Author Topic: Latest GRC-12 TSO Product  (Read 20096 times)
Online Cheese
« on: December 15, 2018, 07:28 PM »
Check this out...and such a simple concept.  [smile]
https://youtu.be/1s0x4gtuxMM?t=6
Offline Peter Halle
« Reply #1 on: December 16, 2018, 07:41 AM »
This topic has been restored.
Offline Gregor
« Reply #2 on: December 16, 2018, 08:32 AM »
Interesting.
Now combine that with the makita way of having a lower part that spreads the load to protect the slot bottoms from being deformed by the screws - with something that holds both parts together when removing the connector - and it would be something.
Offline StanB
« Reply #3 on: December 16, 2018, 09:27 AM »
This looks exactly like the rail connectors Woodpecker used to fix their parallel cut system a few years back.
OF1010 EQ Router | MFT/3 | DF500Q | Mafell P1CC | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro | VAC SYS SYSTEM SET | MX 1200 E MIXER | DF700 XL
Offline Cochese
    • The 144 Workshop
« Reply #4 on: December 16, 2018, 09:29 AM »
Interesting, I was going to pick up the Betterley connector after Christmas.
Online Svar
« Reply #5 on: December 16, 2018, 10:08 AM »
The connectors are quite thin. Can you trust them to remain straight and be rigid enough to act like alignment tool?
Offline DynaGlide
« Reply #6 on: December 16, 2018, 10:29 AM »
I think not having them like the Makita was a big miss.
Instagram @matts.garage
Offline Corwin
« Reply #7 on: December 16, 2018, 01:19 PM »
I like the idea of these. However, I think that some have rails that differ slightly and may only want one of these to align the inner (center) T-slots while leaving the outer (left edge) T-slots to be joined with a connector that does not self align.
Online Svar
« Reply #8 on: December 16, 2018, 01:30 PM »
Excellent point.
Offline duburban
« Reply #10 on: December 16, 2018, 05:57 PM »
cool, i agree.
Just cannot beat the wedge system. I made 2 pair and finally feel good about having my tracks connected.
helper: i used a festool "circular saw" to do something simple and it made it really hard
me: exactly, it makes simple cuts complicated and complicated cuts simple
Offline Peter Halle
« Reply #11 on: December 16, 2018, 07:28 PM »
Two threads have been merged.
Peter Halle - Moderator
Offline dlu
« Reply #12 on: December 16, 2018, 08:41 PM »
Cool, and disappointing - wish that they didn't have the grub screw bearing on the track. Even the "inverted flathead" screw that Woodpecker uses would be a big improvement IMHO.
Offline TSO_Products
    • TSO Products LLC
« Reply #13 on: December 17, 2018, 01:31 PM »
thank you all for the comments - and helpful feedback!
We also check our email box
                                              info@tsoproducts.com
for customer comments to hear from folks who actually have used the product.
We will respond to the questions in the preceding posts after we see a pattern. If we have made design choices that are not spot on, or fall short of reasonable customer expectations, we will acknowledge that and fix them to the extent that may be feasible. That's how we and our products get better [smile]
Hans and Eric
Online Svar
« Reply #14 on: December 17, 2018, 02:30 PM »
Perhaps only a thin spacer under the set screw. In TSO design the connector is acting as a straight edge and needs to be rigid. It is already quite thin. Making it in two pieces (like Makita's) will weaken it even more.
As previously mentioned an inverted flat head, perhaps with plastic padding, should work well.
Offline Richard/RMW
« Reply #15 on: December 17, 2018, 03:59 PM »
Or just use non-marring set screws like these and don't crank them down too tight.
https://www.mcmaster.com/set-screws
Love the TSO products that I have (latest order showed up today) and really respect Hans and Eric for their innovation however $50 does seem a mite steep.
RMW
Offline gunnyr
    • Compass Custom Creations
« Reply #16 on: December 18, 2018, 08:38 PM »
The Betterly StraightLine Tool is $109, the Festool Connectors are $40 for the pair.  $50 for a tool that replaces both seems pretty good to me!  As I already have the Betterly and two sets of Festool Connectors I don't see the need for the TSO product, if I didn't have the Betterly I would jump on these!
I don't understand the concern about dimpling the guide rails with the connector set screws.  I simply snug down the set screws and move on.  Yep, my rails have dimples in them.  To date it has not affected their functionality.  What am I missing?
