Hello!
I'm new to the forums and to the craft, but have been slowly building my MFT-style bench (Paulk Smart Bench) as a first project. I'm using the Parf Guide Mark II to make the dog holes and have been struggling with loose fitting dogs no matter what I try.
The dogs always have noticeable play in the hole. It doesn't take any pressure to seat them; there's enough play that they drop in from gravity alone. I reached out to Axminster and after a few exchanges, they sent me a new 20mm cutter that they tested before shipping. I was hopeful this would address the issue, but I get the same loose fit using both of the bits.
Here are 2 videos I recorded showing how the dogs fit (apologies if this isn't the best way to post videos)
https://d2dmppnfx8a8m8.cloudfront.net/parf/parf-loose1.movhttps://d2dmppnfx8a8m8.cloudfront.net/parf/parf-loose2.movI'm following the instructions for the system. The locator pins are fully seated when drilling the pilot holes. I use the pins to align the guide block and even clamp it down to make sure it doesn't lift or tilt while drilling. I'm drilling slowly and pecking as recommended.
I've tested the fit with both the included Parf Locator dogs and also with a pair of TSO Close Fit dogs. I measure dogs both to have a 19.95mm diameter.
I've also tested in a few different materials: Baltic Birch (12mm and 18mm), MDF (12mm), and MDO (12mm). Same result.
I've made sure to use both of the bushing in the guide block. Same result.
I've also tried chucking the bits into my Rockler drill guide to eliminate the guide block and drill runout as a factor. Same result.
At this point I'm questioning my expectations for the product (which seems excellent aside from this issue). Most of the reviews and tutorials rave about a snug dog fit with zero play (
even too snug), but this has not been my experience. To be fair, the loose fit I'm experiencing is probably manageable but I can't shake the feeling that something is off.
How snugly do everyone else's dogs fit in their PGS produced dog holes? Are my expectations the problem or is there some other factor I'm failing to account for?
Thanks in advance for any ideas or suggestions!
Will
