I have a very small shop. Last year I made some modifications to my MFT3. To reduce the space behind my table I replaced the hinge mechanism on the guiderail. It has been a huge success. I also bought an extra Festool fence clamp so I could move the fence farther back on my table. It seemed to work until recently I had some cuts which were not consistent with the flip stop. I noticed the fence slipped in the fence clamps. I could not make them any tighter. I also had a slight amount of give in them front to back causing the cuts to not be square. I have decided they are not stable enough to use in the future. I have seen multiple members with solutions to move the fence back. I decided to create a different option and it has worked very well. I thought I would share it.
Using some off cut birch plywood I built two support pieces to attach to rear extrusion, and then attach the fence. It is made of three pieces each. It is far from pretty but I built it with what I had to see if it was stable and met my needs. I was planning on rebuilding with something that looked better but it works so well I may not.
I cut all the pieces down from three scraps I had. I was careful to make cut each layer from a single piece so they would be as close as possible to the same thickness. The first two back pieces were originally glued together as they provided support and from there I rested a small piece on the table and then glued it so it matched the table height. I did route a small rabbet on the second piece so the it also provided a bit of support.
I sanded down a couple of machine screws that would fit into the slot of the Festool guide. (It would be nice to someone new of a TBolt that fit.) The fence is attached to the support with one machine screw with a nob and the support has 2 bolts attaching it to the table.
It is completely solid and is easy to take on and off. It cost me about $10 because I bought the knobs. I had originally tried to figure out pieces from 8020 that might work but was unable to without some custom cutting. This may be better made out of Baltic birch or MDF but this is what I had to work with at the time. I will watch to see if it gets any less stable but so far so good.
I am open to any comments, suggestions or watch outs.
Original post on Hinge and Festool clamps.
http://festoolownersgroup.com/festool-jigs-tool-enhancements/mft-3-ideas-for-small-shop/I hope the new pics make sense.
Hal II