Semper Fi,
Jeff
TS 55 REQ|HKC 55|PSB 420|DF 500|ETS EC 125/3 EQ|ETS 150/3|DTSC 400|RO 90|RO 150|OF 1400|MFK 700|LR 32|MFS 400/700|CXS (2)|PDC 18|DWC 18-4500|CT MIDI|CT 26|CT 48|MFT/3 (2)|VAC SYS-SET|DUO-SET|SYSLITE KAL II
    • TSO Products LLC
« Reply #17 on: December 18, 2018, 11:24 PM »
Richard,
Thank you for your kind remarks about TSO and your set screw suggestion – which is exactly what is  standard on the GRC-12 Connectors (see picture)
Your comment about TSO being “a mite” pricey tells us we need to be more clear:
It’s easy to overlook that it requires two (2) connectors while Makita and Festool sell and price them as individual units
Because the Makita connector consist of two stamped steel strips it’s easy to think the set, consisting of two stamped steel strips provides two connectors but actually  requires 2 sets of these. So here is the cost picture:
TSO GRC-12 consisting of 2 fully machined connectors $ 49.95
MAKITA one 2-piece stamped steel strip Connector $ 24.99  requires 2 sets = $ 49.98
Festool Connectors $ 20.00 ea. – requires 2 = $ 40.00
Thanks guys for your interest
Hans and Eric
Offline tjbnwi
  • Cedar Tucky Indiana
« Reply #18 on: December 18, 2018, 11:29 PM »
@TSO Products,
Thank you for clearing up the set screw question. My guess was they were soft nose set screws, but it is not clear in the video or on the website.
Offline Richard/RMW
« Reply #19 on: December 19, 2018, 08:27 AM »
Richard,
Hans and Eric
No offense intended guys, the comment wasn't meant in relation to other alternatives. I should reserve my yapping on prices, cost is relative to value & value is dependent on utility/functionality.
I highly value stuff that just works for it's intended purpose, which your guide squares are a prime example of, and I am sure these connectors fit that category as well.
Keep up the great work.
RMW
Offline Chippiegary
« Reply #20 on: December 19, 2018, 05:23 PM »
Was wondering if these connectors are going to be available in the Uk ?,post and packing from USA makes them ridiculously expensive , asked the question via email from Tso no reply yet ?
Online neilc
« Reply #21 on: December 20, 2018, 06:29 PM »
Just received my set.  I'll try them out in the next couple of days.
Offline Peter Halle
« Reply #22 on: December 20, 2018, 07:49 PM »
@neilc , looking forward to your thoughts!
Offline Cochese
    • The 144 Workshop
« Reply #23 on: December 21, 2018, 10:28 AM »
Same. When you consider the Betterley is $100 and still needs a set of connectors, for $50 this seems like a pretty smart play if everything lines up like it should.
Offline Gregor
« Reply #24 on: December 23, 2018, 04:52 AM »
@TSO_Products is there a european distributor? Shipping these from the US would be prohibitive costwise.
    • TSO Products LLC
« Reply #25 on: December 23, 2018, 12:36 PM »
Was wondering if these connectors are going to be available in the Uk ?,post and packing from USA makes them ridiculously expensive , asked the question via email from TSO no reply yet ?
YES,  www.axminster.co.uk will have stock as soon as we get production ramped up to supply everyone. Our dealers are not set up yet Meanwhile we can fill individual small orders  and ship via US Postal International First Class. We will announce it via our TSO INSIDER newsletter. GO to www.tsoproducts.com and click on subscribe.
Thank you for asking!
Hans and Eric
    • TSO Products LLC
« Reply #26 on: December 23, 2018, 12:48 PM »
@Gregor - on the European continent TSO Products are well stocked by http://www.bannedlink.com/ in Amsterdam.
as we replied earlier to the availability question in the UK, we are gearing up to supply stock of the GRC-12 Connector Set to our international dealers. In the meantime we can fill small individual International orders via US Postal International First Class mail.
Hans and Eric
    • TSO Products LLC
« Reply #27 on: December 23, 2018, 01:00 PM »
@Corwin - glad you raised that question because we addressed that close tolerance concern and guide rail variability from the beginning. Remember that our GRS-16 series Guide Rail Squares are designed to handle the normal production variances of Guide Rail Extrusions. We sweated that quite a bit in the beginning to get it right and have that issue well in hand. Your comment highlights the fact that there is more to getting it right than meets the eye.
