Author Topic: Worktop jig  (Read 3024 times)
Offline Peter 50
Worktop jig
« on: July 31, 2017, 02:25 PM »
Does anyone now we're I can get worktop jig pegs from
Offline Distinctive Interiors
  • Modern Kitchen Specialist
    • distinterior.com
Re: Worktop jig
« Reply #1 on: July 31, 2017, 02:33 PM »
Which worktop jig is it...? The Festool alloy one or a resin/phenolic version?
Offline TSO Products
    • TSO Products
Re: Worktop jig
« Reply #2 on: July 31, 2017, 03:41 PM »
not sure I understand "worktop jig".
Do you mean something you can use to make your own 20mm hole pattern on 96mm centers? - like a ParfGuide?
Hans
TSOproducts.com
    • distinterior.com
Re: Worktop jig
« Reply #3 on: July 31, 2017, 04:06 PM »
I assumed he was in the UK coz it's a commonly used description over on this side of the pond.
Here is an example of a jig......
http://www.axminster.co.uk/ujk-technology-700mm-variable-angle-worktop-jig-508615
And a spare set of pegs to fit it....
http://www.axminster.co.uk/ujk-technology-aligning-pins-for-worktop-jigs-508621
Offline tjbnwi
  • Cedar Tucky Indiana
Re: Worktop jig
« Reply #4 on: July 31, 2017, 04:07 PM »
@TSO Products,
Peter must be "across the pond". What we call counter tops they call work tops. A work top jig allows them to put a masons miter (we'd call it a jack miter) into the top and join them at 90ยบ to each other.
Offline Bob D.
Re: Worktop jig
« Reply #5 on: July 31, 2017, 04:40 PM »
Never fit one but their joints look easier than our (US) full miters on countertops.
Especially when you have two closed ends (walls) and a U-shaped top that runs
from wall to wall.
    • distinterior.com
Re: Worktop jig
« Reply #6 on: July 31, 2017, 06:06 PM »
This is an example of what the finished joint looks like when cut with a router and a worktop jig.
40mm thick Duropal particle board laminate worktop/countertop..!
« Last Edit: July 31, 2017, 06:10 PM by Distinctive Interiors »
