spotted what turns out to have been a shipping department software glitch that caused numerous customers to receive two sets of TDS-10 Dog Stops. While that problem, once identified, was quickly fixed, it drew down our inventory more quickly than expected. Many affected customers wanted to buy and keep the extra pair.
Typically our new product roll-outs will be met by demand which exceedss our ability to immediately fill.
Rest assured that follow-on production materials are already in the pipeline several months into the future. We will be ramping up as quickly as is responsible to do.
We expect it will take several months before we have product to fill orders as they are received.
Remember: it’s not just you wonderful people out there wanting our product – for TSO it is a necessity to ship [wink]
We are motivated!
Hans, Eric and the whole TSO Team
TSOproducts.com
Offline Birdhunter
« Reply #19 on: May 11, 2019, 07:00 AM »
In the process of returning the extra set of stops, I got to talk to a number of the TSO staff and with Hans. I came away with an appreciation of a young company with excellent ethics, great customer service, and a drive to become a leader in their market segment.
Birdhunter
Offline RustE
« Reply #20 on: May 12, 2019, 12:14 PM »
Typically our new product roll-outs will be met by demand which exceeds our ability to immediately fill.
@TSO Products , will there be any of the TDS-10 Dog Stop kits available for purchase before the end of the introductory offer on June 15th?
    • TSO Products
« Reply #21 on: May 12, 2019, 12:21 PM »
@RustE  -  Yes, we expect to have enough TDS-10 product to cover all orders received on or before June 15. If demand exceeds that, we will provide rainchecks or equivalent  [smile]
Hans and Eric
TSOproducts.com
Offline Gwerner
  • They call me George...
« Reply #22 on: May 12, 2019, 04:53 PM »
I will be all over a standalone pair of the stops as soon as they are available to order again. Signed up for the e-mail notification.
Offline ScotF
« Reply #23 on: May 12, 2019, 08:24 PM »
Hans and Eric
It would not let me order - said to be on a list and would be notified when back in stock.
Offline RustE
« Reply #24 on: May 15, 2019, 12:00 PM »
@TSO Products, following the comment from @ScotF, is there an estimate for when orders will be taken again?
Offline TSO_Products
    • TSO Products LLC
« Reply #25 on: May 15, 2019, 04:36 PM »
@RustE  - the surest way to know is to be signed up for notification. That will go out automatically to all who signed up. Whatever date I might be able to put a finger on tonight will probably change between now and then. Obviously we're stepping on it to fill demand.
The seven hour time difference where I'm sitting in Europe does not make it easy for me to provide personalized information about product availability - please excuse that.
Hans
Offline tjbnwi
  • Cedar Tucky Indiana
« Reply #26 on: November 02, 2019, 09:30 PM »
Reviving this.
As most here know I test various TSO products, with that out of the way........
When I first recieved the TDS 10 stops months I had no clue how we would use them. For repeat cuts on the MFT, at times, I'd just turn the the angle head 90º and set it where I needed it.
Well today I figured it out (yah, I know I'm a little slow). I had to cut a bunch of Domino mortices in 1-1/2" material. Broke out the TDS's (there's a joke there.......) put the dog on them and morticed away.
The material is walnut and hickory. The hickory takes more pressure to cut the mortices.