Thank you for nudging us to point this out. We regularly ask ourselves if we are providing too much information about our products and our customer's eyes glaze over or if we don't provide enough. We'll add a paragraph about this on our website product page.
Hans
Online neilc
« Reply #28 on: December 23, 2018, 10:28 PM »
I put the GRC-12 connectors on a pair of 1080 guide rails.
The GRC-12 units are slightly thicker than the Festool ones given the bevel.  They are made from aluminum rather than steel.  They include allen head screws and a wrench rather than typical straight-head screws for adjustment.  (BTW, I also made a set of connectors similar to the Makita ones out of a couple of pieces of steel and they work, but the allen screws are a little small for much torque to tighten them and I don't use them as much as I have used the Festool connectors because of that.)
I installed the GRC-12 units in one rail, tightened them and then slid the second rail in place leaving a slight space between the two rails - maybe 1/16" and tightened them up with no straightedge.  Upon checking with a Festool level for a straightedge, the outside edge was off by .004" over the length of the level.  However, when aligning the level to the inside extrusion, it was dead-on with no measurable error in alignment.
I then picked up the guide rail in the middle and shook it a bit while on the edge, to see how it deflected when two were clamped together.  I did notice upon placing it back down on the bench that the rails were no longer straight.  They were out of alignment by perhaps 1/8" and I had to straighten them out.  I did not try a similar technique with the Festool connectors but I would bet they too would slip.  I had hoped the GRC-12 connectors would 'hold' given the beveled clamping method.  But there is a lot of force across a nearly 2200mm rail when you start shaking it.
To be honest, I'm pretty careful with connected rails when moving them so my 'shake test' might be considered a bit extreme.  But I wanted to see if the connectors would keep things in alignment.
I'll spend some more time with them and report back what I find.
I'd say the connectors are definitely easier to install and get set up - and I like the hex head screws for easier adjustment.  Based on a quick test, they aligned upon first install very well.  But I think regardless of the connectors (festool, TSO, Makita) you're going to want to still use care when moving connected rails to insure they stay straight.
neil
TSO thickness
Festool thickness
.004 alignment variation on outside extrusion of rail
No alignment variation on inside extrusion
Offline ScotF
« Reply #29 on: December 24, 2018, 12:34 AM »
Good test, Neil. Thanks for the pics and write-up. I am curious why these would not be longer - seems that a longer length would be more secure. I too am careful when connecting rails, but I have had them move and it is frustrating. I was hoping this would solve that issue, but looks like that might not be the case. I would be interested in hearing how these perform as you put them through more testing.  Thanks!
Offline Richard/RMW
« Reply #30 on: December 24, 2018, 07:22 AM »
Neil thanks for the testing/results. One of the best aspects of the squares is not even having to wonder if it.s square, i.e. I just attach and cut. If you have to stop and check the joined rails frequently just for peace of mind it will somewhat eliminate the benefits of their self aligning aspect.
Just my [2cents]
RMW
Offline NL-mikkla
  • www.m144h.com
« Reply #31 on: December 24, 2018, 09:45 AM »
LOL, simple adjustment to an old ongoing problem/discussion.
Festool must feel silly for not thinking of this solution.
Offline ChuckM
« Reply #32 on: December 24, 2018, 01:49 PM »
Big, bureaucratic companies are more prone to ignoring or missing opportunities to improve little things, while small, entrepreneurial businesses are more responsive to or quicker in responding to market feedback.
    • TSO Products LLC
« Reply #33 on: December 28, 2018, 02:31 PM »
FOG Members and customers:
We appreciate the comments and feedback. Neil’s report is very helpful, too – thank you.
We made a mistake in judgement to start shipping because we got such excellent results in testing- obviously not sufficiently “life-like” testing – Lesson learned:
                                     no new TSO products go into production without outside BETA testing.
Based on what we have learned, we launched an initiative to test further design refinements.  When we have new parts to BETA test, we will put them in the hands of volunteer individuals, including some current purchasers, to see how far we can improve on the original design.
