Author Topic: Quick Disconnect Fittings for VAC SYS Lines  (Read 1824 times)
Offline MikeGE
« on: November 23, 2020, 08:36 AM »
 I apologize in advance for asking what might be a stupid question.
I want to modify the vacuum lines on my VAC SYS for use with my new MFT-style workbench.  I'll post photos later, but I have the vacuum pump on a pull-out tray, where it will remain most of the time.  The SE1 will be attached to the side of the workbench when in use, and stored on a pull-out tray above the vacuum pump when not being used.  The SE1 will be about three feet from the pump, so I don't need the long hose currently attached to it, as it just gets in the way.  I will disconnect the vacuum line from the pump and can coil it around the SE1, but I can't disconnect the foot switch...yet.
I would like to add quick disconnect fittings so I can remove the hoses for easier storage, and also shorten the lines a bit.  Ideally, I would have two sets of hoses, one for the workbench and the original hoses kept in the Systainer for those times when I take the VAC SYS out of my shop.
Can the same quick disconnect fittings used for compressor lines be used for vacuum lines?  If not, which fittings are compatible with the VAC SYS?
Offline rst
Re: Quick Disconnect Fittings for VAC SYS Lines
« Reply #1 on: November 23, 2020, 10:04 AM »
The foot switch is attached to the head with a push/pull fitting so the hose can be disconnected.
Offline MikeGE
« Reply #2 on: November 23, 2020, 10:44 AM »
The hoses on my SE1 are crimped.
Offline rst
« Reply #3 on: November 23, 2020, 11:05 AM »
The foot switch hose on mine has a push/pull where it engages the head.  I haven't used mine in a while, moving shop, I may have left suction hose attached.
Offline FestitaMakool
« Reply #4 on: November 23, 2020, 03:05 PM »
Hi Mike,
I’d bring the items you’ll like quick connect couplings to, to a assorted pneumatic seller or whole seller.
They might have more neat couplings ala Festool ones to order - then you’ll need to know the dimensions, therefore bring the gear  [smile] Though it looks like 1/4” fittings (judging by the photo...) there are different dimensions on the male and female as well as the threaded part - like the brass hose/clamp fitting on the foot pedal.
You might check out dealers into Metal Work pneumatic, chances are that they carry even more brands. And why not Festo?
https://www.festo.com/cms/de_de/index.htm
https://www.metalwork.de/
Offline MikeGE
« Reply #5 on: November 23, 2020, 08:27 PM »
Hi Mike,
Thank you for the links!
This is the thread that caught my attention to the possibility of modifying the VAC SYS lines:
My Vac-Sys setup
Unfortunately, scholar's PCL links are no longer valid, but I found the new website and will do some research.  I remembered I had a new compressor hose in the garage, still sealed in the bag, and it worked great when I inserted it between the vacuum pump and the Festool quick disconnect.  I couldn't see any difference in the vacuum pulled with or without the compressor hose, so as @Cheese said in the other thread where I originally commented, this is not a life or death situation and the compressor fittings work.
« Reply #6 on: November 24, 2020, 10:03 AM »
FWIW...the tubing on my foot valve is also installed directly into it and crimped with Oetiker ear clamps.
Offline Bob D.
« Reply #7 on: November 24, 2020, 01:30 PM »
Keep in mind that with a vacuum system every connection is a potential leak.
Make sure any quick connect fittings you choose are rated for vacuum as many are not.
Offline MikeGE
« Reply #8 on: November 24, 2020, 02:39 PM »
I ordered new fittings from PCL Air Technology in the UK.  These are the fittings that @scholar recommended.
AA7114 XF Adaptor Plug with Tailpiece for 9mm Hose
AA7103 XF Adaptor plug with R 3/8 Male Thread
AC7109 XF Coupling with Tailpiece for 9mm Hose
AC7106 XF Coupling with Tailpiece for 6mm Hose
I will put the AA7103 on the foot switch and SE1 slide control.  The AA7114 will go on the SE1 line just as it clears the head.  The AC7109 couplers will go on the Festool hoses where I cut them.  Since these hoses will be about the standard length, they will go back into the Systainer for storage.
The AC7106 couplers will be used on 6mm line I already have and will be cut to fit for my use on my workbench.
Offline Richard/RMW
« Reply #9 on: November 24, 2020, 06:51 PM »
I haven't confirmed this yet but believe the readily available high flow fittings are compatible. Lots of jabber in this thread.
Otherwise, I found the euro style fittings on McMaster for not too many pesos. Info in the same thread.
RMW
Offline rvieceli
« Reply #10 on: November 24, 2020, 07:53 PM »
Hey @Richard/RMW Lowe’s is closing those out for $5
https://www.lowes.com/pd/Kobalt-High-Flow-Fittings/1000404949
Looks to still be available online
Ron
Offline Richard/RMW
« Reply #11 on: November 24, 2020, 10:04 PM »
Ron
Thanks Ron, got to run my pre-holiday long-weekend errands tomorrow so I'll hit Lowes for a few. Also Fazzios for some random metal.
RMW
Offline MikeGE
« Reply #12 on: December 02, 2020, 10:25 AM »
The fittings from PCL arrived yesterday and are now in place.  The 9mm tube fitting was a bit tight, so I put the end of the tube in hot water to soften it and it fit over the nipple much easier.  The 6mm tube fittings didn't require any heating.
The OEM hoses have female quick disconnect fittings on both ends, and will be stored in the SE1 Systainer.  I cut part of the existing blue air line to make the shorter hoses, and am still able to use the air line for my shop.  The new hoses and fittings hold the vacuum as well as the OEM connections.
Everything disconnects quickly and stores easily out of the way.  The foot switch and blue lines are stored in the end drawer with the other SE1 head adapters.  (yes, I forgot to put the protective cap on the vacuum pump before taking the photo)
