Author Topic: Track Rack  (Read 9901 times)
Offline ryanwichman
Track Rack
« on: August 20, 2019, 06:22 PM »
Hey guys, check this out!  I just got these guide rail holders from FastCap and installed them on my garage door to hold my 55" rail. They work great! No more worrying about finding a place to keep my track saw rail from getting damaged...
303395-0
This can be mounted horizontally or vertically using the included shelf that clips into the backside of it before you mount it to whatever surface you have chosen. Here's their video explaining how it works:
Ryan
Offline CarlsonCarpentry
Re: Track Rack
« Reply #1 on: August 20, 2019, 06:35 PM »
These are great!
I’ve been trying to come up with something like this using a combination of hooks from the hardware section at Lowe’s.
The use I need these for is on my utility truck I have a flip up bin that I store my rails in. I wanted to store these on the lid that flips up. I would have to silicone them instead of screw because I’m not sure how thin the bin lid is.
Anyway these are the perfect solution to my problem.
Re: Track Rack
« Reply #2 on: August 20, 2019, 07:17 PM »
Like so
Offline Alanbach
Re: Track Rack
« Reply #3 on: August 20, 2019, 07:53 PM »
@ryanwichman - Thank you for this! I have been meaning to build something for a while and have just not gotten to it. I can’t stop what I’m doing for $20 so I just ordered a pair. Thanks again!
BTW - I’m not too familiar with Fast Cap’s products. What else do they make that I can’t do without?
Offline ryanwichman
Re: Track Rack
« Reply #4 on: August 20, 2019, 08:52 PM »
@CarlsonCarpentry I definitely see where you are coming from with not wanting to use screws. While screws might not work the best, a small washer and a rivet gun plus a dab of silicone might do the trick.
@Alanbach Glad to hear that these are going to work out for you! Some other things that I like that they sell are their green pro carpenter tape measure. It has the markings on both sides but it is unique because it is readable from both sides of the tape, if that makes sense. No more looking at numbers upside down.
Otherwise, it's honestly too hard to say because they have a ton of useful products. Another one is Kaizen foam if you're a fan of organization. They also sell the Paulk Workbench, if you're familiar with that.
Ryan
Offline Chris Cianci
Re: Track Rack
« Reply #5 on: August 20, 2019, 09:35 PM »
Hi
I agree they have a number of great items. I also like their Mag Shims for setting Router bit or saw blade height, reveal etc etc fascap.com
Offline SonOfMI
Re: Track Rack
« Reply #6 on: August 20, 2019, 09:56 PM »
I know Fastcap has this reputation as a forward thinking company that makes great products, but I wish they would better engineer these products and adopt better quality control. These track racks look like a quick solution and I like their kaizen foam. You can quickly put together tidy and protective organization. But I've gone through a couple of those kaizen knives. I quit buying them because they keep breaking. Those tapes are something else. I really like the featureset in them and will pick up a couple at a time for when I drop or lose one. But I'll be in Peachtree checking 10 just to find 2 that are accurate. So many of these have the hook incorrectly set so the first inch is actually an inch and an eighth. Their metric tapes are off as well. And so are the flat backs.  There are other products from them I've had problems with, these are just two I could think of quickly.
Offline Jim Kirkpatrick
    • My Instagram
Re: Track Rack
« Reply #7 on: August 21, 2019, 09:32 AM »
This is a great tip that I might use.  Thanks for posting
Offline ryanwichman
Re: Track Rack
« Reply #8 on: August 21, 2019, 05:21 PM »
I thought this was pretty slick. Here's an example of them being used in a buddy's van:
Ryan
« Last Edit: August 21, 2019, 05:54 PM by ryanwichman »
Online nicholam77
Re: Track Rack
« Reply #9 on: August 26, 2019, 02:55 PM »
Does FastCap still make these? I am having trouble finding them on their website, or anywhere online. Anyone got a link?