Meanwhile we have stopped accepting orders and notified purchasers of this product. If we can demonstrate in BETA testing that we have in fact achieved the desired improvements we will exchange customer owned GRC-12’s at no charge before resuming production shipments. Customers who wish to return their GRC-12 will of course get a refund with free return shipping.
The first step is to get to next design revision and complete testing. We expect this will take us into February. Meanwhile, thank you for your continued support.
Hans
Offline Richard/RMW
« Reply #34 on: December 28, 2018, 03:36 PM »
Kudos Hans, well played. Hope your new design meets a set & forget standard, it will be a great addition to the product line.
RMW
Hans
Offline ChuckM
« Reply #35 on: December 28, 2018, 03:42 PM »
No way a company such as Festool or Bosch or the like can respond to the market in a speedy manner like that.
By the way, a while back, TSO has indicated a new Domino Joiner accessory is being worked on. Any update on that (we don't know what it is or what it does based on the scan info. provided at that time)?
« Last Edit: December 28, 2018, 03:44 PM by ChuckM »
Offline Cochese
    • The 144 Workshop
« Reply #36 on: December 28, 2018, 04:39 PM »
Hans
Man, while I'm disappointed that I can't order (literally had my card out), I appreciate the attention to detail.
Offline TSO Products
    • TSO Products
« Reply #37 on: December 28, 2018, 08:22 PM »
@ChuckM  - while it's off-topic for this thread let me share with you that BETA testing resulted in the addition of another feature benefit which is going back into machining the next btach of BETA test units. NO Launch date yet. Staytuned to TSO INSIDER newsletter  [smile]
Hans
TSOproducts.com
Offline box185
« Reply #38 on: December 29, 2018, 01:02 PM »
It seems to me that a design based on the Wedgelock product would be a better option. If only they were available in a suitable size.
http://www.wakefield-vette.com/products/accessories/wedgelocks.aspx
    • TSO Products
« Reply #39 on: December 29, 2018, 01:32 PM »
@box185  - thank you for offering a helpful suggestion. We agree and we seriously looked at the wedge approach as well as other means of adjusting the crossection of the Connector. But very quickly the complexity, production cost and resulting selling price moved this out of final consideration. We're not afraid of revisiting any of these alternatives should we not be successful in producing a "TSO worthy" configuration of the current concept.
Keep the suggestions coming while we modify and test the current concept!
Hans
TSOproducts.com
    • TSO Products
« Reply #40 on: December 29, 2018, 02:02 PM »
more on the wedgelock concept:
here is a link with a more detailed illustration
                  http://www.wakefield-vette.com/products/accessories/wedgelocks/-d-series.aspx
One of the challenges TSO faced in choosing the design direction was the fact that our Connector would need to be adjustable from the "side' of the assembly - rather than in the preferred longtitudinal direction. The wedgelock design as you can see from the exploded catalog view is aleady a complex set of parts in its existing arrangement. Now add the need for adjustment from the side and you can see why we felt we should move on to other approaches.
That said, the idea of searching for inspiration in unrelated technical fields is certainly the right one.
During the Cold War era the Soviet Union made a concerted effort to find ways to apply results of their space program research to other commercial applications. After "that"  Wall came down, this research effort became public. I took the opportunity to attend a day long training  session in  a Lockheed Martin conference room to familiarize myself with this approach to inventing solutions. Certainly opened my mind to always look much more broadly at possible solutions.
I could imagine that in the medical field there are methods and devices which could inspire. In our woodworking applications the challenge quickly narrows down to low product cost at (relatively) very low unit volume - which limits what you can spend on tooling.
Keep the ideas coming!
Hans
TSOproducts.com
Offline box185
« Reply #41 on: December 29, 2018, 02:57 PM »
It seems that the socket head could be accessible along the direction of the slot in the Festool Guide Rail using a ball driver - similar to some of the 80/20 connectors.
Among other applications, the Wedgelock product is used in military applications - holding circuit card assemblies in the equipment chassis. This application endures significant vibration testing without failure.
I agree that looking for solutions outside of the box is useful - one of the reasons that a forum is so valuable. Everyone has a different experience.
I’ve contacted the manufacturer of the Wedgelock to find out if the have other sizes available. The Festool application is probably larger than what they typically deal with, but I wanted to ask.
