From Festool in Finland, part number 496824
So you'll use the MFT top as a template? I'm interested in your results. Have you done this before? Will you drill then finish each hole with template bit? That's a lot of holes, but it's a whole lot cheaper than CNC or LR32(when you don't already have it). That's the way I'm leaning right now, but have never done anything like that.
Quote from: Fin66 on March 21, 2014, 01:20 PMFrom Festool in Finland, part number 496824NAINA for some unfathomable reason.
I'm curious why people aren't having a cnc shop do these? Can one really achieve that kind of precision?
Quote from: duburban on March 21, 2014, 07:44 PMI'm curious why people aren't having a cnc shop do these? Can one really achieve that kind of precision? I'd have to ask, is that kind of precision that necessary in what amounts to a work table? Yes, it's nice to have from the standpoint of knowing that it was done precisely. Yes, it looks better and is in context with Festool's precisely made machinery. If I looked, I could likely find a CNC shop to do the job, but aside from the aesthetics, why bother? After all, it's a sacrificial top. I, for one, have not encountered a situation that depended on the holes in my MFTs being cut dead nuts on the 96mm grid. YMMV.
@squarecut, so how was it? I've seen some people recommend that method, but then others say they'll never do it again that way. Maybe it depends how big a top you do? What router did you use? I've got only got one router(makita 1100). With the price increase looming, trying to decide if I should by an OF1010. I've bought a bunch of green tools recently(as well as some red and will buy more by the end of the month(more green), but wondering if I can save some money by skipping the router. I'm sure I can do the mft holes with the Makita, but I'd like to get a smaller router and this might be the excuse I need for the OF1010.
Quote from: Sparktrician on March 21, 2014, 08:08 PMQuote from: duburban on March 21, 2014, 07:44 PMI'm curious why people aren't having a cnc shop do these? Can one really achieve that kind of precision? I'd have to ask, is that kind of precision that necessary in what amounts to a work table? Yes, it's nice to have from the standpoint of knowing that it was done precisely. Yes, it looks better and is in context with Festool's precisely made machinery. If I looked, I could likely find a CNC shop to do the job, but aside from the aesthetics, why bother? After all, it's a sacrificial top. I, for one, have not encountered a situation that depended on the holes in my MFTs being cut dead nuts on the 96mm grid. YMMV.I don't use the fence on my MFT. I just use the holes to line up 90's and 45's. I like the speed of it. I would need my holes perfect to keep doing that. I am building a larger work center and have contemplated the CNC route vs. me using my lr32. Depends on price and how close the CNC shop would be.
Quote from: bkharman on March 21, 2014, 09:13 PMQuote from: Sparktrician on March 21, 2014, 08:08 PMQuote from: duburban on March 21, 2014, 07:44 PMI'm curious why people aren't having a cnc shop do these? Can one really achieve that kind of precision? I'd have to ask, is that kind of precision that necessary in what amounts to a work table? Yes, it's nice to have from the standpoint of knowing that it was done precisely. Yes, it looks better and is in context with Festool's precisely made machinery. If I looked, I could likely find a CNC shop to do the job, but aside from the aesthetics, why bother? After all, it's a sacrificial top. I, for one, have not encountered a situation that depended on the holes in my MFTs being cut dead nuts on the 96mm grid. YMMV.I don't use the fence on my MFT. I just use the holes to line up 90's and 45's. I like the speed of it. I would need my holes perfect to keep doing that. I am building a larger work center and have contemplated the CNC route vs. me using my lr32. Depends on price and how close the CNC shop would be. I understand that. I do use the fence which is why I posed the question. For my purposes, the LR 32 would do a splendid job and look great. The bigger issue would be getting a 20mm bit that would cut the holes precisely so that my QWAS dogs would fit right.
I had a aluminium laser cut template made this week and used a 24mm copyring and aligned the template with 24mm home made "Qwas Dogs", the result is very good.