Offline Alanbach
Re: Track Rack
« Reply #10 on: August 26, 2019, 03:04 PM »
Yes they do still make these. I just got mine a few days ago.
https://www.fastcap.com/product/track-rack
Online nicholam77
Re: Track Rack
« Reply #11 on: August 26, 2019, 04:05 PM »
Great, don't know how I missed this, thanks!
Offline Alanbach
Re: Track Rack
« Reply #12 on: August 26, 2019, 05:25 PM »
@ryanwichman - Thank you very much for the heads up regarding FastCap. I received the Track Rack and installed it! Because you responded to me so quickly I was able to add a couple of their green tape measures to my order. I got the 16 footer and the new little one. That little guy is going to come in handy. The bad news is that I have been obsessed with their website and now their catalog. You are really costing me some $$$. I just ordered a Best Fence system and my wish list is growing. 😊😊😊
Offline ryanwichman
Re: Track Rack
« Reply #13 on: August 26, 2019, 07:02 PM »
@Alanbach glad I could help! I got that little tape measure myself, five actually, and have placed one at each of my machines using a rare earth magnet. No more searching for my tape! I have been eyeing those fences as well and think I’m gonna use them for my miter station build.
Offline Alanbach
Re: Track Rack
« Reply #14 on: August 26, 2019, 07:15 PM »
I have an old Delta gravity cart that holds my Makita SCMS. Most of the time it sits in its spot in my shop ready to go for a quick cut but when I have to cut something longer than 6’ or so I have to roll it out onto the driveway and extend the wings. I had been looking for a way to set it up for precise repeatable cuts. I am pretty sure that the Best Fence system is going to fit the bill perfectly. They (Matt) were (was) super helpful and figured out how to do adapt their system for this older uncommon stand.
Offline ryanwichman
Re: Track Rack
« Reply #15 on: August 29, 2019, 10:01 PM »
@Alanbach That’s awesome that they were able to help you out and adapt their system to fit your old miter saw cart. Let us know how the best fence works out for you! I’m looking at doing a permanent miter saw station modeled after Jay Bates’ design and have been on the fence, no pun intended, on whether to use their system or the one jay designed.
Ryan
Offline Alanbach
Re: Track Rack
« Reply #16 on: August 29, 2019, 10:05 PM »
I will definitely do that!
Offline krudawg
Re: Track Rack
« Reply #17 on: September 04, 2019, 04:53 PM »
Ryan
Just mounted my Guide Rail on my Garage Door with the Track Rack.  The install was easy and the quality and functionality were excellent.
Ted
MFT/3, DF 500, Hammer K3 Winner, TS55,  Sjoberg Elite 1500 Workbench, Fuji MiniMite4 Platinum,
Former Marine, Vietnam Vet
Offline ryanwichman
Re: Track Rack
« Reply #18 on: September 05, 2019, 10:39 PM »
@krudawg I'm loving mine as well. I originally only got one set but have since picked up more to outfit my entire collection of rails. I used some 80/20 rail and some 3d printed brackets to set these all up in one spot on my garage door:
Offline ben_r_
Re: Track Rack
« Reply #19 on: September 23, 2019, 06:28 PM »
These are pretty cool! They look like they'd be easy to 3D print if you have a printer.
Offline TSO_Products
    • TSO Products LLC
Re: Track Rack
« Reply #20 on: September 24, 2019, 03:03 PM »
TSO’s stocking up on Track Rack.
Inventory  is on the way to our warehouse now. $ 19.95 / pair
                            https://tsoproducts.com/organization/fastcap-track-rack/
Considering how many woodworkers use their garage as a workshop, garage doors are the most underutilized “wall” space in the shop.
You’re paying for that space – may as well use it!
Insulated garage doors make installation of these TRACK RACK brackets a breeze. If you have hurricane braced doors in the south of the US as shown in the preceding picture you can still make it work as you can see in the picture in the preceding post.