    • TSO Products
« Reply #42 on: December 29, 2018, 03:32 PM »
@box185 - you're quite right that a ball driver with a long enough blade or a flexible shaft driver could be made to work. Where we derailed with the wedge or other expansion device was the cost imposed by market level pricing for such a low volume item in woodworking.
it would be interesting to see a proforma itemized list of parts with production and tooling cost for every single line item, plus tooling amortization and see what selling price would have to result.
Ask what the individual cost of the mass produced "D" Wedgelock is.
Hans
TSOproducts.com
Offline rst
« Reply #43 on: December 29, 2018, 04:55 PM »
Whenever I design a jig or tool modification, I always subject it to the KISS principle, a philosophy very similar to Ocam's Razor... Keep It Simple Stupid.  It always amazes me how many things a designed in an overly complicated manner.  I sell service and repair Gyro Tech automatic doors.  The gearbox for their automatic swinging doors was the original non-hydraulic or air operated door opener.  It was designed by one man in the 60's and every part excepting the motor and controls is exactly like the original today.  How many designs can claim that...not even Festool.
Offline JD2720
« Reply #44 on: December 29, 2018, 06:36 PM »
(Attachment Link)
Isn't the inside extrusion, where the saw rides, the only extrusion that needs to be in alignment?
That is where my alignment jigs mount.
    • TSO Products
« Reply #45 on: December 29, 2018, 11:18 PM »
(Attachment Link)
@JD2720  -You are correct to the extent  that you are talking about "lining up the two ends of the upside-down t-slot the saw rides on. That's the easy part. The challenge is to keep both tracks pointed, as perfectly as possible, in a straight line.
hope that helps clarify when we're talking about "aligning"
Hans
TSOproducts.com
Offline box185
« Reply #46 on: December 30, 2018, 12:13 AM »
I had some time this evening to look at pricing for the Wakefield-Vette Wedgelock products.
I searched for the 426C7 series and found this
http://www.nextwarehouse.com/item/?2076899_g10e&gclid=EAIaIQobChMIvrDhyOHG3wIVhLrACh34cQgTEAkYAiABEgIQOfD_BwE
Another search for the 422C-480UMB-CKP product ( slightly narrower ) yielded this.
https://www.ttiinc.com/content/ttiinc/en/apps/part-detail.html?partsNumber=422C-480UMB-CKP&mfgShortname=WKV&utm=ga-shopping&channel=ppc&source=google&campaigns=tti-brand&gclid=EAIaIQobChMI_s-RvuTG3wIVE57ACh1qXg8wEAkYASABEgJfqvD_BwE
Both of these parts are too small for the Festool Rail Guide, but this information is provided for reference. It does seem that a narrow strip of material could be attached to the Wedgelock, making it fit into the Festool Guide Rail.
Offline Gregor
« Reply #47 on: December 30, 2018, 07:28 AM »
While the principle of the wedgelock is great when your want to apply pressure along a seam (or a card in a holder) it might fall short when it comes to aligning the t-slots at the seam between two FS rails. This would need some testing.
But to have a rail connector operate on the sides of the t-slots (instead of top and bottom, as all current solutions do) would IMHO be a good idea to follow as the sides of the slot have to be parallel and in one line to get a straight cut.
A slight deviation in the vertical direction would worst case hinder movement of the saw (it might catch on the ledge) if there would be an offset at the rails seam, but that shouldn't happen when the rails lie on a flat surface when being connected and the flexibility of the rail itself should compensate for any slight non-parallelism on the vertical axis...
Offline skids
« Reply #48 on: January 04, 2019, 10:19 AM »
good test Neilc...I think the very fact the rails move is what makes these TSO connectors more valuable..Every time you move them easier to square them back up with out additional straight edges.
The funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it
    • TSO Products
« Reply #49 on: May 03, 2019, 02:10 PM »
The latest generation of the GRC-12 Connector (REV C)
began shipping from TSO April 29, 2019. A refined connector-body profile is accompanied by the most noticeable change – custom set screws -reflecting customer suggestions since the release of the original configuration:
A large “flat-foot” Set Screw which retracts into the counterbored Connector body has replaced the original blunt tip set screw. No more divits in guide rail t-slots. More specifics can be seen at https://tsoproducts.com/tso-products-guide-rail-squares/grc-12-self-aligning-guide-rail-connectors/
And here’s a tip for new users:
When first using the Connector set, the retracted Set Screws need to be loosened by turning the 3mm ball-tipped Allen Hex Driver clockwise. When packaged, these set screws were tightened to keep them from vibrating out during shipment. Tightened a bit too much, it turns out. This misled some customers thinking there is something wrong because of the force required to break them loose.
