Author Topic: Template for dovetail joints for beams  (Read 1563 times)
Offline zoki4691
« on: October 17, 2019, 04:12 PM »
The template for dovetail joints for the beams.
I love carpentry work and if I can reproduce this template (original and aluminum) I will be very happy.
Of course, I wanted to do measurements x my needs. Make a template  for interlocking for joists, then the measures contained.
I already have right milling, I have the cutter with driving bearing, it just lacks the dima.
Construction material and birch phenolic plywood plywood
305570-0
[ Specified attachment is not available ] [ Specified attachment is not available ] [ Specified attachment is not available ] [ Specified attachment is not available ] [ Specified attachment is not available ] [ Specified attachment is not available ]
« Last Edit: October 17, 2019, 05:10 PM by zoki4691 »
You must not use the money as a your only wealth ,,,
My Festo :   PS 2 , ET 2 , CDD 9.6 ,HL 850 , SR 201 E-AS , AT 65 EB , DX 93 E , RS 100 , RS 400  e
My Festool :  PS 300 trion, PS 400 Carvex  , CTL 48 E ,   DF 700 , RO 150 ,OFK  500 , OFK 700 , RG 150 , TDK 15.6 , CS70 , CMS , OF 1010 , OF 2200 ,HK 55 EBQ , TS 55 REBQ , PL 205 E , SSU 200
Re: Template for dovetail joints for beams
« Reply #1 on: October 17, 2019, 05:47 PM »
Nice job...the phenolic version of the aluminum Arunda system for a lot less than $3300. [smile]
https://www.timberwolftools.com/arunda-dovetailing-mortise-and-tenon-system
Offline zoki4691
« Reply #2 on: October 18, 2019, 05:55 AM »
More photos...
Offline blaszcsj
« Reply #3 on: October 18, 2019, 12:10 PM »
@zoki4691 did you make this pattern or buy it? I am interested in one as well.
OF1010 EQ Router | MFT/3 | DF500Q | Mafell P1CC | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro
Offline zoki4691
« Reply #4 on: October 18, 2019, 12:20 PM »
If you're interested, I'm going to sell it? I did some paterns
Offline blaszcsj
« Reply #5 on: October 18, 2019, 04:01 PM »
Id be interested in purchasing a set for a pergola build in the spring.
Offline Gregor
« Reply #6 on: October 19, 2019, 04:59 AM »
Nice.
Will you share the process of making the templates?
Offline zoki4691
« Reply #7 on: October 19, 2019, 06:03 AM »
Nice.
Pocess Is Biesse Rover 325 [smile]
(Attachment Link)
Offline Gregor
« Reply #8 on: October 19, 2019, 06:12 AM »
Will have to pass on that as I don't have enough space in my shop  [sad]
Offline Bob D.
« Reply #9 on: October 19, 2019, 06:26 AM »
That is a monster bit (#492667). I searched but does not appear to be available in NA. I see the shaft is 12mm. Is a 12mm collet available for the OF1400, I didn't see one in the current Festool catalog.
Offline Gregor
« Reply #10 on: October 19, 2019, 06:29 AM »
The 12mm collet for OF 1400/2200 is #494462 (Spannzange SZ-D 12,0/OF 1400/2000/2200).
« Last Edit: October 19, 2019, 06:35 AM by Gregor »
