Author Topic: Kapex hose  (Read 1148 times)
Offline StanB
Kapex hose
« on: March 12, 2021, 09:05 PM »
Does any vendor here make the short 36mm hose for kapex?
OF1010 EQ Router | MFT/3 | DF500Q | Mafell P1CC | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro | VAC SYS SYSTEM SET | MX 1200 E MIXER | DF700 XL | PDC 18 | TID 18
Offline pettyconstruction
Re: Kapex hose
« Reply #1 on: March 13, 2021, 12:48 AM »
Not that I know.
Two things you could do.
1: buy a cheaper hose and cut it.
2: buy a longer Festool hose and cut it down and have two.
I went with a Bosch hose, and cut it in half.
Btw I went with a non anti static hose.
Charlie
Offline Peter Parfitt
  • Magazine/Blog Author
Re: Kapex hose
« Reply #2 on: March 13, 2021, 07:14 AM »
Hi @StanB
I had a rush of blood a while back and bought a 5m anti static 36 mm hose. I cut about 1.2 m off for the Kapex and the remainder stretches perfectly from my centrally positioned CT to my tracksaw cutting station where I connect it to my TS55.
Although I deliberated on the purchase for a while it has turned out to be a really good investment.
Offline morts10n
Re: Kapex hose
« Reply #3 on: March 13, 2021, 12:14 PM »
I did the same as Peter
Offline elfick
Re: Kapex hose
« Reply #4 on: March 14, 2021, 03:02 AM »
Would there be any value in using a 50mm hose? It seems like the 5’ 50mm hose from the boom arm kit with the 50/36 adapter would work if there is any benefit in 50mm over 36mm.
Re: Kapex hose
« Reply #5 on: March 14, 2021, 04:33 AM »
There would be a slight improvement but a short 36 mm works brilliantly.
Offline jeffinsgf
Re: Kapex hose
« Reply #6 on: March 14, 2021, 09:23 AM »
Here's a less expensive way to test your theory:  https://www.oneida-air.com/flex-hose/vacuum-hose/2-5-inch-5-5-foot-wire-reinforced-vacuum-hose
That hose from Oneida is very well made and a perfect fit in the Festool vacs ... and $17.
Offline unixisgoodforyou
Re: Kapex hose
« Reply #7 on: March 14, 2021, 11:49 PM »
Interesting.  Is the hose an anti static hose?  Presumably to get it to work you would need to cut the ends odd and attach festool ends.
 RWW
Offline StanB
Re: Kapex hose
« Reply #8 on: March 15, 2021, 12:05 AM »
Well poop. Now I have a long 36mm hose...The 2.5" looks interesting option too. Thank you for all the replies
