Author Topic: Parf Guide mark 2 issues and questions  (Read 49369 times)
Offline Rta108
Re: Parf Guide mark 2 issues and questions
« Reply #240 on: August 08, 2019, 05:37 PM »
Just as of last night I just finished drill all holes, cutting all parts to size and also have begun assembly.  As such, I have not yet been able to test it all out yet.
What is the issue with you having three sets of rules/sticks?
I checked in at post #196 of this thread with my first set of problems.
Offline ChiknNutz
« Reply #241 on: August 09, 2019, 09:38 AM »
While I have not yet begun to use the table, it seems to me if there were issues with the hole spacing, I would have long discovered them by now.  I have made 5 separate surfaces with 20mm holes, ranging from 2 rows & 7 columns up to 9 rows & 16 columns.  I have used both sticks interchangeably and in no particular orientation.  If something were off, either the sticks or the drill jig would have highlighted the inaccuracy during the process.
-Chris
Rotex 150/5 FEQ, CT 36 E, ETS EC125/3, TS75, Domino XL
Offline Rta108
« Reply #242 on: August 09, 2019, 01:11 PM »
Probably right.
My use of the system did not go smoothly as you describe.
Offline ChiknNutz
« Reply #243 on: August 09, 2019, 02:16 PM »
I will state for the record that while almost all of the kit is superb, the edges of the holes in the Parf Sticks do leave a bit to be desired.  I don't have a picture of them, but can confirm they do look similar to what you posted earlier, though not the extent.  However, the thru holes are true and properly in line and the imperfections noted do not seem to affect the accuracy of the product.
-Chris
Offline Solly1
« Reply #244 on: August 09, 2019, 08:06 PM »
@ChiknNutz I would be curious to hear with your completed tables, if you insert 3 dogs along a row of holes and place a known accurate straight edge across them (testing from both sides of the dogs), whether you notice any discernible "rock" in the straight edge whilst moving the centre dog to various holes in between the end dogs. Test various rows and columns.
Offline ChiknNutz
« Reply #245 on: August 10, 2019, 06:14 PM »
I did as you asked and did not see any noticeable deviation in the linear hole relationship. I tried this in rows and columns as well as diagonally in various positions.
-Chris
« Reply #246 on: August 12, 2019, 01:45 PM »
 Silly question; Asumming, as I have, that the Parf guides space the holes at 96mm on center, is that the same spacing that is used by Festool?
 I am asking because I am curious to learn if Festool MFT accessories meant to be aligned with two or more holes will also adapt to a DIY bench top made with Parf guides.
 For example; Is an item like this going to work when I get finished making my bench top with the Parf guides?:
 Thank you!
« Last Edit: August 12, 2019, 02:15 PM by Woody Knotsensplintahs »
Offline neilc
« Reply #247 on: August 12, 2019, 04:28 PM »
Woody -
Yes Festool and many third parties using 20mm holes have standardized on 96mm hole spacing.  Perf Guide works great for creating tops that can use these accessories.
« Reply #248 on: August 12, 2019, 05:45 PM »
Thank you!
I am new to MFT use and appreciate the helpful info.
Offline Dusty.Tools
    • Dusty.Tools
« Reply #249 on: August 19, 2019, 01:27 PM »
Hi All,
Does anyone have a trick or tip for using the Parf Guide with laminate? I created a small top, as a test, and it worked perfectly. However once the cut gets through the laminate, the laminate breaks off from the MDF and stops the drill bit from going any further. Unfortunately even with the bit full retracted it's impossible to hook it out from under the drill bit, so I had to lift up the guide off the table. This process still leaves a perfect hole, it just takes longer....
Cheers
Ben
@dusty.tools
Offline ben_r_
« Reply #250 on: August 21, 2019, 06:44 PM »
Urgh! Does anyone know WHY the UJK Technology Chamfer Tool was designed without a way to attach it to a drill??? My pointer finger and thumb ache just THINKING about sitting there rotating HUNDREDS of holes each on both sides just to complete one table top! Being that the tool is designed to bottom out to not over chamfer, why wouldn't it be used with a drill?!
Offline Solly1
« Reply #251 on: August 21, 2019, 07:02 PM »
Although I have the chamfer tool, I used a trim router to do a 8 x 4 top with around 200 holes. Much easier, took maybe 20mins.
Offline ben_r_
« Reply #252 on: August 21, 2019, 09:34 PM »
Yea Im thinking the trim router with a chamfer bit is a must with this application. Im just so surprised anyone thought it would be a good idea to release the UJK Technology Chamfer Tool designed as it is.
Offline Jiggy Joiner
« Reply #253 on: August 22, 2019, 08:34 AM »
@Dusty.Tools  Ben, do you mean the breakout on exit, underneath, or the initial cut at the top?
@ben_r_  I really love the PGS, I think it’s a great invention but, I alway chamfer the holes with a router and chamfer bit.
I like using the Parf dog system, so I chamfer all my tops and the router is a fast solution.
The chamfer tool is fine though if you just need to do a few holes for a cutting station, or don’t own a router.
Offline Dusty.Tools
    • Dusty.Tools
« Reply #254 on: August 22, 2019, 08:36 AM »
In the initial cut, I end up with a little round disc of laminate.
@dusty.tools
« Reply #255 on: August 22, 2019, 08:59 AM »
Ah ok, got it. You might need a different type of forstner bit, or maybe the Festool 20mm Euro hinge boring bit, I think Bosch make on as well.
Some of these type have a sort of serrated bottom, that should cut through the laminate. I think they are, or were expensive though.