The nature of a ball driver means there is intentional play between the Driver and the hex-socket  compared to using a straight Driver or L-wrench. We are now retracting the Set Screws only lightly into the Connector body
Hans
PS: a picture I tried to attach to this post earlier seems to have caused an upload problem -I'll try the picture again separately
TSOproducts.com
    • TSO Products
« Reply #50 on: May 03, 2019, 02:41 PM »
one more try to upload the GRC-12 REV C picture . . .
Hans
TSOproducts.com
Online Bob D.
Re: Latest GRC-12 TSO Product
« Reply #51 on: May 05, 2019, 07:26 AM »
The flat heads on the screws will not bite into the rail, which may be both good and bad. Good as it does not damage or deface the rail (inside the alignment grooves), and bad because they will not have the same 'grab' as a cup point set screw does. Once you snug the stock set screws down they are less likely to slip I would think. I wonder if adding a cross hatch pattern to the flat face of the TSO screws would be enough to eliminate the slip. Of course that would mean it might Mar the surface of the rail inside the grooves but it would be less damage than done by the stock Festool set screws I think.
I just received mine yesterday but haven't even opened the box, busy with yard work yesterday. Maybe later today I will get to check them out.
    • TSO Products
« Reply #52 on: May 05, 2019, 08:34 AM »
@Bob D. – thank you for giving me the opportunity to explain the engineering decision behind the GRC-12 a little bit more:
To begin with – the job of any connector is to keep the rails from shifting horizontally. There is no appreciable lateral force to pull the guide rails apart.
Traditional guide rail connectors
rely on friction between the connector body and screws (or Makita flat plate). To retain guide rails in alignment these connectors need to be kept from sliding horizontally Left/Right.
The GRC-12 Connectors oppose mis-aligning horizontal guide rail forces by locking the Connector body into the opening of the guide rail t-slot. It accomplishes this by using a jack screw effect from what used to be a set screw shape. Our special “Flat Foot” Screws need only to eliminate vertical clearance when snugged up. The actual “holding” is done by the inability of the interlocking shapes of the GRC-12 and the guide rail t-slot to move laterally while in compression.
And thank you for your purchase, Bob [smile]
Hans
TSOproducts.com
Offline reidbailey
« Reply #53 on: May 05, 2019, 11:59 AM »
I received my connectors and accompanying ball Allen wrench this week. It appears that the Allen wrench is too small for the screws. I know with a ball head there will be play but this has no purchase to turn a screw.  I emailed a video to support earlier this week but have yet to hear back.
I also know I can use a different sized Allen wrench but really like the accompanying one sent with the connectors.
Has anyone else experienced this?
Offline Koamolly
« Reply #54 on: May 05, 2019, 12:41 PM »
Yes.  I ordered two sets of connectors.  One set the Allen wrench was too small, one set it was the correct size.  Was going to send an email with photos.
    • TSO Products LLC
« Reply #55 on: May 05, 2019, 01:05 PM »
@Bob D. - @reidbailey – and other GRC-12 purchasers
Loose fit of the Eklind 3mm Allen Ball Driver into Special Foot set screw:
we are aware of the issue and will work with the Eklind to see what solution we can come up with quickly. We found that the Screw Socket and Ball Driver dimensions appear to be running at their opposite tolerance limits creating excessive clearance.
The first production lot of the new GRC-12 (REV C) was packaged with the Special Screws retracted into the body and tightened (too much) to keep them from vibrating loose in shipping. So to get started after unpacking a hard right hand twist on the driver or L-wrench is required the first time. Actually an L-wrench makes breaking it loose easier.
If you encounter any difficulties, email to info@tsoproducts.com – our ZENdesk customer service system creates a ticket and a record for us to respond to without risk of falling through the cracks at our end.
Our apology for this inconvenience.
Hans and Eric
Online Cheese
« Reply #56 on: May 05, 2019, 01:28 PM »
Also look at the Eklind handle top/end there should be a 3 engraved on the end.
Online Bob D.
