Author Topic: Looking for Feedback on New Model Guide Stop for Domino  (Read 16448 times)
Offline Rick Christopherson
    • http://www.rts-engineering.com/
« on: August 03, 2011, 04:09 AM »
Shortly after developing the first design of the Multi Position Guide Stop (MGS-20), I came up with the concept for a Self Centering Guide (SCG-10). I put off the design for a while, but finally decided to pursue it again in earnest not too long ago. I am ready to enter production and I would like to get some impressions on how much interest there would be in this model.
The main premise behind this model is that guide positions can be reset easily, quickly, and without tools in just a few seconds. Loosen the two thumbscrews, slide the stops to the desired position, and retighten the thumbscrews. The two sliding stops are coupled together so that they always remain centered about the mortising position. When you slide one stop, the other stop slides in the opposing direction.
The stops are infinitely adjustable from 3/4 inch to 5-3/8 inch. When a stop is not in use, it flips up, out of the way. The stop that is being used for mortise registration is then flipped into the down-position for use.
The positioning mechanism is based on a sliding dovetail system to keep the stops in-line during movement, yet providing a firm clamping action during operation. The components are milled from billet aluminum and anodized for long life and appearance. The stop arms are 1/4" thick for rigidity and strength, with detent positions controlled using stainless steel, micro ball plungers. The SCG guide mounts to the Domino Tenon Joiner using the existing threaded holes in the Domino's base without needing to modify your joiner in any way. The mounting thumbscrews are captivated so they do not get lost when the guide is not being used. The baseplate is powder coated for durability.
I wanted to keep the price the same for both models, but the machining is more complex on this model. The price will be $129, which is actually the same price as the MGS-30 version.
I would like to hear how many forum users might be interested in this model. I will be updating the website (www.dominoguide.com) when the guides are in production.
Thanks,
Rick Christopherson
Offline Ken Nagrod
  • Restricted
Re: Looking for Feedback on New Model Guide Stop for Domino
« Reply #1 on: August 03, 2011, 04:43 AM »
First, it's too early in the morning for me to think clearly.  This is when a video showing the new features/design benefits would be helpful.  [poke]
Second, MGS-30 ?  What's that one?
Third.  So this new one has a cable that runs around the front controlling the movement?
Offline Robert Robinson
  • southern Indiana, U.S.A.
« Reply #2 on: August 03, 2011, 05:13 AM »
I'll take one.
TS-55, FS-KS angle unit, 55 inch guide rail, Domino (pin style), 3 Domino systainer assortments(one sipo set),Multi-position Guide Stop 20, Domiplate , PSB-300, FOGtainer 4, CXS set
« Reply #3 on: August 03, 2011, 05:31 AM »
Ken, the basic model of MGS guide is the MGS-20 with 2-pair of stops. The MGS-30 has 3-pair of stops. I believe you bought your guide from a dealer, and they do not typically make this same part number distinction because they normally sell the extra pair of stops (if ordered) separately.
Yes, there is a coated-steel coupling cable between the stop assemblies on the new version. This is what keeps the stops automatically centered about the tenon as they are repositioned.
Offline Ken Nagrod
  • Restricted
« Reply #4 on: August 03, 2011, 05:50 AM »
Rick,
Something else I thought about.  It does appear that it would be faster adjusting the spacing or positioning now, but would this design be slower to re-position for multiple spacings compared with the older version that has multiple stops?  I'm still trying to get a grasp on overall, how this would improve or speed up the process over the older design.
Thanks.
« Reply #5 on: August 03, 2011, 06:09 AM »
Ken, This model wasn't intended to replace the previous model, but instead to be a companion to it. That was always the plan, but I just didn't develop this model sooner.
You are correct that when you have repeating, multiple stop positions, then the MGS guide is more appropriate and faster. This model is for when you want faster, on-the-fly adjustability of the positions. The original vision I had was for the MGS guide to be geared more toward the cabinetmaker, and the SCG guide more toward general use.
Edit: To answer your question, I captured another view of the guide.
« Last Edit: August 03, 2011, 06:39 AM by Rick Christopherson »
« Reply #6 on: August 03, 2011, 06:20 AM »
I'll take one.
I like your dedication Rob. Two years ago you missed being my first customer by only a couple hours. I'll make sure the first one goes to you this time.
Offline Festoolfootstool
  • The trouble with Bob is its all about Bob
« Reply #7 on: August 03, 2011, 06:42 AM »
Hi Rick
Looks interesting, so when its fitted to the machine and you put the domino down does it rest on the two knobs?
If the milk turns out to be sour, I ain't the kind of **** to drink it.......
Why do Festool accessories only have a two month guarantee here in the UK ?
