Author Topic: Introducing the UJK Parf Fence - a must for MFT3 or custom benches  (Read 11890 times)
Offline msc
Re: Introducing the UJK Parf Fence - a must for MFT3 or custom benches
« Reply #60 on: April 26, 2020, 04:26 AM »
@peterparfitt
I understand in terms of accuracy 600 is fine but the stop can’t be set on fence to suit larger panels. Would have to set a separate stop for longer panels, such as a home made one / the tso ones, or even the adjustable ujk stop. This would be the case for when doing a panel say 1500mm long as I wouldn’t  expect a fence to be produced that long.
I just think the 600 length has been made in relation for the mft size, doing small things. One that is at least 800 or 1000 opens up things for larger projects on same fence before one has to resort to other type of stop.
Bench dogs in Uk has a fence system with a flip type adjustable stop along with scale (so one can set more than one stop-extra one bought separately) however Ime suspect on the quality of the 3D printed stops, so am avoiding this system. Maybe they will improve on stops in future but at least they make them over 1000mm from memory -think there are some different sizes that offer.
Offline Peter Parfitt
  • Magazine/Blog Author
« Reply #61 on: April 26, 2020, 10:32 AM »
The beauty of a top created with the Parf Guide System is that it is so accurate that you can use a pair of the Parf Fences on the same side and setup exactly how you wish. The 600 mm length is a good compromise to allow MFT3 users and custom tracksaw users take advantage of the same system.
Offline Doug S
« Reply #62 on: April 26, 2020, 01:33 PM »
You can use the fence dogs from Bench dogs on standard 20 x 40 aluminium extrusions so you can make whatever length fence you want, works out very reasonable, that is the route I am going down.
Offline msc
« Reply #63 on: April 27, 2020, 03:13 AM »
I now will assume a longer one won’t be made, and will disregard this system.
600 is a poor choice of length (just to keep within mft size limits)
It’s also rather expensive for what it is, but I can see past that, and I know the quality would be spot on. Hence would pay the price anyway.
Will start to look my own alternative, and as mentioned maybe use some of benchdogs parts and an extrusion. Need to look into stops for this.
Offline JimH2
« Reply #64 on: April 27, 2020, 10:26 AM »
It is so easy to tell someone who takes the initiative to design, implement and bring to market at a price that works financially. It is even easier in forums like this one. The question is what have done in terms of bringing something to market. I'll guess that it is nothing.
Peter, thanks for doing what you do. I don't have any of your product, but fully appreciate the time and energy required to do so.
Offline msc
« Reply #65 on: April 27, 2020, 01:58 PM »
[/quote]
I have supported peter from the very first veritas made parf dogs, then the very first parf guide stem and then the parf dogs, got virtually everything inc some ujk stuff which works alongside. I’ve also met peter at north of England show.
I just think this is lacking as it’s simply made to suit the mft size more and so easy to offer more size options. As much as I want to go with system, I can’t make the length work for me  for the panel sizes I tend to cut.
« Reply #66 on: April 27, 2020, 02:23 PM »
[/quote]
Axminster are aware of the requests for longer and shorter versions but they are struggling to keep up with the demand for the current size. If anything new is agreed I will let you know ahead of product launch.
Cheers - fingers crossed that Harrogate will happen this year but it is not looking hopeful.
Offline Rick Herrick
« Reply #67 on: April 27, 2020, 06:56 PM »
I spent a lot of time with my new fence today.  All of my holes were created with the MKII system.  But I am wondering if maybe the holes used to secure this fence should NOT be chamfered?  It worked OK but it was not rock solid using the chamfered holes.  I earlier realized I needed to chamfer the holes for the Super Parf Dogs but starting to think you have to think it through on which holes get chamfered, and which ones don't.
I am going to make a test tomorrow with a few non-chamfered holes and see if it gets a little more solid feeling.  It would be nice too, if the stop had a different mechanism to tighten it.  As it is you only have 180 degree of movement.  Be nice if the mechanism worked on top instead of on the side of the fence.  I like it and have already ordered a second one, just hope they look at improvements along the way.
