Author Topic: MFT Top/UJK Parf Guide/Cutting station  (Read 531 times)
Offline phamt78
« on: June 24, 2020, 02:41 PM »
Hello Everyone,
Just wanted to share my cutting station. I finally had time to make it.
Wish I bought the mark II. I bought the mark I a while ago when it first came out.
I finally had the time to take it out the box and make a cutting station today.
Thanks Peter Parfitt,
Truong
Offline TSO_Products
    • TSO Products LLC
Re: MFT Top/UJK Parf Guide/Cutting station
« Reply #1 on: June 24, 2020, 08:42 PM »
Hello Everyone,
Truong
[/quot
@phamt78 - welcome to the FOG and congratulations for getting started with your Parf Guide Mk 1.
Alsway helpful to see work - in -progress or finishe dwork as in your case - with pictures - THANK YOU.
Let me re-assure you that both versions are equally accurate.
If yo did not  buy the Parf Dust Port - I highly recommend it. Snap it on and quit fiddling with vac hoses while trying to drill.
You also should have a Clamping Collar. If you purchased from TSO it likely included  our custom Stainless Clamping Collar. If not TSO has a few left in stock as AXMINSTER have now switched to a Clamping Collar instead of the earlier less than satisfactory Stop Collar.
Keep up the good work and keep posting!
Hans
Offline Rick Herrick
« Reply #2 on: June 24, 2020, 11:05 PM »
I second Han's suggestion on the Parf Dust Port.  At first you think it might be hokey but its incredibly useful.  I did about 80 holes today and twice I forgot to turn on the vacuum and boy, does that 20mm spit out some stuff.  The Dust Port catches pretty much all of it.
Offline Josh2
« Reply #3 on: June 25, 2020, 11:31 AM »
Thanks for sharing! I like it because it's simple and efficient. I am working on my own. Is this a Incra TTRACKPLUS36 36" T-Track Plus? What do you use to attach the adjustable DIY rail support to both ends?
Hello Everyone,
Truong
