Author Topic: Supercut with Festool Vecturo plunge attachment. It works!  (Read 33910 times)
Offline Magpal
Re: Supercut with Festool Vecturo plunge attachment. It works!
« Reply #30 on: April 09, 2017, 07:44 AM »
I am bringing this thread up again as things may have changed with the new Starlock blades. I have a couple of questions regarding the compatibility of the plunge base:
-Will the plunge base also fit for the new starlock multimaster? Has anyone tried this? How large is the gap in between the magnet and the blade?
-Does the plunge base fit without the gap on the supercut or does this also has the small gap between the base and blade?
Offline Bob D.
    • My Cordless Workshop
« Reply #31 on: April 19, 2017, 07:35 AM »
Anyone know if this should also work with a multimaster? Not sure if they use the same housing
I'd like to know the answer to this too. I have the FMM250Q and curious if this will work for me.
Offline rst
« Reply #32 on: April 19, 2017, 09:44 AM »
I have the Supercut and the Festool plunge attachment works perfectly unless you are using the adapter to use the regular multimaster blades.  The adapter holds the multimaster blades out further than the magnet on the plunge attachment.  The plunge attachment does not fit the regular multimasrter...the drive heads are not the same.
Offline Bob D.
« Reply #33 on: April 19, 2017, 10:03 AM »
Hmmm, sounds like I need to let go of my Fein and get the Vecturo if I want the capabilities of the depth stop and plunge base which are both great accessories in my view.
Offline grobkuschelig
« Reply #34 on: April 19, 2017, 05:02 PM »
Hmmm, sounds like I need to let go of my Fein and get the Vecturo if I want the capabilities of the depth stop...
If I recall correctly, a depth-stop is available from Fein directly. But the plunge base is Festool only...  [sad]
