Author Topic: Benchdogs New Rail Square  (Read 2085 times)
Offline Ralph Mignano
« on: January 13, 2020, 02:31 PM »
Hi All
Thought I would let you know that our Rail Square is now available for pre order here at Benchdogs UK
** PRE ORDER ONLY ***  PLEASE READ BEFORE ORDERING
The New Benchdogs Rail Square, Light, Strong and Square. A Unique design which makes it stand out from the crowd.  Special fitment that works with Festool, Makita & Triton Track Saws. The added slide support for using the track on the left or right of the workpiece.
With the Additional 30mm or 50mm bevel adaptors, the Rail Square can be used with bevelled edges which easily screws in on the bottom side of the square, so no need to find an Allen key of fixing to attach it.
MFT compatible.  With the use of the Grooved Adaptors, this can be inserted in the holes of and MFT top to allow the square to be used on any MFT style top for complete accuracy. The use of our B-Collars can also be used to adjust the height to suit board sizes of 9, 12, 15,18 & 25mm.
The Rail Square will be available in 3 options
1. Rail Square Only  - £110
2. Rail Square Systainer with foam insert - £150
3. Rail Square Systainer fully loaded,  which includes  Rail Square, Systainer, Insert, 30mm & 60mm bevel adaptors, MFT Grooved Adaptors & B-Collars, 4 x 30mm Benchdogs (in line with B-collars) £199
RELEASE DATE - 1ST BATCH OF 50 - MID-FEBRUARY 2020
Design, manufactured and design registered in the UK.
PLEASE NOTE
Any other items ordered with this item will not be shipped until Rail Square is ready for shipping.  Please order this product on its own.
TS 55 R, CTL MIDI, RAILS 1400mm, DF 500 Q, OF 1400, CMS-OF, CMS-GE GB 240V, CMS-TS55, ETS 150/5, BS 75 E, MFT/3, KS120, MFK 700 EQ, T 18+3 FL, CTL 36,PS 420 EBQ, ETS EC 150/3, RTS 400 REQ, FS5000/2, FS 1400/2-LR 32, SYSROCK BR10, VAC SYS Set SE1, SYS3-Set SURFIX, FS-PA, FS-PA-VL, LR 32-SYS
