Author Topic: My version of the MFT sysport cart  (Read 13554 times)
Offline Justin Michael
« on: January 06, 2015, 12:28 PM »
I finally had time over the holidays to design and build my version of an MFT/3 sysport cart.  Viewing previous FOG post on similar carts was very helpful and provided quite a bit of inspiration.
The cart is 35/ 3/8 tall (~900mm) and 30 1/2 D x 45 1/2 W which allows for edge clamping of tall or wide boards on all sides. I also bored the corner supports for 5/8" pegs to support such pieces.  It's put together with pocket screws and is extremely sturdy sitting on red 3" locking casters from HD.
In total, I used 1 and 1/2 sheets of 3/4" birch plywood, a couple board feet of 8/4 ambrosia maple for the corners, and edge banding to make it look purdy.  I will eventually build some small drawers for that center area to hold clamps, dogs, tape measures, etc. as well as some in the back area next to the CT26 for whatever.
As you can see, I still have room for a few more systainers.   [smile]
Thanks for looking.
TS55 REQ, MFT/3, CT 26, Rotex 150, 1900 rail, and clamps
Offline Don T
  • Phoenix, Az
Re: My version of the MFT sysport cart
« Reply #1 on: January 06, 2015, 01:09 PM »
Looks real nice.
Offline copcarcollector
« Reply #2 on: January 06, 2015, 01:26 PM »
Looks great!
Be careful, its a dangerous thing to have room for 'a few more systainers'! :o
Offline Billedis
« Reply #3 on: January 06, 2015, 05:17 PM »
Nicely done.  I like the hose holder, could you tell me more?  Bill
Offline Gerald_D
« Reply #4 on: January 06, 2015, 05:53 PM »
Looks great- I like how you made a cubby area for broom and clamps- will have to add that in my design.  Hopefully I'll have time to make mine this spring.
What CT do you have installed on the backside?
Gerald
Gerald
I have Festools- Big and Small and a few other tools
Offline Baremeg55
« Reply #5 on: January 06, 2015, 06:49 PM »
Justin, looks great!  Thanks for sharing!!!
Gary
« Reply #6 on: January 07, 2015, 09:57 AM »
I only have 8ft ceilings so i attached a 24" rod with screw-in eyes, then use a bungee cord and a swivel clasp to suspend the hose.
I also wrapped the hose in Tech Flex 1 1/2" in diameter which works perfectly on the 27mm hose.
http://www.amazon.com/gp/product/B0008JF8U0/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Offline Billedis
« Reply #7 on: January 07, 2015, 10:09 AM »
Thanks for the info Justin.
Offline Iceclimber
« Reply #8 on: January 07, 2015, 12:40 PM »
Looks good!
Can you give us a close up of both ends of the hose on the CT so i can see the transition or end point of the tech flex..
I have bern considering this stuff myself but am unsure i will like the unfinished ends.
Sure beats the cost of sourcing the Festool hose covers from overseas though! My other real consideration..
Kapex, MFT/3, MFT, CMS VL, 1400, TS75, Carvex420, CXS, DTS 400, Midi, CT36, RO90 and a bunch of other little junk and accessories it would be nuts to get into listing..
Offline mike_aa
« Reply #9 on: January 07, 2015, 01:10 PM »
Justin,
Nice work, but there's a potential for serious injury with the use of bungee cords.  They don't look harmful, but they can be dangerous.  Here's an article about what can happen.  I knew someone who lost an eye to one of these.
Mike A.
« Reply #10 on: January 07, 2015, 01:34 PM »
Mike,
Thank you for the heads up; I've had (other) bungee cords snap back in the past but have been lucky.  In this instance, there isn't much tension on the bungee, just the weight of the hose itself.  It was more about convenience at the time I put it up to hold the swivel. One could definitely use a piece of para cord or clothes line instead to support the hose from the ceiling which I'll likely do this weekend.  Thanks again.
« Reply #11 on: January 07, 2015, 01:36 PM »
Looks good!
Thanks. Sure, I'll take some pics tonight.
Offline wow
  • Inactive Member
« Reply #12 on: January 08, 2015, 02:34 AM »
Nice job, Justin! Very well planned and executed.
Now, as for your comment:
My prediction is "Not for long!"
« Reply #13 on: January 08, 2015, 01:46 PM »
Looks good!
I've attached pics of the ends of the Tech Flex.  I think WOW used shrink wrap, but i didn't have any of that so i just used zip ties.  I used a lighter to keep the ends from fraying.
Offline gnlman
« Reply #14 on: January 08, 2015, 02:05 PM »
Nice Job. Hoping to get rid of my temp table and build something along the same lines for my mft.
Interested in the techflex idea. Do you think that size techflex would expand enough to fit the 36mm hose (with plugit) as well?
Thanks Greg.
« Reply #15 on: January 08, 2015, 10:42 PM »
Thanks Greg.
Definitely. It fits just fine over the plug it and my Bosch 35mm hose.
Offline Baremeg55
« Reply #16 on: January 08, 2015, 11:06 PM »
Justin,
I was wondering if you still like having the CT located within your sysport?  I have the boom arm on my CT, thus, was considering having shelves on each side for systainers, and just park the CT close by.  Again, nice job!
Gary
Offline Drich
« Reply #17 on: January 09, 2015, 07:02 PM »
Very nice job on that. I need to do something also along that line. Any  thought of posting your plans for the build?
« Reply #18 on: January 10, 2015, 11:11 PM »
Justin,
Gary
Thanks. I definitely prefer having the CT on the back - its now out of the way. I have plenty of storage elsewhere and to me the shop is now more ergonomic and "clean".
Offline johnesher
« Reply #19 on: April 03, 2015, 05:28 PM »
I too would be interested in plans.
Offline thedevme
« Reply #20 on: February 19, 2019, 08:02 PM »
Thanks for looking.
@Justin Michael do your dimensions include the caster height?
Offline nicholam77
« Reply #21 on: February 05, 2020, 11:19 AM »
@Justin Michael I really like your design, great work! So much so that I'm trying to replicate it for my own use. I know this thread is old and not sure if you're still active on this forum, but..
I see you have used pocket holes for the plywood-to-plywood connections, but would you mind sharing how you attached the legs to the top and bottom pieces? Thanks!
Online vkumar
« Reply #22 on: February 05, 2020, 11:54 AM »
Very nice build @Justin Michael . What type of casters did you use?
Vijay Kumar
Offline StevoWevo
« Reply #23 on: February 06, 2020, 03:54 AM »
Looks like this one Vijay
Offline Mortiser
« Reply #24 on: February 06, 2020, 09:52 AM »
I've been pleased with these, but you may want to check your load.
https://www.amazon.com/gp/product/B01FJ97E64/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
Rich
Offline sandy
« Reply #25 on: February 10, 2020, 10:42 AM »
I have only, recently, learned of the potential danger associated with bungee cords, but I see that it has already been discussed in the this post.  I was wondering, though, whether the danger could be minimized if the hooks on the ends were clamped closed to minimize the possibility of one of them coming off the piece of conduit.  They could either each be made into closed loops that went over the conduit, or they could be connected together, as I do like the overall idea.
On the other hand, I guess pretty much the same thing can be done, albeit safer, using yacht line,  Given that I've been playing with yacht line eye splices, I think that an alternative could be a length of yacht line with an eye at one end sized for the conduit, and an eye at the other end sized for the vacuum hose.
Sandy
