Author Topic: Parf Guide mark 2 issues and questions  (Read 72483 times)
Offline wozzman
Re: Parf Guide mark 2 issues and questions
« Reply #210 on: August 08, 2019, 07:51 AM »
I have been using my recently rec'd MKII set for a table with several panels, used it again last night even.  I notice no perceptible play between the mating parts.  The largest grid I have made so far is 9X16 and I had no issues with any of the holes lining up properly with the Park rules.  Do you also see this with the 3mm locator pins?
The 3mm pins locate perfectly into the drilled hole. ZERO play, nice very firm fit. The 6mm guide that slots into the parf stick to drill the 3mm hole is almost exactly 6mm. Again, extremely well made. But the holes in the stick itself are, as I mentioned earlier, approx 6.17mm. I will say, although the holes are 6.17mm they are ALL 6.17mm or thereabouts making whatever happened consistent across the two sticks I have... strange.
As an update, Axminster replied earlier and they have said that the tolerances should be somewhere between 6.01-6.04mm, which is what I would have expected. So will be sending them in for an investigation and new ones coming out. Appreciate them sorting that out.
Offline Rta108
« Reply #211 on: August 08, 2019, 03:41 PM »
Getting straight lines of holes? That’s good to hear. Have you had a chance to line up a track saw cut with dogs yet?
Neither of my first two sets of sticks were loose at all. Very tight hold with 3mm pins.
I have a third set of sticks coming in the mail now. Axminster says these were checked and tested. Also included a new pair of 3mm drill guides for some reason. Hopefully they aren’t having a new issue.
Offline ChiknNutz
« Reply #212 on: August 08, 2019, 04:37 PM »
Just as of last night I just finished drill all holes, cutting all parts to size and also have begun assembly.  As such, I have not yet been able to test it all out yet.
What is the issue with you having three sets of rules/sticks?
-Chris
Rotex 150/5 FEQ, CT 36 E, ETS EC125/3, TS75, Domino XL
Offline Jiggy Joiner
« Reply #213 on: August 08, 2019, 05:16 PM »
There should be no noticeable play between the pins and rules/sticks.
Offline Rta108
« Reply #214 on: August 08, 2019, 05:37 PM »
I checked in at post #196 of this thread with my first set of problems.
Offline ChiknNutz
« Reply #215 on: August 09, 2019, 09:38 AM »
While I have not yet begun to use the table, it seems to me if there were issues with the hole spacing, I would have long discovered them by now.  I have made 5 separate surfaces with 20mm holes, ranging from 2 rows & 7 columns up to 9 rows & 16 columns.  I have used both sticks interchangeably and in no particular orientation.  If something were off, either the sticks or the drill jig would have highlighted the inaccuracy during the process.
-Chris
Offline Rta108
« Reply #216 on: August 09, 2019, 01:11 PM »
Probably right.
My use of the system did not go smoothly as you describe.
Offline ChiknNutz
« Reply #217 on: August 09, 2019, 02:16 PM »
I will state for the record that while almost all of the kit is superb, the edges of the holes in the Parf Sticks do leave a bit to be desired.  I don't have a picture of them, but can confirm they do look similar to what you posted earlier, though not the extent.  However, the thru holes are true and properly in line and the imperfections noted do not seem to affect the accuracy of the product.
-Chris
Offline Solly1
« Reply #218 on: August 09, 2019, 08:06 PM »
@ChiknNutz I would be curious to hear with your completed tables, if you insert 3 dogs along a row of holes and place a known accurate straight edge across them (testing from both sides of the dogs), whether you notice any discernible "rock" in the straight edge whilst moving the centre dog to various holes in between the end dogs. Test various rows and columns.
Offline ChiknNutz
« Reply #219 on: August 10, 2019, 06:14 PM »
I did as you asked and did not see any noticeable deviation in the linear hole relationship. I tried this in rows and columns as well as diagonally in various positions.
-Chris
« Reply #220 on: August 12, 2019, 01:45 PM »
 Silly question; Asumming, as I have, that the Parf guides space the holes at 96mm on center, is that the same spacing that is used by Festool?
 I am asking because I am curious to learn if Festool MFT accessories meant to be aligned with two or more holes will also adapt to a DIY bench top made with Parf guides.
 For example; Is an item like this going to work when I get finished making my bench top with the Parf guides?:
 Thank you!
« Last Edit: August 12, 2019, 02:15 PM by Woody Knotsensplintahs »
Offline neilc
« Reply #221 on: August 12, 2019, 04:28 PM »
Woody -
Yes Festool and many third parties using 20mm holes have standardized on 96mm hole spacing.  Perf Guide works great for creating tops that can use these accessories.
« Reply #222 on: August 12, 2019, 05:45 PM »
Thank you!
I am new to MFT use and appreciate the helpful info.
Offline Dusty.Tools
    • Dusty.Tools
« Reply #223 on: August 19, 2019, 01:27 PM »
Hi All,
Does anyone have a trick or tip for using the Parf Guide with laminate? I created a small top, as a test, and it worked perfectly. However once the cut gets through the laminate, the laminate breaks off from the MDF and stops the drill bit from going any further. Unfortunately even with the bit full retracted it's impossible to hook it out from under the drill bit, so I had to lift up the guide off the table. This process still leaves a perfect hole, it just takes longer....
