Author Topic: Aftermarket Festool Compatible Accessories  (Read 235623 times)
Offline Anderson-Plywood
  • Festool Dealer
  • Ask Us Questions, We Are Here To Help
    • Anderson Plywood Website
Re: Aftermarket Festool Compatible Accessories
« Reply #60 on: June 30, 2016, 12:30 PM »
Anderson Layout Square for MFT is pretty popular and could be a good addition to your list..
Here is the link:
http://www.andersonplywood.com/square-for-festool-mft-square/
Anderson Plywood
Ask Us Questions, We Are Here To Help.
Largest Festool Distributor in Southern California
With a Vast Range of Festool Products, Hard to Find Parts and Accessories
Offline John Stevens
  • Ardmore, PA
« Reply #61 on: February 28, 2017, 08:17 PM »
Did I miss TSO Products?  (I have no interest in this company)
https://tsoproducts.com
What this world needs is a good retreat.
--Captain Beefheart
Offline craigcm
« Reply #62 on: March 08, 2017, 11:41 AM »
Is anybody making aftermarket clamping elements?
Offline guyk
« Reply #63 on: July 09, 2017, 10:27 PM »
just got mine used it all day never once was it out of square unlike the woodpecker one easy to attach and no adjustments needed
Offline scalci
« Reply #64 on: July 10, 2017, 01:44 PM »
Hi Everyone
I just saw this thread, thank you....
Offline blaszcsj
« Reply #65 on: July 10, 2017, 10:29 PM »
Lee valley veritable has some quick action bench clamps for dog holes.
OF1010 EQ Router | MFT/3 | DF500Q | Mafell P1CC | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro
Offline mat
« Reply #66 on: February 10, 2018, 10:19 PM »
Bessey sell both a straight clamp and ratchet clamp identical to the festoon versions for rail/table use. GTR16S6H for the ratchet
Mat
Offline Ralph Mignano
« Reply #67 on: March 21, 2018, 02:57 PM »
For the UK & Europe market for Bench Dogs and Tops, you can visit www.benchdogs.co.uk.
TS 55 R, CTL MIDI, RAILS 1400mm, DF 500 Q, OF 1400, CMS-OF, CMS-GE GB 240V, CMS-TS55, ETS 150/5, BS 75 E, MFT/3, KS120, MFK 700 EQ, T 18+3 FL, CTL 36,PS 420 EBQ, ETS EC 150/3, RTS 400 REQ, FS5000/2, FS 1400/2-LR 32, SYSROCK BR10, VAC SYS Set SE1, SYS3-Set SURFIX, FS-PA, FS-PA-VL, LR 32-SYS
Offline guitarchitect
« Reply #68 on: July 30, 2018, 09:46 AM »
I use the bessey clamps and they are great, and around half of the festool price.
Offline oberlin1
  • Larry
« Reply #69 on: July 30, 2018, 10:10 AM »
I have heard the Festool clamps will not work for a 1 inch thick MDF table with the MFT/3 hole pattern...(guess the festoon table is not as thick).  Will the Bessey ratchets work with a 1 inch deep top?
CXS, ETC-125, TS-75, CT-26E, LS-130, RO-150 FEQ
« Reply #70 on: July 30, 2018, 10:29 AM »
The clamps have a very hard right angle rather than a "swept" or rounded corner, so they can only rotate around a certain thickness when they go into a top... if that makes sense? If I'm not mistaken Festool tables are 3/4" thick. My temporary MFT is 3/4" chipboard and the clamps work in it just fine. I tried putting some 1/4" mdf around a hole while putting a bessey clamp in and out and it doesn't work. The outside of the "elbow" needs more width in the hole to go through the top, and without weakening the corner by lopping off material, it'll never go through.
EDIT: Just wanted to say, if you're stuck with a 1" top you just need to look for stuff that doesn't rely on the bottom of the table for grip. Veritas has a solution that isn't cheap but I'm sure someone else must as well. If you consider the full cost of making the system work I suspect it'd be easier to replace a 1" top with a 3/4" one and go with the more standard accessories
« Last Edit: July 30, 2018, 10:34 AM by guitarchitect »
Offline oberlin1
  • Larry
« Reply #71 on: July 30, 2018, 11:17 AM »
Thanks!  probably have to look for a non-ratcheting solution.
Offline The.Handyman
« Reply #72 on: July 30, 2018, 11:17 AM »
Works fine with 1" top of you just put a slight chamfer or roundover on the underside.
Both of my MFT table tops are 1" thick Baltic Birch plywood.
Sent from my SM-G960U using Tapatalk
Offline John1102
« Reply #73 on: December 20, 2018, 08:20 PM »
Thanks for posting the list.
Offline Job and Knock
« Reply #74 on: February 06, 2019, 12:26 PM »
Trend in the UK sell their own version of the Domino 500 bits:
http://www.trend-uk.com/en/UK/productlist/3/268/dowel_system.html
Useful to know that a Trend agent can supply them
Simplicity is the embodiment of purity and unity
- Shaker maxim
TS 55 - TS75 - Kapex KS120 - OF1010 - OF2200 - Rotex RO150e - Domino DF500Q -  Domino DF700XL
Offline JimD
« Reply #75 on: August 29, 2019, 06:57 PM »
It's been mentioned but I am happy to report CMT bits work on my Domino XL.  My Bosch 5 meter hose also connects to the Domino fine and my Rigid shop vac is pulling the chips out fine.
« Reply #76 on: November 18, 2019, 12:07 PM »
I was on the lookout for some festool-compatible vacuum stuff... for cleanup around the shop I don't think festool's cheaper offerings are worth the price and the bosch version (VAC011) suffers from the same limitations (tiny floor nozzle, tubes are narrow).
I think I finally found the right price/performance compromise - the Ridgid Heavy-Duty Cleaning Kit. For a guy like me who just works in the shop, I don't need another systainer and the tubes are always connected and ready to go anyways. The 36mm fits snugly over the end of the metal tube, and for a really secure fit (although it might distort the hose-end) there's a bump on the metal wand to really grab the vacuum hose. All of the accessories go right over the end of the hose, and as an extra benefit it contained an adapter that perfectly mates my 36mm hose to my sawstop TS guard. The floor nozzle is nice and wide.
For $80CAD I'm a happy camper!
Offline kmickey
« Reply #77 on: November 18, 2019, 11:15 PM »
I picked one of these up at Costco, the Festool hose fits perfectly. I think I paid $40.
https://www.amazon.com/Porter-Cable-PCX18301-4B-Gallon-4Hp-Vacuum/dp/B01H0WP938
Offline ben_r_
« Reply #78 on: January 30, 2020, 05:43 PM »
Nice! Never know about this list before! Excellent thread!
Offline rubber_ducky
« Reply #79 on: January 30, 2020, 05:57 PM »
Mat
Seems that the bessey ratcheting clamps are no longer the bargain that they were in 2018...
Bessey GTR16S6H All Steel Ratcheting Table Clamp with 6 5/16" Capacity x 2 5/16" Throat Depth & 540 lb Clamping Force, Red/Silver https://www.amazon.com/dp/B013UNUOEU/ref=cm_sw_r_cp_api_i_O61mEbG871MKV
Offline xedos
« Reply #80 on: January 30, 2020, 06:07 PM »
 [huh]   sorry , but a plug cutter does the exact opposite of a tenon cutter.
perhaps another link ? ??
« Last Edit: January 30, 2020, 06:10 PM by xedos »
