Author Topic: Fixture made to drill Domino joints across an arc accurately on tangent  (Read 842 times)
Offline woodbilder
319495-0
/Users/test/Downloads/Dry fit copy.jpeg
I am drilling five accurate tangential back splats in each of six chairs. Some will scoff at the work gone to but if you have orthopedic hand issues, or replacement joints (shoulder), you will have a different perspective. The chair is built to plans from Fine Woodworking, Spring, 2006.
The issue on this segment of the project is to conform to the semicircular back rails, spacing five tenons (Dominoes) across the width in tangent alignment with the arc, r.=36".
The back rails were cut on MDF jigs in same fashion as a circle cutting jig for the band saw pivoting about a known distance and ⅛" dia. pin through the bandsaw.
https://www.festoolownersgroup.com/festool-jigs-tool-enhancements/subject-to-follow/?action=dlattach;attach=319474;image
Since the patterns were repurposed, the rails were assured of being an accurate match for drilling, noting that the mortises in question are drilled into the EDGE of the rail.
https://www.festoolownersgroup.com/festool-jigs-tool-enhancements/subject-to-follow/?action=dlattach;attach=319479
The Domino rests on the new fixture and the workpiece is advanced across the arc, keeping thge tool in one location.
https://www.festoolownersgroup.com/index.php?action=dlattach;topic=63913.0;attach=319473;image
« Last Edit: August 16, 2020, 04:24 PM by woodbilder »
Start slow, wind down gracefully
Offline rst
Very creative work around...kudos
Offline ChuckS
Great problem-solving thinking. [thumbs up] The DF is such a versatile machine that its limitation is only defined by its owner.
Are those the Rodel's chairs?
Offline woodbilder
Sorry Chuck, but I am not familiar with Rodel's chairs. Help me out.
Offline ChuckS
Here: https://www.kevinrodel.com/showroom/item/dining-chair
I have had the plans for his dining chairs for years, but never got to make any (because there were more than enough around!). I recently sold my dining set including 6 chairs, and am in the market for new chairs. But his A & C style won't fit the table I've made, so I'm going to build 4 chairs of a different style. Needless to say, they'll be built using the DF500. (Rodel milled the mortises with a router and jig: https://www.finewoodworking.com/2006/01/17/making-an-arts-and-crafts-chair.)
« Last Edit: August 16, 2020, 05:26 PM by ChuckM »
