Author Topic: DF500 modification for extra fence height -- Useful?  (Read 2078 times)
Offline ChuckS
I came across this:
https://www.instagram.com/p/Bxd_yssDZNV/
Trying to think of an application for it. [unsure]
Offline Bert Vanderveen
Re: DF500 modification for extra fence height -- Useful?
« Reply #1 on: May 15, 2019, 02:54 PM »
It has been done by others. Takes care of the minimum width of material limitation, eg you can use material under half an inch down to possible 3/8, still centering the domino (though using 4 mm domino on 3/8 is cutting it close, I think).
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · DTS 400 · ETS EC 125 w 150 pad · Surfix Set · CTL SYS · CT-VA-20 · … | Mirka 1230L P&C | Hammer: A3 31 Silent Power · N4400 · HS950 | TaigaTools: VacPods Pro Set
On order: … [ ! ]