Hans and Eric
Offline Mike Goetzke
Re: Track Rack
« Reply #21 on: September 24, 2019, 05:15 PM »
Hans and Eric
@TSO_Products
Hans/Eric while you are at it can you invent a similar product - TPG/GRS Rail/Square Rack?
Re: Track Rack
« Reply #22 on: September 24, 2019, 05:17 PM »
(Attachment Link)
@ryanwichman Nice design! Can you share more photos/info about the standoffs?
Offline ryanwichman
Re: Track Rack
« Reply #23 on: October 05, 2019, 04:45 PM »
Thanks Mike! The standoffs are nothing more than some 80/20 offcuts I got off their ebay store and then some brackets that I designed and 3d printed. They've been working great so far and I love how they keep all my tracks in one spot.
Ryan
    • TSO Products LLC
Re: Track Rack
« Reply #24 on: November 21, 2019, 09:57 PM »
- Track Rack sets back in stock - again - at TSOproducts.com
First come - first served
Still only $ 19.95 for a pair
Hans
    • TSO Products LLC
Re: Track Rack
« Reply #25 on: December 18, 2019, 03:18 PM »
What makes Track Rack different than some other products on TSO's website?
- woodworkers often buy multiple sets at a time. Just within the last week we had one customer buy 10(!) sets on one order. Two or three set orders are very common.
You can see how this quickly depletes what we thought was a generous inventory supply. So we have been re-stocking and re-stocking to the extent that Fast Cap themselves had any stock.
Now it seems production has caught up with demand and our warehouse shelves prove it. But don't hesitate if you're considering these very handy organizers for your fixed or mobile work space.
Hans and Eric
Offline oneinch
  • I'm a rookie. I measure once and buy twice.
Re: Track Rack
« Reply #26 on: January 11, 2020, 10:23 AM »
I see in many pictures that the track is mounted (horizontally) with splinter the strip down. I'm wondering if anyone can attest to these racks helping prevent the splinter strip from curling off of the track on the ends? For this to be effective the racks would need to be at the extreme ends of the track. I like the functionality of these. If they help prevent delamination of the splinter strip that would be fantastic.
Offline demographic
Re: Track Rack
« Reply #27 on: January 11, 2020, 11:37 AM »
I was wondering about that as I store my rails with the strip facing up, never down.
Offline Alanbach
Re: Track Rack
« Reply #28 on: January 11, 2020, 11:50 AM »
I have had my track stored on the back of my garage door in a track rack for four months now. The tolerances are relatively tight, there is not a lot of slop in there so it does provide a bit of incentive for the strip to stay in contact with the rail at the point of intersection with the track rack. Not sure it is going to solve the delamination problem but if located towards the ends it wouldn’t help make it worse either.
Also, I have seen a lot of people on this site and others discuss their concern with the tracks being stored in track rack with the strip down. I have seen no negative effect whatsoever from this! If a person were really concerned about that you could install the track racks upside down and the strip would be facing up. You can also install these vertically if you want.
Offline Alanbach
Re: Track Rack
« Reply #29 on: January 11, 2020, 12:10 PM »
@ryanwichman - Recent posts brought me back to this thread today and made me realize that I am long overdue to give you some feedback regarding the Best Fence System. They did help me adapt it to my older Delta miter saw stand and were super helpful. Overall I love the system! It is a little pesky if you are setting up and breaking down all the time, but once you get a process down it only takes a couple of minutes to get it dialed in. I ended up with their bench models as they were the easiest to adapt to what I had. If these were installed in a shop on a permanent bench / miter station they would be awesome as once you had it all set up properly you could lock them down and you would be good to go. I bought their crown stops to accommodate wider stock but I haven’t used them yet, I just haven’t felt the need. I bought the original rail sections with the back edge that sticks up as my stock is generally milled before it goes to the miter saw. I have since done two projects that required a ton of pieces cut to the same lengths and it was so fast and accurate that in my mind it immediately justified the purchase. Really a pleasure to use!
