Author Topic: LR32 enhancement via TSO square & parallel guides  (Read 3155 times)
Offline crustacean
« on: June 07, 2020, 12:08 PM »
Perhaps this is already known, but I found a nice way to use my TSO guide rail squares and parallel guides to do a job that would otherwise have been tedious with the LR32 as sold by Festool.
I was trying to install a three sets of Blum drawer slides in a cabinet. Two of the three were quite far in to the middle of the cabinet. The first hole position is 37mm from the gable edge, standard for Blum. This is not straightforward with the LR32, since there's no 37 mm spacer, nor an easy way to quickly set up the rail accurately in the middle of a big panel, unless you are reasonably close to the edge.
Solution: I glued together a 5mm and 6mm domino to make an 11mm spacer. Using I then used the 16mm Festool spacer and butted the dominoes between that spacer and the gable edge. This offsets the rail so that the first LR32 hole is at 5mm. Then the second one is at 5+32 = 37mm, as desired.
Once that was set up, I simply attached the TSO square to the rail and set it up flush to the workpiece and locked it in place. From that point on, I could simply remove the Festool stop and dominoes, use the TSO square to place the rail with the correct offset for all subsequent holes.
As for the placement of the rail in the middle of the panel, that's easy once the TSO square is in place. Just use the TSO parallel guide and index from the edge of the workpiece at the back of the rail (this is the opposite side from the one Festool uses).
-- Nike
« Last Edit: June 07, 2020, 12:11 PM by crustacean »
Offline Stan Tillinghast
Re: LR32 enhancement via TSO square & parallel guides
« Reply #1 on: June 07, 2020, 12:13 PM »
Interesting, I’m going to keep this “improv” in mind.
Question: I have not seen the word “gable” used in this context, nor does Wikipedia help. Can you please explain what the “gable edge” is?
Für uns...ist das Beste gerade gut genug!
Offline kmickey
« Reply #2 on: June 07, 2020, 12:56 PM »
Vertical/side  panel. Dave Stanton just used the term in his latest video.
Offline Bugsysiegals
« Reply #3 on: September 11, 2020, 11:58 PM »
You must have been placing the rail front front to back or parallel with the drawer slides, correct?  I believe the rail is meant to go perpendicular and then using the alignment bars you’d be able to achieve your 37mm setback. Unfortunately, in this position, you’re unable to reach the middle holes of drawer slides. I’m trying to think of a repeatable method but am almost considering to just drill the first and last hole with LR32, install the drawer slide, and use a drill with Vix bit for the centers ...
Offline tsmi243
« Reply #4 on: September 19, 2020, 07:44 PM »
Yeah, we need pics.  It sounds like you're using the LR32 sideways to me.
Offline StanB
« Reply #5 on: September 20, 2020, 06:41 AM »
I do something similar with the woodpecker pgs. I got tired of taking the front bits on and off.
OF1010 EQ Router | MFT/3 | DF500Q | Mafell P1CC | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro | VAC SYS SYSTEM SET | MX 1200 E MIXER | DF700 XL | PDC 18 | TID 18
Offline Coen
« Reply #6 on: September 28, 2020, 09:14 AM »
(Attachment Link)
That looks nice, but even more expensive than the LR 32 set itself.
Also; your rail is too short. (I hope Festool will read this and finally make a holy 3000 rail.)
The Ikea Pax cabinets can be bought in 2,36m high and Festools longest LR-32 rail is 2424... a shame really.
Offline StanB
« Reply #7 on: September 28, 2020, 12:13 PM »
(Attachment Link)
I had the PGS kit for saw applications, just figured I could use it here as well so I did not have to take off the other bits all the time.
In this particular case, it did not matter the rail was short. I was only doing a couple upper hole sets. In the past, I just used the fact it was on a parallel edge and slid it down the side using the router in one of the existing holes to index.
Offline etds4u
« Reply #8 on: September 28, 2020, 03:40 PM »
For the mid-panel row of holes, I use the LR32 guides to position the front row of holes only, then I attach the TSO parallel guides before removing the LR32 guides. The TSO guide settings are arbitrary at this point since I just use a spacer block to get dead-on spacing between the front row and the mid-panel row (224 mm spacing shown. Ensures perfect slide mount hole alignment).
Offline Mario Turcot
« Reply #9 on: October 02, 2020, 12:11 AM »
I have 3 Pax cabinets and they all came with LR 32 already. You want to make more holes?
« Last Edit: October 02, 2020, 01:03 PM by Mario Turcot »
Mario
Offline Rick Herrick
« Reply #10 on: October 02, 2020, 08:25 AM »
Thanks @etds4u .  This is a very interesting idea.  I also like the idea of using my TPG system without having to break out the GRS squares.  Guess I need to look into the guide rail adapters you have here.
Offline Sparktrician
« Reply #11 on: October 02, 2020, 08:56 AM »
You can also reverse the Festool edge guides on the rail to get the mid-panel holes.
- Willy -
Offline jobsworth
  • Festool Baby.....
« Reply #12 on: October 02, 2020, 11:59 AM »
Jason Bent has a good video on the LR 32. He shows a jig that he got from Peter Millard