« Reply #57 on: May 05, 2019, 01:43 PM »
Thanks, I emailed you earlier today. I also found the ball to be undersize and the shaft slightly oversize when compared to my Elkind 3mm L wrench. Also, the hex in the screws seems slightly oversize. Tough to take an inside measure using a 6 inch micrometer but I came up with 3.14mm. I don't know what the tolerance is for a socket head screw but this seems high. Still the supplied wrench is off and that's not TSO's fault, they didn't manufacture them.
I thought when I opened the box; "wow, how about that, TSO sent along a made in USA hex driver from Elkind". One minute later my joy was neutralized as the ball spun around inside the hex. I did find that the T15 Torx driver on my Festool Toolie multi function tool fits snugly as does a standard 3mm hex wrench.
Online Bob D.
« Reply #58 on: May 05, 2019, 01:44 PM »
Yes, mine has the number 3. The ball is so small I was thinking maybe it was a 2.5mm with a 3mm handle by mistake.
Offline Koamolly
« Reply #59 on: May 05, 2019, 01:53 PM »
Both mine say 3 on handle.
    • TSO Products
« Reply #60 on: May 05, 2019, 03:11 PM »
Bob and @Koamolly: can you put a caliper on the ballends and email us the results?
getting data will help nail down the cause and be sure to get the correct Ball Driver replacements.\
Hans
TSOproducts.com
Online Bob D.
« Reply #61 on: May 05, 2019, 05:17 PM »
I sent an email earlier today Hans with those measurements. The ball is 2.50mm and the shaft is 3.15mm, and when I measured my Elkind 3mm L wrench it was dead on 3mm. Also, the hex in the screws are slightly over 3mm, I checked a few of them and they are 3.12 to 3.15mm best I can measure but not easy to get the inside jaws of the mic in there.
I sent you a link to a video in my public folder on OneDrive too.
Offline reidbailey
« Reply #62 on: May 05, 2019, 06:04 PM »
I had a similar experience.
Hans & Eric - I did email my issue earlier this week. Twice actually. Perhaps it’s still waiting to be acknowledged but I posted here in hopes of validation that I was either losing my mind or if someone else has experienced the same thing.
Online neilc
« Reply #63 on: May 05, 2019, 07:07 PM »
I received two and they were different.  One worked, the other was too small.  One was 2.9mm.  The other was 2.48mm.
Both had 3 on the end of the handle.  Definitely a QC issue.
« Reply #64 on: May 06, 2019, 10:21 AM »
Quality control is no longer a function of “made where” but “made by who”.
Offline SRSemenza
« Reply #65 on: May 06, 2019, 11:19 AM »
     If they are all as different as the two in this picture, then it doesn't look like a tolerance issue to me. That looks like two different size drivers.
« Reply #66 on: May 06, 2019, 12:26 PM »
Re. Seth, so maybe the fault is in the application of the number 3 on the handle...
    • TSO Products
« Reply #67 on: May 06, 2019, 12:31 PM »
3mm Hex Ball Driver EKLIND p/n # 92630 mix-up reports
We received reports that some Ball Drivers marked “3” on the top of the handle are in fact molded with mismatched driver ball tips for a smaller tool. Note that the blades are the same cross section – only the ball tip is machined differently.
We are working with EKLIND, the US Manufacturer of this tool, to establish an inspection process for our in-house inventory as well as new, incoming inventory of this Ball Driver. The goal is to be able to ship the correct replacements to affected customers as quickly as possible - aiming for this week.
We are also opening packaged GRC-12 Connector kits in our warehouse and inspecting them to ensure the correct Ball Driver is included. This means a brief interruption of shipping new orders to be sure they’re correct.
EKLIND apologizes profusely, along with ourselves, for this mix up. We thank our customers for their understanding.
Hans and Eric
TSOproducts.com
Offline Roachmill
« Reply #68 on: May 17, 2019, 05:43 PM »
Received mine today and I'm very pleased with them. Despite the additional £28 UK import duty which is not fault of TSO I may add.
First shot at connecting rails require a second go with a straight edge to get things bang on (that's with leaving a small gap between rail ends) but they are so much easier, relatively speaking (based on having used the Festool and Makita connectors), to tighten up its no big deal. A good amount of shaking the rails around did nothing to change alignment so I'm happy to trust them once set... which is a good feeling to have in any tool :)
    • TSO Products LLC
« Reply #69 on: May 23, 2019, 04:06 AM »
@Roachmill - we have noted your report of FedEx charges on orders shipped direct from TSO. We will hasten to supply our international dealers with these new products to avoid these importation charges.