Cheers
Ben
@dusty.tools
Offline ben_r_
« Reply #224 on: August 21, 2019, 06:44 PM »
Urgh! Does anyone know WHY the UJK Technology Chamfer Tool was designed without a way to attach it to a drill??? My pointer finger and thumb ache just THINKING about sitting there rotating HUNDREDS of holes each on both sides just to complete one table top! Being that the tool is designed to bottom out to not over chamfer, why wouldn't it be used with a drill?!
Offline Solly1
« Reply #225 on: August 21, 2019, 07:02 PM »
Although I have the chamfer tool, I used a trim router to do a 8 x 4 top with around 200 holes. Much easier, took maybe 20mins.
Offline ben_r_
« Reply #226 on: August 21, 2019, 09:34 PM »
Yea Im thinking the trim router with a chamfer bit is a must with this application. Im just so surprised anyone thought it would be a good idea to release the UJK Technology Chamfer Tool designed as it is.
« Reply #227 on: August 22, 2019, 08:34 AM »
@Dusty.Tools  Ben, do you mean the breakout on exit, underneath, or the initial cut at the top?
@ben_r_  I really love the PGS, I think it’s a great invention but, I alway chamfer the holes with a router and chamfer bit.
I like using the Parf dog system, so I chamfer all my tops and the router is a fast solution.
The chamfer tool is fine though if you just need to do a few holes for a cutting station, or don’t own a router.
Offline Dusty.Tools
    • Dusty.Tools
« Reply #228 on: August 22, 2019, 08:36 AM »
In the initial cut, I end up with a little round disc of laminate.
@dusty.tools
« Reply #229 on: August 22, 2019, 08:59 AM »
Ah ok, got it. You might need a different type of forstner bit, or maybe the Festool 20mm Euro hinge boring bit, I think Bosch make on as well.
Some of these type have a sort of serrated bottom, that should cut through the laminate. I think they are, or were expensive though.
Offline Peter Parfitt
  • Magazine/Blog Author
« Reply #230 on: August 22, 2019, 04:05 PM »
The clean exit hole of the UJK 20 mm cutter is the reason that the disc is there after a cut. On exiting, the hole is quite clean and so a neat little circular disc is formed by the wings of the cutter.
Offline ben_r_
« Reply #231 on: August 22, 2019, 05:49 PM »
Wow, just added the Mark II system with the dust collection piece to cart and shipping (to California) from both Axminster and TSO Products and wow what a price difference!
Axminster: Parf Mk II Guide System ($175 USD) + Parf Dust Port ($26 USD) + Shipping ($10.06 USD) = $211.06 USD
TSO Products: Parf Mk II Guide System ($229.95 USD) + Parf Dust Port ($34.95 USD) + Shipping ($21.34 USD) = $286.24 USD
Saved me $75! Hopefully this saves someone else some money too! Can put those saved funds to some Parf Dogs for your new bench!
And wow I had no idea UJK made/rebranded so many other tools! (LINK)
EDIT: Soooo, to update this post, it appears now TSO lowered its prices and Axminster raised them. Go figure.
« Last Edit: September 20, 2019, 06:38 PM by ben_r_ »
« Reply #232 on: August 22, 2019, 06:33 PM »
Hi Peter, I think Dusty is saying that on the initial cut, the bit is cutting a laminate disc, and will not cut any further/deeper until the disc is removed. He cannot clear the disc without removing the jig though.
Unless I’m mistaken?
JJ
Offline ChiknNutz
« Reply #233 on: August 22, 2019, 09:39 PM »
I unfortunately did not know to price check until well after the fact.  Was a bit perturbed that TSO adds such a markup, but buyer beware!
-Chris
Offline Rta108
« Reply #234 on: August 23, 2019, 04:15 PM »
...AND I’m betting international DHL package gets to you faster than domestic UPS.
Offline ChiknNutz
« Reply #235 on: August 23, 2019, 04:21 PM »
I'd like to state for the record that Hans from TSO both emailed and called me regarding this price discrepancy.  I won't elaborate on the specifics, but will say their response is more than acceptable...especially given I never even asked for anything from them directly.  I just chalked it up to me not doing my due diligence (which I almost always do to a fault).  So I will say that TSO continues to be a great company to deal with.
-Chris
Offline Dusty.Tools
    • Dusty.Tools
« Reply #236 on: August 23, 2019, 06:11 PM »
It does yes! I just ordered a few parts and it'll be in Seattle on Monday!
@dusty.tools
Offline Dusty.Tools
    • Dusty.Tools
« Reply #237 on: August 23, 2019, 06:12 PM »
JJ
That's correct yes. It's a little disc of laminate which stops me cutting into the mdf.
@dusty.tools
Offline ben_r_
« Reply #238 on: September 03, 2019, 06:53 PM »
What is the size of the shaft for the 20mm cutter bit? Thinking of ordering a better stop collar for it, stainless or hardened steel or something, and need to know what size to get.
Offline TSO Products
    • TSO Products
« Reply #239 on: September 03, 2019, 07:48 PM »
@ben_r_   - until AXMINSTER replaced the (less than optimal) collar and screw TSO added a 10mm,  Stainless Clamping Collar to all Parf Guides we sold. We still have a few of those left - also in Steel. Email your last TSO order number and we'll send one at no charge to that address,
Hans
TSOproducts.com
