Author Topic: My DIY 8020 MFT  (Read 3966 times)
Offline modeller
    • Modeller | modern modular shelf system
My DIY 8020 MFT
« on: February 17, 2019, 05:53 PM »
I thought some of you might be interested in seeing how my 8020 MFT works with the woodpecker router jig and some Bessey track/table clamps. they fit into the woodpecker rails with a bit of sanding and I use parf dogs with nuts to attach the woodpecker router jig on edge
https://www.dropbox.com/sh/wbyq3ww7zby4wzm/AADoJrZm74PCfffHD9mPJYqqa?dl=0
293045-0
Offline Renovatedspaces
Re: My DIY 8020 MFT
« Reply #1 on: February 18, 2019, 02:45 PM »
Nice set up. how do you like  the Vac Sys? I’m on the fence about getting one.
Kapex, CT 26e, Installers clean up kit, RO 125, MFK 700, Domino 500, Carvex 420 with Kit, TS 75
Offline modeller
Re: My DIY 8020 MFT
« Reply #2 on: February 18, 2019, 05:51 PM »
I didn't use the vac sys much until I mounted it to the side of my bench, flush with the top. now it indispensable. I bought it at the same time as my Conturo. I had a large job with edge banding so I could justify the cost. I've even used it once when I cut a piece too short so I banded on 3mm edging to fix my mistake!
« Last Edit: February 18, 2019, 05:56 PM by modeller »
Offline stickman
Re: My DIY 8020 MFT
« Reply #3 on: February 18, 2019, 08:27 PM »
Quote
I am super interested. How big is your table? Do you have a cut list you want to share? I really want an 80/20 based assembly table but every time I try to build a cut list to order I give up lol
KS-120 | TS-75EQ | DF-500Q | XLDF-700 | RO-150FEQ | RO-90DX | HKC-55EQ-FSK420 | EBQ-420D | MFT/3 | CT-26 | CT-SYS | T18+3 | OF-1400EQ |  TSC55 REB PLUS | HL 850 | RAS-115 | VECTURO OS 400 | PDC 18/4 | LR32-SYS | SYS-ROLL 100
Offline modeller
Re: My DIY 8020 MFT
« Reply #4 on: February 20, 2019, 12:05 AM »
Offline Reds-Garage
Re: My DIY 8020 MFT
« Reply #5 on: April 06, 2020, 01:32 PM »
Quote
I'd recommend going through AluFab.  They help you with the design and cutlist, they are good about filling in parts that you didn't think of.  I did a few projects where i got all my parts and then realized I was missing a bunch of little things that I forgot about lol.  I'll post AluFab's website, you can email them direct from there or call them
www.alufabinc.com
Offline Dusty.Tools
    • Dusty.Tools
Re: My DIY 8020 MFT
« Reply #6 on: April 09, 2020, 12:25 AM »
I will have a blog post up on ToolGuyd shortly that starts with my frame design. It should give you some ideas :)
@dusty.tools
Offline williamduncan
Re: My DIY 8020 MFT
« Reply #7 on: April 19, 2020, 11:46 AM »
Not finding your post over there yet...but which 8020 profile did you use?