Hans
(in Europe at the moment)
Online Bob D.
« Reply #70 on: June 12, 2019, 07:35 PM »
Hans and Eric
Any updates on when these will ship?
I know you said you were 'aiming' for next week, which was ~3 weeks ago, and I understand these things often take longer then expected. I also understand it's not a show stopper in that it does not stop anyone from using the guide rail connectors. But an update as to what's happening would be nice.
    • TSO Products LLC
« Reply #71 on: June 12, 2019, 08:17 PM »
@Bob D. - you have not yet received a replacement EKLIND 3mm Ball Driver from us? Our apologies as we work to mop up the after this customer inconvenience!
we do have replacement 3mm Allen Drivers in stock now.
Did anyone else receive a mislabeled EKLIND 3mm/actual 2.5mm Ball Driver and is waiting for replacement ?
please email your name** and shipping address to:
           Info@tsoproducts.com
**Remember we have no practical way of connecting your FOG Handle to your customer name in our database.
Hans
Online Cheese
« Reply #72 on: June 12, 2019, 10:59 PM »
Great point Hans and one that very often falls by the wayside, so while we all chat with each other with our “handles”, we all have formal names that govern more significant information.
Online Bob D.
« Reply #73 on: June 13, 2019, 06:36 AM »
True, while it is possible to send an email to a FOG member their actual email address is never revealed in the process. As I said it's not a show-stopper for me, I have a couple 3mm hex wrenches. But the dedicated ball driver would be nice to keep with the rails in the transport bag.
Offline nms
« Reply #74 on: October 05, 2019, 07:47 AM »
How are you guys liking these? Are the alignments dead accurate everytime or are you still needing to use a straight edge for total accuracy?
Online Bob D.
« Reply #75 on: October 05, 2019, 11:31 PM »
The connectors are great, no complaints and they are easy to use and self-aligning works well.
The ball driver was a good idea but unfortunately the item TSO got from Elkind was incorrectly labeled as a 3mm when it was not. TSO was quick to send replacements but for me the second ball driver was no better than the first. I don't really care the guide rail connectors is what I was buying. I use my own 3mm hex wrench, also from Elkind, and it works just fine.
Long story short the guide rail connectors are worth the money and work well.
« Last Edit: October 06, 2019, 09:39 PM by Bob D. »
Offline Gregor
« Reply #76 on: October 06, 2019, 09:10 PM »
Do not 'undertighten' the screws (meaning: think that it's still tightened to the rail while in reality it's already loose from the rail as it's already unscrewed as far as it can be) or you'll end up with them getting stuck inside the connector.
Please don't ask how I know.
« Last Edit: October 06, 2019, 09:15 PM by Gregor »
Offline jarbroen
« Reply #77 on: October 27, 2019, 07:23 PM »
Does TSO ever offer any free shipping deals?
I'd really like to order the connectors, but it seems silly to spend $13 on shipping.  That's the cheapest option.
Woodcraft Seattle doesn't carry it and the other vendors have similar high pricing on shipping.
Offline rj_mccall
« Reply #78 on: October 27, 2019, 07:26 PM »
I believe they have before, but not for some time. I agree though, a bunch of products my vendors do not stock that I can’t justify the shipping on. Hopefully for Black Friday?? Doubt it though.
    • TSO Products
« Reply #79 on: October 27, 2019, 08:32 PM »
@rj_mccall - have you asked ULTIMATE Tools  in Burnaby, BC Canada to stock the item(s) you're looking for? - if not, you may want to ask them and cc: info@tsoproducts.com.
Same applies to other dealers.They'll stock what you ask for.
We can offer lower shipping costs on some items via a combination of UPS or FedEx with "last mile" delivery handled by the USPS Post Office. But that earned us some customer complaints about delivery SERVICE and tracking information. Thus ended the lower shipping cost option.
If you are signed up to our TSO INSIDER Newsletter you will learn about our private sales. If you are a subscriber and have not received the latest TSO INSIDER over this weekend (October 25 -27) and would like to take advantage of it, email us and ask:
Hans and Eric
TSOproducts.com