Offline TSO_Products
    • TSO Products LLC
« Reply #68 on: April 27, 2020, 09:38 PM »
Rick,
the chamfer should have zero effect on the snug fit of the dogs inserts through the Parf Fence.
there is far too much contact in the 20mm bore to allow even a generous chamfer to have any effect on the dog-to-hole fit.
What method did you use for boring the 20mm holes? Did you use the Parf Guide 's 20mm cutter with a drill or some other method?
What other dogs do you have to compare their fit?
Hans
« Reply #69 on: April 28, 2020, 08:54 AM »
Yes, I did use the Parf Guide system, MKII and did use the 20mm cutter provided.  I have Veritas long and short dogs, Parf Super Dogs (and other ones that came with the MKII).  And the dogs that came with the fence itself.  Just for kicks I pulled out the PTR-18, which I used initially as one step to verify my test table.  Moving it all around the layout to make sure I didn't have any spacing issues.  Using any of my dogs, the PTR-18 is more snug.  I can hear it click when I try to shake it.  But on the Parf Fence I can hear the click but also see the slightest movement.  I have not tested the Super Parf Dogs yet on this fence but as I said earlier, not seeing a performance issue yet so not going to lose sleep over it.
Offline Tom in SoCal
I was delighted to receive my parf fence from Axminster.
I as disappointed that it wouldn’t fit on my MFT/3.  No matter which holes I used on the fence, and no matter where I tried to use it on the MFT, the holes were very slightly misaligned, and I couldn’t install both dogs.
My MFT is about 3 years old and in great shape.
So beware that the Parf fence may not work on an MFT/3.
Offline manuc
I have the same issue with the second Parf dog not going in on the MFT/3. I sent them an email. A possible solution is to machine the lower half of one of the Parf dogs  a little smaller without introducing any slope.
Festool do not guarantee the accuracy of the layout of their 20 mm holes which is why the Parf Guide System was created to provide a common standard for dog hole positioning.
Offline Euclid
Clearly some confusion here.
It’s often cited that Festool’s primary intention for the hole pattern of the MFT3 top is hold dowm, clamping, assembly etc. Yet the 96mm spacing adopted implies adherence to (or, at least, support for) the 32mm system… but the spacing of the holes would surely only be relevant if they were intended for accurate spacing or cutting of components - otherwise, why bother?
However…
the title of this thread includes the phrase “ - a must for MFT3 or custom benches”.
Doesn’t MFT3 imply the Festool product? Why is it a must if it isn’t guaranteed to fit?
Just asking…
Having said that, I wouldn’t mind getting one for my UJK Valchromat top!
MFT/3 owners note -- Parf fence may not work on Festool tops
« Reply #74 on: May 11, 2020, 03:48 AM »
I think that could have been made clearer in the Axminster website copy.
And your video is not clear on the potential incompatibility either.  Starting at 1:43, you say:  "...and on [the parf fence] are a series of holes which match the 96mm centers that we have with our custom work bench or the Festool MFT/3"
I suspect you may not have been aware of the potential incompatibility at the time you published the video.
But none of this should take away from the design and manufacture of the Parf fence;  it is a super design and it is very nicely executed.  The way the dogs sit flush with the top is a great idea, and I thought the clamp stop was an well executed as well.  If it had fit I would have gladly bought a second one as well.
And many on this board do have tops made with the Parf guide system and it will be useful to them.
BUT -- many of us are MFT users like me, and I think the potential incompatibility should be very clearly identified;  hence my post.
« Last Edit: May 11, 2020, 03:28 PM by Tom in SoCal »
Hi Tom
Many thanks for that. I think that having been producing my own tops for my MFT3 for so long now using the Parf Guide System I sometimes miss the reminder about the original Festool tops.
Offline box185
Look back at Post #12 for additional information.
Offline manuc
Yeah I assumed the Festool MFT/3 top was cut to the 32mm system.
