Author Topic: OF1400 Router Base DWG or DXF  (Read 4942 times)
Offline capww8
« on: October 06, 2016, 02:47 PM »
Anyone have a CAD block showing the screw positions and shape of an OF1400 router base?
Offline andygiddings
Re: OF1400 Router Base DWG or DXF
« Reply #1 on: June 01, 2017, 09:00 AM »
Resurrecting this old thread as I've just created a PDF showing the router base viewed from below. Unfortunately I can't add a DWG or DXF as the file type is not allowed.
The small circle in the middle is obviously not part of the base - I used this for drilling holes in a circle template and the small circle is for centering purposes.
Offline ben_r_
« Reply #2 on: June 01, 2017, 05:50 PM »
How did you take the measurements? And probably should have included the outer measurements too, just for completeness :)
« Reply #3 on: June 05, 2017, 05:50 PM »
Digital calipers, Ben. If you print the PDF at 1:1 or full size you can use the print as a template (print on paper, card or film and then use tape to fix it to whatever you are machining)