« Reply #8 on: August 03, 2011, 06:48 AM »
Hi Rick
Yes. The two clamping knobs are high impact plastic (with a steel threaded insert of course) very similar to the knobs Festool uses to attach the auxiliary fence to Domino, except these are slightly larger for easier tightening.
« Reply #9 on: August 03, 2011, 06:53 AM »
Hi Rick
Rick +1 on a video of it in use.I would be interested in buying one 4sure.
Offline Alan m
« Reply #10 on: August 03, 2011, 09:25 AM »
might be interested. cant wait for a review or video
Offline Jesse Cloud
  • Festooling at the end of a dirt road in New Mexico
« Reply #11 on: August 03, 2011, 10:54 AM »
Very interested.
Offline FEStastic
« Reply #12 on: August 03, 2011, 12:51 PM »
I would like one
Offline Bob Marino
« Reply #13 on: August 03, 2011, 01:22 PM »
 Rick,
  Nicely done! If you get them, I'll sell em'.  ;). I'm in.
 Bob
Former Festool  Dealer since 2002; user well before that!
« Reply #14 on: August 04, 2011, 06:25 AM »
I'll take one.
Sweet! I can't wait to try it out.
Offline Tim Raleigh
    • Oakville Cabinetry
« Reply #15 on: August 04, 2011, 07:31 AM »
Rick:
If I was to buy one it would probably be the MGS-30, but this one does "look" a lot better.
I like the green anodized parts, should help with marketing it.
Tim
« Reply #16 on: August 04, 2011, 11:45 AM »
Plus +2 for me on the video. As a purchase of your original MGS-20, I'd really like to see a visual of what this new one can do.
I don't have a video on how to use it yet because I haven't built one yet. That's the purpose of the feedback question. However, last night I did capture a screen video out of SolidWorks that shows how the components of the guide interact. (The light-green piece in this view is a representation of the base of the Domino. This is seen from the underside of Domino.)
Offline dsweetser
  • Adirondack, NY USA
« Reply #17 on: August 04, 2011, 01:01 PM »
Rick ,
Something I would be interested in.
Don
Offline jtwood
« Reply #18 on: August 04, 2011, 03:29 PM »
I, too, would be interested in one.  Looks like I need to pick up one of the original ones, too.
Offline Robnol
« Reply #19 on: August 07, 2011, 07:13 AM »
 [tongue] Awesome ... make one for me, i'm in.
TS 75, OF 1400, MFK 700, CT 22, Domino, C 12, MFT 1080, Kapex, PS 300, RO 125, ETS 150/5
« Reply #20 on: August 07, 2011, 08:04 AM »
Hi Rick
So is there a chance of unintentionally altering the settings as you would be putting the machine down on the knobs that control the paddles?
Offline Sparktrician
« Reply #21 on: August 07, 2011, 09:46 AM »
I'm game for this one, too.
 [smile]
- Willy -
Offline Terry Fogarty
« Reply #22 on: August 07, 2011, 10:36 AM »
This one looks great and i will be looking forward to having a go at it when its available downunder.
Offline Brian Buckley
« Reply #23 on: August 07, 2011, 07:36 PM »
I will take one.
Offline neilc
« Reply #24 on: August 11, 2011, 11:10 PM »
Cool design.  Sign me up Rick!
I like it better than your original design for its simplicity.
neil
Offline ghjaxman
« Reply #25 on: August 30, 2011, 10:41 PM »
I'll one as well.  Either through you or Bob.
« Reply #26 on: September 01, 2011, 02:34 PM »
Thanks for all the feedback.
I don't recall if I mentioned it in this thread or not, but I have entered production on the SCG-10 components a few weeks ago. I just got back from a quick visit to the main machine shop that is handling the machined aluminum components. The Dog Arms and Dovetail Bases are complete (but not anodized yet), and look really great. The Dovetail Saddles should be completed in a couple of days and then everything goes out for anodizing.
As soon as I have all the parts in-hand and make sure there is no re-work necessary, I will notify those woodworkers that have asked about the guides, and update the website for placing orders. Should be soon, now.
« Reply #27 on: September 16, 2011, 04:51 AM »
Timing was pretty good today. The baseplates came back from powder coating late yesterday, and while I was standing there at the sheetmetal shop picking them up, the machine shop called to say the aluminum just arrived back from anodizing. Perfect timing! So I swung by the machine shop on my way home from the sheetmetal fabricator.
I still need a few days of testing and planning before I am ready to ramp up into full production, but I did at least assemble a prototype tonight. I'm a little tired tonight, so this isn't the greatest photograph, but I did at least get it installed on a Domino machine.
More information to come.
« Reply #28 on: September 16, 2011, 06:56 AM »
Rick see any value in an extra wide  version ?
Offline tms0425
« Reply #29 on: September 16, 2011, 10:46 AM »
Rick,
These look great! I'd definitely be in for one, probably through Bob if he's getting them.
