Author Topic: Festool Hose Adapters for common Tools to work with your CT Dust Extractor  (Read 1397 times)
Offline ToolCurve
The CT dust extractors are some of the best vacs on the market but the the 27mm hose it doesn't always easily fit many common dust ports for the main tool brands. I make a lot of custom ports to work on some of the most popular tools so you can easily use your Festool vac with most your tools. These twist and lock onto your Cleantec 27mm hose.
All Toolcurve's Festool Hose Adapters
Kreg K5 & Foreman Adapter
Dewalt Table Saw Adapter
Festool RAS Adapter
Makita Sander Adapter
Dewalt Miter Saw Adapter
Makita Router Adapter
SawStop Table Saw Adapter
Dewalt Sander Adapter
Makita XDS01z Cut Out Saw Adapter
Dewalt Router Adapter
« Last Edit: September 09, 2021, 07:17 PM by ToolCurve »
Offline ChuckS
I received promo info. about this new product the other day: https://www.rockler.com/dust-right-stacking-dust-port-adapter-set.
But if anyone can come up with an adjustable adapter like the adjustable circle marker, the sky is the limit in terms of potential sales.
Offline tsmi243
I have the Toolcurve piece for the OF1010, it's fantastic.
Question- you list separate parts for all the oval port tools (OF1010, RS2, etc).  Are the adapters actually different in some way, or is this just done for SEO/marketing?
Offline CeeJay
I just ordered the Toolcurve connectors for the Makita trim router and the Mafell P1CC. Thanks for the link!
Offline Imemiter
For applications like the Makita router or Kreg jig I'd be way more interested in whole replacement parts than adaptors. Instead of that one more thing give me less!
CSX T18+3 TID18 HKC55 OSC18 OS400 OF1010 LR32 DF700 RAS115 DTS400 ETC125 CTSys CTMidi CT-VA
Hey @ToolCurve  I like both of these items a lot. Will they also fit in 80/20 extrusions?
Offline ToolCurve
I have thought about that but I know some guys have cheaper vacs along with their Festool and if I did a complete replacement say for the Kreg K5 then it wouldn't work with a standard vac so I figured it would be a little easier keeping and using an adapter but I can see wanting an entire replacement if you are Festool only.
Offline ToolCurve
@Cheese, could you send me a PM with the t slot profile size of your 80/20, I think they should fit but I just want to make sure. I can send you over the exact size of the profile I use.
John
Hey John I certainly will...my guess is that it will fit but that's only a guess. I have a ton of Festools but could never justify spending the money for a shaky table.  [big grin]  You have some nice product and I'm curious if the hose adapter for the DX 93, RS 2, OF 1010 and RAS 115 are all the same item?
Offline ToolCurve
I've updated the original post with links to our Dewalt Sander, Makita cut-out saw, Dewalt router adapter & more.
Offline Chainring
I haven't ordered anything from you (ToolCurve) yet, but holy moly are you on a tear with all these awesome items. The hits keep coming.
Offline Stan Tillinghast
I just ordered 3 vac adapters. Good work!
Für uns...ist das Beste gerade gut genug!
@ToolCurve   You’re got a nice range of adapters and the finish looks very good!
I’d just like to point out that each element in the dust stream ideally should overlap the preceding element. This way the dust never hits an obstruction and when you pull the hose out of the adapter there is no ring of dust to fall.
Most of your adapters fit over the tool’s exhaust port which is very good but in most cases the 27mm hose fits inside your adapter. The Festool 27mm hose has a thick blunt end which makes it particularly unsuitable to use on the inside of an adapter.
If the Festool 36mm hose fits over your adapter that would be ideal. Does it fit well?
