Author Topic: [NEW] OSC 18 Vecturo, AGC 18 Grinder, Kapex KS 120 REB - October 2019 (US)  (Read 2283 times)
Offline Shane Holland
  • Festool Dealer
New tools and accessories are coming October 2019, all of which are available now for pre-order!
Also, just a reminder that the new Bluetooth-enabled CT MINI I and CT MIDI I dust extractors will begin shipping on August 1st.
The ultimate in versatility, the cordless VECTURO oscillating multi-tool combines limitless functionality with exceptional controllability — delivering precise results in the trickiest of places. With tool-less Plunge Base and Depth-Stop (sold separately or included with the VECTURO Set), the VECTURO oscillating multi-tool stands apart, delivering unbelievable control and precision. The StarlockMax tool holder makes it possible to change tools quickly without the need for additional equipment. Additionally, the brushless EC-TEC motor with vibration isolation ensures that work can progress at an ultra-rapid pace at the same consistently high level of comfort.
ORDER NOW
The powerful AGC 18 cordless angle grinder is highly durable and built for the professional remodeler who needs reliable, versatile performance. With its enclosed brushless motor, protected electronics, and variable speed, the AGC 18 is built to last and perform in a broad variety of applications. This powerful grinder is extremely simple to use — with a keyless arbor and guard change, variable speed, and a unique battery position for cut-off operation.
ORDER NOW
Limited Edition Centrotec Set
The MINI-SYSTAINER is ideal for storing small parts and hand-held tools neatly and securely during transportation.
Its key feature is the T-LOC, the central control element, enabling you to lock, open and connect with a single turn.
And thanks to its light weight and handle, it is easy to transport. And the transparent cover means that you have a view
of everything at all times.
New Centrotec Bit Sets
Available as a 6-piece or 12-piece set, these new Centrotec bits sets have Torx, Phillips and Square Drive bits. The 12-piece set also has Pozi Drive bits, as well as coming in a convenient compartment made to store in the attic lid of your drill Systainer.
All bits are also available individually.
ORDER NOW
The KAPEX is the most advanced sliding compound miter saw in the market today — making cuts that rival the finest trim work. Light in weight and heavy in features, the KS 120 is the perfect saw for the workshop or the jobsite. Effective dust extraction, precise cuts, easy adjustments, and quality components are some of the features that should make this saw the number one choice of professional tradesmen.
What's new? The updated Kapex has integrated expandable extension tables, internal changes to the motor have been made to help increase service life, a locking dust port, and newly designed base with integrated MiterFast angle finder stowage location. Additionally, the new crown stops (203356) and crown support board (204536) are available (sold separately).
ORDER NOW
For reliable sanding of completely filled level 4 or 5 surfaces; ensures a very high level of adaptability and an even sanding finish on soft ready-made fillers; processing dry wall filler, plaster, dispersion filler.
ORDER NOW
« Last Edit: July 17, 2019, 11:35 AM by Shane Holland »
877-866-5688
Offline kdzito
What, a new Kapex!!!!!! And internal changes to the motor!!!! Interesting...
Building one day at a time.
Offline elfick
Will there be sanding pads for the grinder making this the replacement for the RAS?
Offline Trevin
@Shane Remind me please...  If I order the grinder now, when do you charge my card?
Thanks,
Trevin
Festool: MFT3 (x2), OF1010, OF1400, LR32, Domino DF500, Domino XL DF700, Kapex KS120, TS-75, Carvex 420, CXS, C-18, Vecturo OS 400, DTS 400, Pro 5, Rotex 125, VAC-PMP, VAC-SYS-1, VAC-SYS-2, CT-26 (x2), CT-SYS, SYS Light DUO, SYS-ROCK
Other: Minmax FS41, Sawstop PCS (3HP, 52"), Laguna BX14, Jet 17" Drill Press, Rikon 70-220VSR Lathe, Incra LS Router Station, Laguna P/Flux 3 Dust Collector
  • Festool Dealer
@elfick, from what I can tell this has a 5/8" M14 thread, but I could be wrong. It may be possible to find a 4½" hook & loop sanding pad for it from another manufacturer. But, at least for now, Festool does not seem to have plans to offer one for the AGC 18 themselves.
@Trevin, we will only authorize your credit card when the order is placed. That just checks with your bank to confirm the availability of funds and places a reservation for those funds. It is not an actual charge and does not incur any financing fees. We will actually charge the card once the item(s) ship on 10/1. This is extremely common practice for all major ecommerce websites.
I will note that if someone uses a debit card (which I highly discourage for online purchases), funds will come out of your account immediately. Similarly, Paypal will deduct funds immediately when the order is placed.
« Last Edit: July 17, 2019, 01:58 PM by Shane Holland »
877-866-5688
Offline ear3
It will be interesting to see what happens to the price of the older model Kapex on the secondary market with this new release.
Offline blaszcsj
@Shane Holland on your guys Instagram post you mentioned an updated hand planer is this true?
OF1010 EQ Router | MFT/3 | DF500Q | Mafell P1CC | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro
  • Festool Dealer
@blaszcsj, well, sort of. I didn't mention it here because it's really not much of an update. The HL 850 is being changed to meet the new IEC 62841 standard which requires that the tool be fitted with a restart lock. This ensures that planer will not start up accidentally after a power failure even if the switch is pressed. So... meh... nothing exciting.  [blink]
Really appreciate that you following us on Instagram -- @toolnut
« Last Edit: July 17, 2019, 07:34 PM by Shane Holland »
877-866-5688
Offline The Wizard
Well, I'm glad I waited on taking the plunge on the Kapex.  Happy to see that pricing has not increased.  It's time to order one.
Thanks for the news Shane.
Offline The Wizard
Looks like there is a new planer as well.
Shane, can you please confirm that only new feature is that the planer will not start up independently after a power failure (regardless of how this happened) even if the switch is pressed. No other improvements? Thanks.
 https://www.festoolproducts.com/power-tools/festool-planers/festool-576612-hl-850-e-planer-in-t-loc-systainer-2019-model.html?SID=8m1o5re7csbganv78pcfkr8tr7
Online Cheese
He already has, see reply #8.
Offline The Wizard
Doh! How the heck did I miss that.  Thanks Cheese.
