Author Topic: The smaller, 3mm (1/8"?), Domino bit and tennons?  (Read 926 times)
Offline Andrius
« on: December 11, 2022, 07:10 AM »
Hello,
Why there are no smaller, 3mm size Domino bit ant tennons available? They might be usefull in connecting thinnier plywood, such as 8-9mm (3/8"?). Domino tennon might be 3x16x20mm or 3x16x15mm size.
Is it possible to gringe down the smallest available, 4mm bit down 3mm by tool sharpening companies?
Has anyone tried this?
Offline luvmytoolz
Re: The smaller, 3mm (1/8"?), Domino bit and tennons?
« Reply #1 on: December 11, 2022, 07:13 AM »
I would guess they don't make them as they wouldn't be practical.
The sideways forces plunging a narrow bit are enormous, that's why the 4mm only plunges 10mm or so. A 3mm bit would snap the first time it was plunged.
I use 3mm (and smaller) cutters on my cnc all the time, but the motion is a smoothly controlled linear path that gradually deepens.
The aggressive plunge and side to side operation of the Domino push the cutters pretty hard.
Offline Andrius
« Reply #2 on: December 11, 2022, 07:16 AM »
Well, as of plunge speed, this is in total control of the operator of Domino.
Offline luvmytoolz
« Reply #3 on: December 11, 2022, 07:19 AM »
And the cutter swinging sideways WHILE plunging doesn't impact?
This sort of sideways force is the reason 99% of cutters break.
Mind you, if you scale the DOC as compared to the 4, 5, and 6mm cutters, a 3mm cutter would probably be designed to cut to 3-5mm at best, not very useful in general.
« Last Edit: December 11, 2022, 07:29 AM by luvmytoolz »
Offline MikeGE
« Reply #4 on: December 11, 2022, 08:18 AM »
Hello,
If I needed a 3mm tenon for thinner stock, I would use a biscuit cutter instead of a Domino.  As @luvmytoolz wrote, I doubt any 3mm cutter would last long given the aggressive side to side movement.
Offline ChuckS
« Reply #5 on: December 11, 2022, 09:31 AM »
With care, one can easily use the 4mm cutter on 8mm or 9mm thick plywood. I have done three projects with 5mm thick plywood using the 4mm cutter, one example of which is this: https://www.festoolownersgroup.com/member-projects/sorting-trays-(5mm-ply)-done-with-df500-4mm-tenons/#msg662850
Alternatively, the Veritas Domino Joinery Table can be used with a spacer sheet or shims on the table and a 4mm cutter to work on very thin plywood (down to 5mm stock). The Joinery Table, once properly set up, removes the user technique factor.
That said, if someone made a durable 3mm cutter, I'd be interested in it.
« Last Edit: December 11, 2022, 02:12 PM by ChuckS »
