Author Topic: Meet the Power-Loc Toggle Clamp: One clamp, many jigs  (Read 992 times)
Offline TSO_Products
    • TSO Products LLC
Power-Loc™ Toggle Clamps
Innovative Clamps That Don't Require Climbing Underneath Your Worktable
Toggle clamps are a ubiquitous staple of many woodworker's jigs, fixtures and assembly tables—and yet they're often screw mounted permanently in place, dedicated to a single task, and often eat up valuable space on your workbench. With the Power-Loc Toggle Clamp, we set out to create a better clamp; one that could be rapidly inserted into any 20mm dog hole and secured in seconds (entirely from the top of the table), and just as quickly removed. With just a few well-located 20mm dog holes, you can now replace a drawer full of toggle clamps with one Power-Loc.
We have a limited supply of Power-Loc Toggle Clamps on hand, so act fast before they sell out!
Visit the Power-Loc Toggle Clamp Product Page at www.tsoproducts.com.
Happy woodworking,
Your TSO Family
Offline Bob D.
    • My Cordless Workshop
Re: Meet the Power-Loc Toggle Clamp: One clamp, many jigs
« Reply #1 on: May 13, 2022, 06:19 AM »
Interesting, how does this improve on the Armor Tool dog clamps I bought years ago or the Bessey clamps?
What is the maximum capacity, does it even approach the 5.5" capacity of the Armor Tool Dog Clamp?
Online Richard/RMW
« Reply #2 on: May 13, 2022, 06:55 AM »
Bob I'd say the benefit is this shouldn't deform the 20mm holes. The force is pulling up against the bottom of the sheet rather than inside the hole.
Guessing capacity if a couple inches at most.
RMW
Offline tdwilli1
« Reply #3 on: May 13, 2022, 09:20 AM »
If the price is really $70 for one it's a pass.  [scared]
Offline Bob D.
« Reply #4 on: May 13, 2022, 01:55 PM »
RMW
That would be a plus. If that' the case they should change their ad and promote that aspect of their clamp over the others.
Yes, I would not like to deform the dog holes on my MFT. I don't use the Armor clamps on my MFT, I use them on my hard maple bench and they have deformed those dog holes a little. MDF would not hold up as well.
Offline ChuckS
« Reply #5 on: May 13, 2022, 02:17 PM »
The kind of toggle clamp I've used once with the clamping knob on the bottom doesn't deform holes, but does require the mounting from the bottom, not as convenient as the Power-Loc.
What would have made the Power-Loc (about $30US more expensive than the one I tried) more appealing is if it was a tool-free accessory.
Some holdfasts are easily over $100US a piece.
« Last Edit: May 14, 2022, 12:21 AM by ChuckS »
    • TSO Products LLC
« Reply #6 on: May 14, 2022, 09:26 AM »
Thank you all for commenting on  TSO’s new  Power-Loc Toggle Clamp so we can clarify and explain further.
Key advantages:
•   One-hand clamping and unclamping in operation.
•   Quickly relocated with changing set-up needs – all from above the workbench top.
Key point: this is a workholding device designed to immobilize a workpiece on the workbench. Unlike a screw clamp designed to apply serious clamping force, this Power-Loc is intended to act more like a dead-bolt – limiting vertical movement of the toggle clamp. The limited clamping force needed makes it sufficient to rotate the Locking Lug into position just touching the underside of the worksurface.
By preventing the dog body from being tilted during clamping, the dog hole is not elongated by repeated activation of the Toggle Clamp.
When I install the Power-Loc using a 5mm Hex Driver, I just twirl the Hex Shaft between my thumb and index finger until the Locking Lug reaches it respective travel limit. No hand cranking to tighten at all.
Performance of the Bessey Toggle Clamp remains unchanged from the standard Bessey product.
Dictated by each application this Power-Loc version is dimensionally different than our standard Power-Loc for connecting two sheets of material, one on top of the other.
Hope this helps!
Hans
Online Richard/RMW
« Reply #7 on: May 14, 2022, 10:07 AM »
@TSO_Products Hans do you plan on offering the shorter Power Loc dog seperatly?
RMW
    • TSO Products LLC
« Reply #8 on: May 14, 2022, 12:27 PM »
Richard,
do you mean the Power-Loc Dog from the Bessey Toggle set - by itself?
We could, but the economics of that part alone is really questionable and poses customer service problems because now we have customers disassembling and re-assembling leading to questions. Time will tell us what to do.
What would you use the bare Power-Loc with - or for?
- and at what unit price would you be prepared to buy two or more? The "attach from below" SENECA Clamp Dog is priced at $ 39.95 each - on sale right now for $ 34.95 plus whatever Toggle Clamp the customer chooses.
Hans
Online Richard/RMW
« Reply #9 on: May 14, 2022, 12:56 PM »
Richard,
Hans
Yes, the shorter dog alone.
My use would be attaching something fairly thin, ~1/8"-1/4", to a single 18mm layer, with the dog flush to the MFT top.  I can see your dilemma as the thickness variation probably makes this impractical to sell & it's use of a nylock means it would have to be disassembled.
I'd be willing to pay a price in line with the standard power loc, <$40/pair.
Thinking it thru, the Bench Dogs Quad Dog is probably a better option since I can just  drop in the flush dog and attach whatever with an M8 cap screw. They don't resist being pulled straight up quite like your dog but that wouldn't be an issue for me most of the time.
I've been poised to order their Uber set of ~12 for a couple of weeks, [edit] probably reaching my tipping point. [Pulled the trigger...]
Thanks Hans.
RMW
« Last Edit: May 14, 2022, 01:15 PM by Richard/RMW »