Offline Peter Parfitt
  • Magazine/Blog Author
« Reply #256 on: August 22, 2019, 04:05 PM »
The clean exit hole of the UJK 20 mm cutter is the reason that the disc is there after a cut. On exiting, the hole is quite clean and so a neat little circular disc is formed by the wings of the cutter.
Offline ben_r_
« Reply #257 on: August 22, 2019, 05:49 PM »
Wow, just added the Mark II system with the dust collection piece to cart and shipping (to California) from both Axminster and TSO Products and wow what a price difference!
Axminster: Parf Mk II Guide System ($175 USD) + Parf Dust Port ($26 USD) + Shipping ($10.06 USD) = $211.06 USD
TSO Products: Parf Mk II Guide System ($229.95 USD) + Parf Dust Port ($34.95 USD) + Shipping ($21.34 USD) = $286.24 USD
Saved me $75! Hopefully this saves someone else some money too! Can put those saved funds to some Parf Dogs for your new bench!
And wow I had no idea UJK made/rebranded so many other tools! (LINK)
EDIT: Soooo, to update this post, it appears now TSO lowered its prices and Axminster raised them. Go figure.
« Last Edit: September 20, 2019, 06:38 PM by ben_r_ »
« Reply #258 on: August 22, 2019, 06:33 PM »
Hi Peter, I think Dusty is saying that on the initial cut, the bit is cutting a laminate disc, and will not cut any further/deeper until the disc is removed. He cannot clear the disc without removing the jig though.
Unless I’m mistaken?
JJ
Offline ChiknNutz
« Reply #259 on: August 22, 2019, 09:39 PM »
I unfortunately did not know to price check until well after the fact.  Was a bit perturbed that TSO adds such a markup, but buyer beware!
-Chris
Offline Rta108
« Reply #260 on: August 23, 2019, 04:15 PM »
...AND I’m betting international DHL package gets to you faster than domestic UPS.
Offline ChiknNutz
« Reply #261 on: August 23, 2019, 04:21 PM »
I'd like to state for the record that Hans from TSO both emailed and called me regarding this price discrepancy.  I won't elaborate on the specifics, but will say their response is more than acceptable...especially given I never even asked for anything from them directly.  I just chalked it up to me not doing my due diligence (which I almost always do to a fault).  So I will say that TSO continues to be a great company to deal with.
-Chris
Offline Dusty.Tools
    • Dusty.Tools
« Reply #262 on: August 23, 2019, 06:11 PM »
It does yes! I just ordered a few parts and it'll be in Seattle on Monday!
@dusty.tools
Offline Dusty.Tools
    • Dusty.Tools
« Reply #263 on: August 23, 2019, 06:12 PM »
JJ
That's correct yes. It's a little disc of laminate which stops me cutting into the mdf.
@dusty.tools
Offline ben_r_
« Reply #264 on: September 03, 2019, 06:53 PM »
What is the size of the shaft for the 20mm cutter bit? Thinking of ordering a better stop collar for it, stainless or hardened steel or something, and need to know what size to get.
Offline TSO Products
    • TSO Products
« Reply #265 on: September 03, 2019, 07:48 PM »
@ben_r_   - until AXMINSTER replaced the (less than optimal) collar and screw TSO added a 10mm,  Stainless Clamping Collar to all Parf Guides we sold. We still have a few of those left - also in Steel. Email your last TSO order number and we'll send one at no charge to that address,
Hans
TSOproducts.com
Offline Dusty.Tools
    • Dusty.Tools
« Reply #266 on: December 28, 2019, 09:01 PM »
Hi All,
I need some advice on using the Parf Guide Mk2 that I have.
When I purchased it, I created a small 30 hole top and it came out perfectly square.
This weekend I started working on a 50 hole and a 150 hole top. I started with the 50 hole top and used the locking screw pin to create the triangle. There's a very little wiggle in this setup, maybe 1mm. I have only done the pilot holes, but everything appeared to work out well based on eyeballing everything using a square.
When I went to do the 150 hole top I used the drill bushing with the long locking collar. In this position there's quite a considerable wiggle. You can see it in this video:
https://www.instagram.com/p/B6oiQ_DgpBT
I decided to push on, and tried to line up the rule using a square. Unfortunately this didn't work because as I moved up the top drilling each row, the ruler started to bow when it was locked into place. By the 9th row it was almost impossible. I attempted to improvised by using the Pythagoras method to attempt to do each row but the right hand column is definitely not parallel with the left hand column.
As an aside - When I line up the two rulers, using the locking pin in #0 hole, I noticed that #10 holes are not aligned, maybe 1mm off. I am not sure this would be the cause of the issue... Photo below.
Has anyone else seen this? I am not entirely sure what parts are not as accurate as needed.... Or is a ~3mm difference across a 1000mm top with in accepted tolerances?
Ben
@dusty.tools
Offline Mike Goetzke
« Reply #267 on: December 29, 2019, 11:04 AM »
@Dusty.Tools
What version rules (sticks do you have)? Maybe this is the issue? Took me three sets to get it right - we'll plus some light filing and surface grinding.
Mike
« Reply #268 on: December 29, 2019, 11:52 AM »
Hi Ben @Dusty.Tools
How long ago did you buy the PGS? There was an issue with a few of the rulers a while back and Axminster sacked one of their subcontractors and brought the manufacture in-house.
Offline box185
« Reply #269 on: December 29, 2019, 12:26 PM »
Hi Ben @Dusty.Tools
When was the subcontractor sacked? It would be nice to understand if any of the PGS II systems that I purchased included the new sticks - I‘ve seen too many issues.