I should have read it as “it won’t fit anything unless you buy our Parf Guide system”. Which I planned on doing eventually once I needed to replace my top. I bought two of the Parf fences and now in order to use it I’ll either need to modify the dog or file down the hole on the top for the second Parf...
[sad]
Online Mike Goetzke
Peter, are there any deals in the works to bring this across the pond like some of your other tools, or will we Americans have to order internationally for the foreseeable future?
Axminster shipping is pretty reasonable and almost always faster than ground shipping. I have often found the price to be cheaper because the exchange rate fluctuates and you don’t pay tax....
Seems Axminster is now charging USA sales tax (I'm in Illinois). Anyone else notice this?
Offline TwelvebyTwenty
I do like some of the UJK tools Axminster make. Are they a member here like other retailers?
« Last Edit: July 01, 2020, 01:10 PM by TwelvebyTwenty »
Offline AstroKeith
I took delivery of two Part fences a couple of weeks ago. Had to wait a while so I guess its was new manufacturing batch.
They work fine, (I have a custom made bench), but the quality of finish is appalling considering the price. Machining marks all over one side of each, and clearly not cleaned properly before anodising and dying. Others have had the same issues (look at the recent reviews).
Makes me think twice about buying UJK stuff again, especially when I hear about the drilling guide issues.
Retired engineer/scientist
The Parf fence does look useful. Does the issue of them not fitting the MFT hole layout happen often or is it a rarity based on not guaranteeing accuracy, but more often that not it is accurate?
Offline ben_r_
Reports such as this are actually what has been keeping me from ordering one. I have a problem paying higher prices for simple machined aluminum products that arent at say Woodpeckers finished quality.
I have placed 3 orders this year and I paid NC sales tax on each of them.
Well, I can only say that I bought one after watching Peter's video, and it didn't fit my MFT.  (2 years old FWIW).
So that is close to $100 of my hard earned down the tube.
Don't take the chance unless you can easily return it....
Offline Php54
I bought two Parf Fences thinking I wanted support on both the finished side and waste side of the cut, i.e. both sides of the track.  I made my top using my Park Guide (original version) a few years ago when it first came out.  I bought it from Axminster as well.  The fences don't fit my top either as others have stated.  I can get two of the dogs in at 96mm apart but no way can I spread them out more than that.  Also, I agree with the previous comment about the finish.  It is not a quality finish you wood expect for that price.  I will be writing Axminster to ask to return them.  Very disappointed.  Fingers crossed.
Just to be clear, you're saying even with a top you made using the Parf Guide system, the holes still don't align with the Parf fence?
Offline AstroKeith
[/quote]
[/quote]
I have used the Parf Guide to make a number of work surfaces, and I now have two Parf fences. No problem at all with alignment.
The fences work OK, but cosmetically disappointing. Machining marks and poor anodising.
I am the same as @AstroKeith .  I have made a full 4x8 table and a 4x3 table, both with the MKII system.  I have 2 of these fences and everything works ok.  I also agree with the cosmetics of these things not really being up to snuff though.
If the store was right down the street, I would have returned them but I think it would be too much hassle to return them from the USA.  I have also used standard tall dogs with the large shoulder on the bottom.  I have gotten the same results with those as I have with the fences.
Offline Php54
To answer Twelvebytwenty, I'll try to be more clear.  My Parf Guide top is 3/4 mdf that I made with my Parf Guide System I.  If I insert one flush mount dog that came with the Parf Fence in a hole at one end, I can't insert the second dog in the hole at the other end.  The tolerances don't match up and you can feel it with your finger.  As you progress from one hole to the next in sequence the difference becomes greater.  It is slight but over the course of six holes (7 in the mdf) it exagerates to the point that the dog has no chance of lining up.  Interestingly if I put a dog in each hole next to each other 96mm apart I can force them in both holes.  It doesn't matter which two, 1-2, 2-3, etc.  So the consistency of my drilled holes is there and the consistency of the fence holes are there but they ever-so-slightly don't match.  Hope that helps.
